Question about Acer Aspire 4315 Notebook
I'm also experiencing same sort of white screen problem.
Video seems unstable when first turned on. If notebook is just turned on and left alone, it will usually "white out". However, if I am patient enough to wait through the boot-up sequence, then start using the computer immediately, the video sometimes remains stable. The "white out" isn't
pure white. but seems to consist of moving narrow vertical stripes of varying shades of near white.
  • Acer Master
  • 32,281 Answers
To determine if the LCD screen or the video card is faulty, connect an external monitor to the video connector on the laptop. Power up the external monitor first and then the laptop. The video should divert automatically to the external monitor and if you get a normal image then the video card is OK and the fault could be the LCD screen or the video cable. Reseating the video cable and connector on the motherboard could fix yout problem.
Posted on Jun 14, 2009
Intermitently, my screen goes dark, but the
1.)It could be your video card
2.) Yes it is expensive for a laptop
3.)I would first check your screen setting for turning off display...
If you are using vista:
-Right click on your desktop then choose personalize
-Then click screensaver
-On bottom click on "change power settings..."
- On the left click on "choose when to turn off the display"
Your monitor can turn off without your computer being in sleep mode.
Dec 26, 2009 | Toshiba Satellite A105-S4334 Notebook
Hello today I had an white vertical line in the center of my PC screen Gateway E2500s series would not shut down from the tower so IV turned it off with the surge and waited a few them turned it back on...
You mention in your post to branded laptops. You can try to check if the problem is from the LCD or from the Video card. Connect your laptop to an external monitor and check if the white vertical line appears, if yes replace motherboard if video card is integrated, if expansion then replace video card alone. If no lines from the external monitor then laptop LCD has the problem.
Oct 03, 2009 | Dell Latitude D505 Notebook
Screen goes all shaky and white for short intervals of time.
Try installing the video drivers from HP's site.
Sep 22, 2009 | Compaq Presario Notebook
Acer Aspire 9410 Notebook
Try updating the video driver. Also try to connect your laptop to external machine to check if the video display on the other machine is ok or not.
If same problem occur, suspected the LCD of your laptop is faulty and needs to be replace.
Jun 07, 2009 | Acer Aspire 9410 Notebook
I turn it on i get white blank screen. same when external is hooked up
Seems it is the Video card which has gone bad, If in case your system shows Compaq on your screen, os in that case need to install windows in the system again.But if it does not , Please get your system's Video card again.
May 25, 2009 | Compaq Presario 700 470024-192 Notebook
Mortherboard,keyboard replacement on gateway m360
First I would ensure my video cable was firmly connected. Sometimes that connector does not seat all the way causing what you are seeing. That is the rectangular connector leading fro the cable on left side of the LCD to the motherboard. Normally there are several hardware components related to a white display. LCD, video cable, or motherboard all causes of white screen. Have you checked external video? What was the original issue before motherboard and keyboard replacement?
Mar 14, 2009 | Gateway M360 Notebook
Videocard problem?
Hello Gergerald,
To isolate the issue further connect the notebook to an external monitor and check the display on it. If the display is perfect on external monitor then the issue is with the LCD screen of the notebook.
If you have got the same lineds on the external monitor then the issue is with the video card of the notebook.
Sep 10, 2008 | HP Pavilion zd8000 Notebook
Bottom Screen
Try to get hold of a tri pronged screwdriver to open up the back of your ds (you can get them from "www.whitedog.co.uk/catalog/nintendo-wing-screwdriver/p-1169.html". Once you have opened it it should be easy to sort out as you can take the whole screen apart. It's quite easy once you've got the screwdriver :-)
Nov 05, 2007 | Nintendo DS Console
Phone resetting
have the keyboard replace to hopefully correct this issue
Sep 16, 2007 | Motorola Mobility SLVR L7 Cellular Phone
LCD powers off and on repeatedly
Your monitor power supply is unstable and needs your expert attention. Check out for bad capacitors.
Apr 02, 2017 | Scanport GL 821A 17 in. Flat Panel LCD...
Acer Aspire 4315 Notebook Logo
164 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
