Question about Dual Electronics CECT P168 Cellular Phone
My phone wont charge
I plugged it in and nothing happens. it has trouble connecting with the pc and it tells me that it has bad contact to the charger.
  • 93 Answers
Well then i would suggest buyinh a new charger
Posted on Jun 14, 2009
    Sniper:
  • 76 Answers
On your usb cable on the end that goes into the phone you have on one side nothing and on the other side an arrow. the side with the arrow goes DOWN, so that when it is plugged into the phone you don't see the arrow.
When i plug my blackberry pearl in its charger nothing happens. It wont turn on or nothing.
try a secondary battery as well as a second charger (I believe the pearl uses micro USB, which is also used by bluetooth headsets, other phones, and pcs- you could even plug it into a pc with the cable to see if it charges)
If neither works, the phone is unfortunately dead. However if the battery works, bad battery. If the different charger works, bad charger
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Mar 31, 2011 | RIM BlackBerry Pearl 8100
I have plugged in the samsung phone into the computer but it says that there is no phone connected! Need help quick!
sxc marzzy . HI ok you need to check the usb connection on your phone . it has to be on ask plug. IT a litttle different if you have one of the smart phones. BUT all you do is go into the settings . Scrool down to the usb connection . Because you could simply have a bad charging port on your phone. I can't tell which one it is .Now do you have trouble charging the phone at all. if you do then your charging port is bad. I can guess that it may be the usb settings on the phone. If you change those settings the computer should now see your phone. Hope this help if not go to your local carrier see what options they may have for you.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Dec 16, 2010 | Cell Phones
Motorola phone wont charge. was charging yesterday, but today i plug it in and nothing happens. what can i do? I've tried two different chargers, and still the same. Do i need a new battery? or maybe a...
the fault is not from the battery. Its from the phone charging port.
You can decide to get another phone or repair/fix the bad charging port.
Good luck.
Jul 19, 2010 | Motorola Mobility V323 Cellular Phone
Laptop wont start up
Does it have a vga port, so you can plug it in to a monitor, if it does plug it into a monitor and see if it works, then you know the screen is bad.
Contact to toshiba and see about getting it repaired, and contact a local
place and see what they would charge, then pick.
Feb 12, 2010 | Computers & Internet
My Iphone is stuck on a demonstration telling me to plug it in to itunes. when i do this nothing happens.
you need to restore your I PHONE DO ONE. switch on your i tunes and connect your i phone to your latop or pc then(if it comes in window that update or restoration your phone then click on that then wait for 10 to 15 min when you i pnones charging on phone then take it out.
Nov 09, 2009 | Cell Phones
Phone won't charge
check charger pins and charger socket and its contacts and the fue in the board. if anyone fails in this charger wont work.
Feb 06, 2009 | Sony Ericsson W660i Mobile Phone
Powers on immediately powers off
ok well there is somwhere to start i would see if you can get it to take a charge ok and if it does than try to start it without the ac power on and see what it does if it wont take a charge your battery may be bad or your charging circuit may not be connected correctly ok lrt me know best regards mike
Aug 27, 2008 | Dell Inspiron 5160 Notebook
Sony Ericsson K770i Phone won't turn on red light apears on the top left, any suggestions?
This has happened to me twice - the first instance occurred when I'd only had the phone a few days and the second occurred today after months of trouble-free use.
On both occasions the phone wouldn't charge via the mains charger - it wouldn't switch on even when plugged in and neither the battery or the charger were warm to the touch after hours of charging, indicating that nothing was happening.
The solution for me was to connect the phone to my PC via the USB cable - nothing happened at first, the PC didn't recognise the phone and it remained lifeless. However, I left it attached to my PC and after 10-15 minutes it suddenly whirred into life.
The battery was COMPLETELY flat despite my attempts at mains charging, so I let it charge via USB for a while then transferred it to the mains charger. This time the mains charger worked.
I've no idea why, but this has worked for me twice so give it a try.
Jun 07, 2008 | Cell Phones
check your charger first, if charger is ok then check the charging connector on the phone, clean it with a toothbrush and solvent cleaners.
Mar 27, 2008 | Samsung SGH-V200 Cellular Phone
Phone shut off
Plug it into your walloutlet usb charger rather then the one connected to your pc. once your battery is so low it wont even have enough juice to show the charge battery screen if your chargeing through the low voltage pc active sync cable.
Feb 11, 2008 | Motorola Mobility Moto Q
Dual Electronics CECT P168 Cellular Phone Logo
122 people viewed this question
Top Dual Cell Phones Experts
William Alequin
270rexton
270rexton
iphone service
Are you a Dual Cell Phone Expert? Answer questions, earn points and help others
