Question about Samsung SGH-ZV40 Cellular Phone
When i connect the phone to the computer.the computer says an problem occured whileinstalling hardware.it might not work properlyand the computer dosent shows the hardware.
  • 1,555 Answers
Uninstall your software, restart your pc after removing your phone from pc. re-install your software don't connect your mobile to your pc restart and then connect your mobile to your pc it will detect it and install the software for it. if it asks for restart then restart your pc.
Posted on Jun 14, 2009
  • 93 Answers
That Is Not A Pc - Enabled Phone.
The sound is not working on my Dell Latitude E5420
click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers
right click on the speaker icon in the bottom taskbar you will see an array of options playback recording sounds and communication select playback devices make sure it has a green tick have a look through all of these make sure all are configured properly
and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers
could be on it although once speakers are connected widows 7 should automatically update the drivers
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker
you might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough
also enhancements and advanced from the drop down
list in the advanced tab select dvd quality or another then apply
if this fails to fix the problem take it back to the place of purchase if possible or ring them for some warranty advice
it might be a faulty sound card
it should be under warranty
hope it helps
Jul 14, 2012 | Dell Latitude E5420 Laptop Computer
My HP Director says it is not connected to the computer BUT the Image software all works properlyand the scanner is fine. What is the problem please. If possible the solution too. Thanks
The problem is that your HP Director software needs to be reinstalled? Run the setup program and when the splash screen comes up, choose the option that says "Add another device"
Dec 23, 2010 | HP ScanJet 2300C Flatbed Scanner
Windows failed to start. A recent hardware or software change might be the cause. file\boot\bcd status 0xc000014c info an error occurred while reading the boot configuration data.
Check the hardware connectivity of your Hard drive and Cd rom drive. Check if the wires are plugged properlyand are not loose. This error is generally thrown when your system is not able to find the boot sector in other words it is not able to find all he information (all necessary file pointers, kernel info And Master Boot Record etc) which it needs to start the system.
In most cases this is a temporary issue and occurs due to loose connections of the cables from Hard drive or CD Rom ( if the system is being booted up from CD).
Nov 18, 2010 | Computers & Internet
My dv6000 dont start . i have black screen with one long beeb and two short beebs
HI friend,
one long beeb and two short beebs Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information,some couse of that issue is New hardware conflicting with old hardware or New hardware conflicting with old hardware or Connections not connected or connected properly or other hardware issue.Best solution is
If any new hardware has been recently added to the computer, remove that hardware to make sure it is not the cause of your issue. If after removing the new hardware your computer works it's likely the computer is either not compatible with the new hardware or a system setting needs to be changed to work with the new hardware device.Remove any disks, CD's, DVD's that are in the computer and if any USB devices (ipods, drives, phones, etc)
before all that please
Make sure all fans are running in the computer. If a fan has failed (especially the fan for the CPU) your computer could be overheating and/or detecting the fan failure causing the computer not to boot.
If you continue to to receive the same problem with all the above hardware removed attempt to disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
  1. Re-insert the memory into the same slot.
  2. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  3. Try one stick of memory in each slot.
Thanks,
Please rate me.......
Apr 04, 2010 | HP Pavilion dv6000 dv6100 dv6200 dv6300...
Cannot recongnize hardware
try connecting it without the usb extension wire. if same error occurs then change the divice
Sep 12, 2009 | Linksys WUSB54GC 802.11g/b Wireless...
Phone is not detected by computer. hardware
pls install motorola phone toola for your phone model from motorola web site
Aug 04, 2009 | Cell Phones
Speech recognition
Reinstall Asus sound card drivers from the setup cd..
Jul 11, 2009 | Computers & Internet
Unable to connect Nokia 3120 Classic with PC
Souns like you need to reinstall the Nokia software. Just pop in the CD and run the setup wizard again. Reboot computer when you are done and try connecting your phone.
If you need further assistance, let me know.
Regards,
Jedi
Mar 20, 2009 | Nokia 3110 Cellular Phone
Hi, my phone wont switch on properly, it just lights up with a wh
This problem occurs because of not ejecting the device properly when connected to pc(computer) via usb cable.
solution:connect your phone to computer via usb at the system tray you see a icon . right click on the icon.the device name appears on the new tab click on it.the hardware is ejected & remove the usb cable
Feb 06, 2009 | Sony Ericsson K750
My PC (Windows XP) refuses my N70 phone now.
first you install the pc suit and then try to install.
Feb 03, 2009 | Nokia N70 Cellular Phone
Samsung SGH-ZV40 Cellular Phone Logo
113 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
