Question about Cuisinart CPT-140 Cool Touch 4-Slice Toaster
Lever on taoster will not stay down
The right side facing lever will not stay down. when i hold the lever down, there is no heat generating from the elements.  I have disassembled the unit but am not sure what i should be looking for.
  • 10 more comments
  • colpas1 Dec 05, 2007
    I have the Toastmaster 4 slice. TMT4CAN The right side will not stay down when pushed, also no heat is generated on that side if held down manually. It seems to be an electrical (magnetic) device that holds the 'toast' down. The left side works fine when plugged in - but does not stay down when unplugged.
    Is there a fuse? I have the screws out of the base - but cannot get the unit apart.
  • Anonymous Dec 07, 2007
    hi , My lever doesn't stay down in order for the toaster elements to heat up. What do I do? I have a tef deluxe 2 slice. thanks
  • Janice McCort
    Janice McCort Dec 10, 2007
    Brand new toaster, have had it for a week. The right side lever
    does not stay down although it does heat. Everything else works
    fine. Is there an easy fix or should it go in to repair?
  • Anonymous Dec 18, 2007
    I have a sunbeam 2-slice toaster model 6225-26 and I have to hold
    the level down so the toast will toast,It will not lock when I press it down.
    The elements are working when I do this.
    Any ideas what the problem is.
  • phoebe Hursey Mar 08, 2008
    the right side facing lever will not stay down. when i hold the lever down, there is no heat generating from the elements. I have disassembled the unit but am not sure what i should be looking for.
  • rustface Mar 16, 2008
    Same problem, right side won't stay down. I took mine apart. Cleaned all the contacts I coudl find, but not it. This is an issue with getting a little electromagnet/servo thing to engage at the proper moment. I am really kicking myself for buying an overengineered toaster.
  • 2 scoops Mar 21, 2008
    lever will not stay down on one side
  • rovinrev Apr 05, 2008
    I cannot get the lever to stay down unless I hold it. It heats fine. I have cleaned it and also touched up the points but it does not hold.
  • Anonymous Apr 06, 2008
  • torchwood76 Apr 14, 2008
    I have this problem with the left side of my Krups Toast Supreme IV. When the lever was depressed, it would not stay down, and when held down, there was no heat generated.
    I opened it up and noticed that the shaft of the plastic "catch" (for lack of knowing the actual part name) had broken. The "catch" is a plastic piece that captures a plastic knob when the lever is pressed down. When the knob enters the catch, the catch pivots between two pieces of copper and completes the circuit, thus allowing electricity to flow to the toasting wires. With the piece broken, the parts are no longer aligned, the circuit is no longer completed, and thus the electromagnet doesn't engage to hold the lever down (and send electricity to the toasting wires as well).
    I am attempting to glue this piece back together, but I am not expecting it to last long since the part has already been compromised. After four years of faithful service, it is probably time for a new toaster.
  • squirrelia Jul 27, 2008
    I have the same problem but with both sides. The problem cropped up just after re-arranging all of my counter-top appliances. My guess is that there is a large chunk of hard bread that is blocking both carriages from going far enough down to latch. First problem though: I can't figure out how to get the cover off. It seems like the levers have to come off, but they don't seem to want to.
  • rustface Oct 26, 2008
    I think what has happened to toasters (over-engineered junk with useless buttons and electronic "features") constitutes a crime. Two of the four slots don't work.
    I mean how many people, in their regular job, can cut their productivity by 50% and remain employed?
    How many of you would accept a saw that was missing every other tooth?
    What about headphones where the left speaker failed in 2 months?
    Cuisinart doesn't seem to mind if their manufacturers and designers produce 50% functional toasters, though.
    I wonder if the Cuisinart executives would accept such junk in their own kitchens?
    And by the way, I'm sure most toasters share essentially the same electro-mech guts. It's certainly not limited to Cuisinart, at this price point.
Black & Decker T4050 OptiToast 4-Slice and it will not stay down and heat either. However you can hold it down and then it will heat. I apparently has an electromagnet that is supposed to hold it down and it's not working. Any Suggestions?
Posted on Dec 26, 2007
On my CPT-140 the two slots on the right would not stay down, but it would heat up if you held the lever down. Well i took it open and looked at it a bit, there it a ciruit board on the inside of the face near the levers, if you look down near the bottom of this you will see a little white plastic hook.. at the top of this should be a plug with three wires .. on my toaster this plug was NOT plugged into this white plastic hook part thing. I plugged it in and now it works fine. Hope this helps someone else
Posted on Jul 01, 2009
  • tara newton Nov 24, 2012
    This was so helpful ,another item saved from the landfill
I had an identical problem and did exactly what another reader suggested by completely cleaning the crumb trays and shaking any crumbs out that were present. Both of the latches remained down and the heating element resume working again. I feel like calling the Cuisinart rep back and informing her since her only suggestion at my request of any trouble shooting solutions was to buy another toaster since it appears I had a good 4 years out of it. My response was that bought it because of the name and expected it to last more than 4 years fell on deaf ears. Nice....
