Question about Husqvarna Designer I
My3120 husquvarna had no spark after sitting for 3 years.I changed ignition module and got spark back.Now it only fires on the first rotation and floods out.whats up with that..maybe not a hot enough spark due to worn fly wheel?help
  • 149 Answers
If its got a carburator then its got a float and needle-seat..remove the carb bowl and clean the float and needle if needle has rubber tip, check to see if its broken off.
Posted on Jun 14, 2009
When putting a new needle in Husquvarna Viking which way is the flat side facing?
Most machines, the flat side faces the back of the machine. But, some machines, especially those that the bobbin loads on the left side, the flat side will face the left. Your manual should show how it should be installed.
Jul 28, 2017 | Sewing Machines
My Viking Husquvarna 1100 sewing machine in great condition was turned on sitting in front of me when suddenly it started to smoke. I unplugged it & placed it outside. Have you heard of this before?
not really but with electricity anything is possible
it could be a broken power cord that shorted out or an electronic control that failed
take it to a sewing machine shop for an examination and diagnosis
Dec 29, 2016 | Sewing Machines
I have a new Juki 8700-7H I switched the feed dogs, throat plate & presser foot to the light duty ones but Now the hand wheel is hard to turn & the stitch length won't adjust. What to do? Timing?
Take your presser foot off and the screws out of the plate. Lift the plate slightly and turn your stitch length regulator to the longest stitch that you use. Now set the plate back down on the feed dogs and see if it will sit evenly without binding. Loosen the feed dog screws and see if you can move the feed dogs enough to allow the plate to sit down. Now, retighten the feed dog screws and rotate the hand wheel towards you to see if they will move freely without binding on the plate. If all well, replace your plate screws and then rotate the hand wheel towards you again.
If this doesn't fix it, you may need to purchase a different # feed dog/plate. You might check to make sure that the items you purchased were meant for a Juki. Mostly they will fit different brands but sometimes it is easier to make sure that the combination of feed dog/plate is actually meant for your Juki.
The other thing you can do is to call a mechanic to readjust the machine to make these work (a more expensive option to be sure!). This has NOTHING to do with your timing. If your machine made good stitches before you change the feed dogs/plate. It should make good stitches after you change it. Timing is all to do with stitch formation and not stitch feeding. Good Luck!
Sep 29, 2016 | Juki Sewing Machines
What do i do? My pe500 worked fine for a month or so then started getting tangled and jamming!!!
1. REPLACE YOUR NEEDLE WITH THE RIGHT NEEDLE.
2. THE BOBBIN THREAD MUST HAVE THE TENSION SET JUST SO WHEN YOU HANG IT FROM YOUR FINGER AND BOUNCE IT THAT IT WILL EXTEND SLIGHTLY.
3. TAKE THE BOBBIN CARRIER OUT AND PUT ONE DROP OF SEWING OIL ON THE RACE THAT THE CARRIER SITS ON.
4. PUT THE BOBBIN BACK IN THE CARRIER AND MAKE SURE IT IS ROTATING THE RIGHT DIRECTION AND GOING THROUGH THE TENSION SPRING.
5. CAREFULLY LOAD YOUR UPPER THREAD WHILE THE FOOT IS UP AND MONITOR ANY SNAGS IF THERE ARE ANY. SET YOUR UPPER TENSION TO 3 TO BEGIN WITH. YOU CAN ADJUST THIS NUMBER ON AN OLD SCRAP WHILE SEWING. IF THERE ARE PROBLEMS YOU MAY WANT TO REPLACE YOUR THREAD WITH GOOD QUALITY THREAD. IF YOUR THREAD IS FUZZY IT MAY BE GETTING STUCK IN THE NEEDLE HOLE.
May 07, 2014 | Brother PE-500 Embroidery Machine
Knife cutting knives
Remove the stichplate and snap out the plastic cover over the thread cutter (left most end of machine). This exposes the thread cutter mechanism. You should then be able to position the knife arm back into the mechanism (two pins on the cutter mechanism that insert in a hole in each actuating arm).
Apr 11, 2014 | Husqvarna Viking 1
Missing the extension table that attaches to the base. Where might I find a replacement?
try ebay or a local Husquvarna dealer may be able to order one in.
There is probably also a Husquvarna user's newsgroup in Yahoo that might give you a lead on one.
Feb 26, 2011 | Husqvarna Huskystar 207 Sewing Machine
I took my Viking Husquvarna Sewing Machine (Model 5605 Rose) apart and cannot figure out how to put the clip back in on the inside. I need a photo of the internal schematics for the machine.
I just got a Husquvarna Viking, Rose machine, i do not know how old it is, but i can't find the model number, and i wuld also like to see how the bobbin case should look.
thank you, Graci
Mar 27, 2010 | Husqvarna Rose
I need an instruction manual for a Husquvarna 910
https://www.2instructions.com/search.php?...HUSQVARNA...HUSKYLOCK%20SERGER%20910
copy and paste this link in your address bar to bring you to your manual site.
Let me know if you need more info
Sep 03, 2009 | Sewing Machines
I took the bobbin assembly out and then the gears.
search sewing machine manuals online, some of the vendors sell service manuals, especially to older machines.
Mar 19, 2009 | Husqvarna Viking 1
Jamome RX 18S - feed dog problem
Janome feed dogs do not go back up until the handwheel has turned one complete revolution. Put the lever in the correct position and rotate the handwheel to see if they will rise. If not, they may be gummy from lack of use. This means the oil in your machine has turned into a sticky mess which doesn't allow the feed dogs to rise. If this is the case, you need to spray the lower parts with ammonia and water, let it sit for awhile , then work them up and down by hand until they are free again.
Sewman7
Jun 11, 2008 | Sewing Machines
Sewing Machines Logo
21 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
