Question about DeLonghi BAR 140 Espresso Machine
Espresso Hi there....i have the 140 bar machine does the handle/ coffee holder fit with the filters etc and fit tightly into the propper place??? it doesnt seem to go in and lock after the filter is in I doing it wrong???
  • cincin Nov 02, 2007
    its not that...I can get it to snap into place with out the filter in the apparatus, but once the little filter is in it, it wont go up into the locking mechanism....almost like I dont have the filter in the holder right...or upside down...and not sure what the black rubber thingy is for??? I really need a diagram of how it all fits together....i have the manual...but am still not getting it to fit in the locked position....
The filter has a little indent that must be placed correctly, if you put the filter in the holder and then rotate the filter you will feel it click into place when it is in the right position ( there is a gap for the indent at the front of the holder)
Posted on Nov 02, 2007
Broken handle on filter holder
Yes, you should be able to buy them. Let me know if you can't find one, cause I have one.
Apr 19, 2010 | Solis Crema SL-90 Espresso Machine
I purchased a new machine and cannot seem to get the stainless steel filter to fit into the filter holder and then fit into the slots - what is the trick?
try this: on the handle there is a black clip that needs to be slid back away from the filter holder; filter basket should now fit (more or less); the markings for lining up the filter-handle into the brew-head slots are a little off; look up at the brew head, familiarize yourself with the location of the slots; line up the filter handle (make sure that black tap is still pulled back, or it won't go in). hope this helps!
Sep 10, 2008 | Breville ESP8XL Espresso Machine
Briel Versatile Due Coffee Machine
You can get it at the Briel service/distribution center at:
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
Sep 05, 2008 | Briel Domus Due Espresso Machine & Coffee...
Krups XP4020
The coffee holder is just hanging in place, not secure against the seal as it should be. Make sure the coffee holder is secured flat up against the seal before turning the handle and locking it into place.
Apr 18, 2008 | Krups Allegro FND111 Espresso & Coffee...
Breville ESP8XL Espresso Machine Cafe Roma leaking.. help please..
We had that happen and it was a crack in the black ring that holds the filter. Breville could not supply us with one but we found an OEM part in aluminum from We received it 1 week after ordering. It was pretty easy to replace. Our machine works fine now.
Mar 06, 2008 | Breville ESP8XL Espresso Machine
Breville Die Cast 800ESXL has a silicon seal (steam ring) to replace faulty or worn ones. There is no shipping charge, and they are $4 each. To replace the steam ring you'll need to remove the stainless spray disk on the brew head with a phillips screwdriver (one screw) and pull off the old ring (pay attention to the direction and placement of the stainless disk).  Takes about 2 minutes to do.
Part # .800ESXL/192
Also, on mine I noticed that the filter holder was ground down at the factory a bit too much on one side, which causes a slight leak down one side (coffee, not water).  You might check the holder (with the filter removed) for imperfections that could lead to your leak. Good luck.
Feb 17, 2008 | Breville Die Cast 800ESXL Espresso Machine
Coffee Machine
The filter and the holder are actually sort of oval shaped, not perfectly round. It will fit, takes some monkeying around with it. Careful tho, the edges are pretty sharp for my 60-wpm soft hands.
Dec 17, 2007 | Breville Die Cast 800ESXL Espresso Machine
Pavoni Si - leak from above filter holder
Check your screws in the bottom of the portafilter, If they are too tight the spring mechanism inside can't do its job, adjust them and it should work. Also, don't over fill your portafilter, if you put too much coffee in then there is to much pressure and again the water will flow from the top. Hope this helps
Oct 09, 2007 | La Pavoni Espresso Si PAB-16 Espresso...
Failing delonghi espresso machine ed140
check the filter holes. They might need to be cleaned with a needle.
Aug 27, 2007 | DeLonghi BAR 140 Espresso Machine
DeLonghi BAR 140 Espresso Machine Logo
185 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Michael Vincent Cruz
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
