Question about Garden
I got the tiller started and another person lowered the speed and when they did it died and since then it wont start i checked the fuel changed the spark plug checked oil and have about pulled my arm off i cannot get it started what should i try???
  • panilling9
    panilling9 May 11, 2010
    do you have the engine model and brand please
    President:
  • 1,776 Answers
Check the throttle cable and the throttle linkage.
Posted on Jul 11, 2009
Tiller will not continue to run. It has good spark. It will start if primed through the carburator but once the prime burns off it dies.
If fuel sits in the gas tank 3 months, the fuel deteriorates and it gums up the filter in the tank. You need to put stabil in the tank. This has happened to me over and over. It is best to dump out the gasoline if you don't use the tiller within one month. Some people who use chain saws commercially dump all the gas out every day and start over the next day. The symptoms are the tiller won't run at high speed at first, then as it gums up more
it won't run even at low speed, then becomes hard to start.
The gum is hard to see. Pull out the gas line to get to the filter and change the filter. Filters are only 3 or 4 dollars at hardware stores.
Jun 01, 2012 | Honda 25cc 4-cycle Mini Tiller
Honda fg100a wont stay running full of fuel and oil
I had a similar issue. Tiller starts and runs for 20 secs. or so then dies. Found the problem! In turning the tiller on its side to check model numbers etc. the fuel line had shifted inside the tank and was stuck just about at the TOP of the fuel level. When I gently pushed the fuel filter and line back to the BOTTOM of the fuel tank, the tiller now runs beautifully! So, check that the fuel line placement inside the fuel tank is correct.
Sep 29, 2011 | Honda 25cc 4-cycle Mini Tiller
2 stroke Mantis Tiller 1) Very difficult starting, when started, high rev works, but 2) Engine dies on deceleration. Carburetor is signed C1U K4589A. The priming pump does not suction, gasoline...
Hi there is a small stone fuel filter in the tank. this filter stops fuel from running back into the tank from the carb check to insure it still on and make sure there are no cracks or hole in fuel line that should fix your problem
Aug 31, 2011 | Mantis 2-Cycle Tiller
MTD lawn tractor will start but dies after 3 seconds no matter where speed control is moved or left, choke adjusted, etc. First starting after 5 months.
If your fuel valve fully ON? Is there dirt in the tank? Is the filter clean? These are the the first things you should check.
Apr 30, 2011 | Mtd Products Yard Machines 158CC Tiller
I have a sears mini tiller,2cycle and i can get it to start,but when i try to throttle it up it dies
try it with the choke on, if this helps then clean the carb and check fuel filter if it has one,if all that doesnt help then open up low speed jet and try that, another cause could be muffler screen plugged w/carbon, remove and clean
Apr 13, 2011 | Craftsman Gas Mini - Tiller/Edger
Mantis starts ok, and idles just fine, but when you give it gas it dies?
Start with the basics. Check condition of fuel lines and fuel filter. May need a simple adjustment by backing out on the low mixture screw just enough to give you a smooth "throttle up". You may also need to open the high mixture screw to obtain proper high speed. If adjustments do not correct the problem, you could be looking at overhauling or replacing the carburetor, whichever is more cost effective. Hope this helps.
Feb 24, 2011 | Mantis 2-Cycle Tiller
Gas coming out of exhaust, wont idle, dies when fuel is applied
Gas came out because it is flooded. Check the spark plug for damage.
If it has been sitting for a while empty fuel tank. Prepare fresh fuel/oil mixture to fuel tank. Add two ounces of 100% acetone (available at Walmart) and attempt to start several times. Let sit for several minutes. Repeat until it acts like it wants to start.
Then watch this video and do it:
http://www.alamia.us/mantis_parts_s/148.htm
Never let tiller sit with fuel for any prolonged period of time. Run it out of fuel before storing or sitting. Acteone will remove varnish from inside.
Oct 17, 2010 | Mantis 2-Cycle Tiller
Maxim tiller won't run
Try better quality gas. I had the same problem. Ethanol too high in lower grade gas. Buy better grade or ethanol free. Mine works fine with better gas.
Apr 06, 2009 | Maxim Garden
Mantis tiller 2 cycle seemed as if it was running out of gas
Check fuel filter and lines, if thay are good I would get a carb kit and set the adjustment screws at 1 turn out from lightley seated to start. Don't lean high speed screw too much.
You might check muffler & cylinder port for carbon first.
Mar 20, 2009 | Mantis 2-Cycle Tiller
Will not crank
no that would not keep the engine from starting. is it an electric or manual start motor?
Sep 10, 2008 | Mantis Tiller
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
