Fluid level is fine changed filter mower has 1025 hours. Well maintained
SOURCE: cub cadet 1863 trans/pump slips and whines in
sounds like the clutch not releasing all the way
SOURCE: I have a cub Cadet M60 Hydrostatic zero turn. When
i have same mower with 200 hours after 30 mins it starts lossing steering and whining i have checked disengage and is ok
SOURCE: I have a cub cadet model 1420 with hydrostatic
i had exmark hydros i was told to never wash them, the water does more damage than good. have you checked or changed your hydostatic oil and filter latley? if you have, when doing that you have to be very careful not to get any foriegn objects in the oil resevoir, dirt, grass clipings, anything will ruin the hydro pump.
SOURCE: I changed both transmission filters (each side) on
The pump is not working - either because you have fitted the new seals incorrectly or it hasn't been primed correctly.
Dismantle the pump again refit all the parts correctly and check the other seals in the process. Then check the fitting of the hydraulic pipes and prime the entire installation by forcing oil in it while rotating the pump and the wheel motors by hand. Do that for both position of the lever to make sure the regulator has also been filled with oil. Finally start the pump motor and shift the lever to forward and push the mower.
the belt tension could cause the mower to not pull on a hill you can pull on the belt and if it's flopping around also look at the belt for signs of oil oil leaking on the belt will also cause the belt to slip