Posted on Aug 08, 2010
    Welcome Back:
    Visited the website for 2 consecutive days.
I found out something that surprised me once I pried the cover off my toaster: The toast carriage is held down by an electro-magnet, not by any type of physical clasp or hook. I looked at *so* many websites and consulted a coupld of hard-bound fix-it books, and neve anywhere did any article mention this unusual approach to holding the toast carriage down.
Long story short: the real problem with my toaster was that when I moved it, I plugged it into an outlet that turns out to be faulty. Thus the electro-magnet did not work, so the heating element could not heat. Once I plugged it into a different, working, outlet, the toaster worked just fine (except that I broke a thing or two prying the cover off -- oops!)
Hope this helps!
Posted on Oct 24, 2008
Disassemble (carefully) trying not to bend tabs
holding it together as it makes it harder to put back together, try taking only one side off first. When the lever comes down it contacts a small magnet and below that there are two bronze colored tabs, clean both contacts,being carefull not to bend anything,with contact cleaner(sold at electronics stores) sprayed on a q tip and let dry a few minutes then test before re assembly
worked on my toastmaster TMT
Posted on Nov 02, 2010
I had a similar problem with my Toastmaster Model Number TT2CTBB, 2 slice toaster. After disassembly I found one of the two copper spring contacts had come loose from the circuit board. I was able to reattach the spring contact to the circuit board using a very small screw which fit through the attaching end of the spring contact and a nut.I drilled a clearance hole through the circuit board where the spring contact had been attached. I did have to grind a small flat on the head of the screw.This allowed for clearance between head and the bend in contact spring, which let contact spring work properly.
Oh by the way, lever is held down by an eectromagnet. No working contact switch, no AC current, no magnet. Upon reassembly of cover, etc after reattach of contact spring switch with screw and nut, toaster works great!
Posted on Nov 26, 2007
I had the same problem.
I removed the crumb tray and put it back in.
problem solved
Posted on Nov 03, 2007
  • 709 Answers
Hi Moana,
You should see Electrical contacts near the lever.  Clean between where the metal of tghe Electrical contact meet each other.   The Toaster bread trays slide up and down on a metal rod.  On one side the assembly that slides on the rod, you should see a "L" shaped piece of metal that hangs.  This "L" shaped piece is suppose to Catch and hold the bread in the toaster.  Good luck....
Posted on Oct 30, 2007
2 Suggested Answers
SOURCE: Lever on taoster will not stay down
I would just buy a new toaster...they are not that expensive. Check the intruction book first because maybe it's under warranty. Or if you bought it very recently, just take it back to the store. Most places will take it back even without a reciept if you tell them you just bought it and it's already broken.
Posted on Nov 22, 2008
932 ariens shuts engine down as clutch is engaged to throw snow
Your problem would be in a safety shutdown switch.
some Ariens blowers have a two handed safety switch whitch is located on back of blower right lower side (inside of body)
You have to remove 4 transmission pan bolts to see it.
The other location is under the metal face plate between the handle bars.
Some of them have a third handel on right side of handle bars that has to be depressed to run auger .
Mar 01, 2014 | Ariens Garden
Auger clutch lever disengages even though drive clutch lever is squeezed
On mine (Honda HS55) it turned out to be gummy old grease on the shaft and the lever that are supposed to lock the auger lever down. The spring couldn't overpower the sticky old grease. If nudged or given enough time, it would slowly turn and lock, but not instantaneously, as it should.
10 mm wrench to remove the nut (bottom left) and bolt (under handle) holding on the metal cover.
Once cover was off I could see the locking lever, spring, and the shaft that had the gummy grease on it.
The third photo shows the locking lever as it should be engaged. I had to push it to engage it, due to the spring not being strong enough for the gummy grease on the shaft.
There are flat sides on the shaft, behind the threads for the nut that has already been removed. Use a wrench on those to turn the shaft out. Disassemble. Clean. Oil. Reassemble. Works great now.
Another possibility is that your locking lever or spring are broken.
Dec 17, 2013 | Honda Snowblower Cover Silver Hs928,...
Brake light stays on all the time
There are two brake light switches on your bike. One for the front brake and it's located in the right handlebar switch housing and a pressure switch that is usually underneath the bike somewhere for the rear brake. You can find the rear brake light switch by following the metal brake line that comes out of the rear brake master cylinder until you come to a switch with some wires on it. On the older bikes, you could unplug the wires to see which switch was holding the light on. If the brake light goes off when you unplug the wires, it's this pressure switch that has the light held on. If the light stays on, it is the front brake light switch. On your bike, check for looseness in the front brake lever. If the lever and pin are worn, this will cause the lever to not depress the switch in the side of the switch housing facing the front brake lever. Your front brake switch may be broken. Odds are that the front brake switch is the one causing the problem.
Good Luck
Jul 24, 2011 | 1993 Harley Davidson FLSTF Fat boy
How to thread a Frister and Rossman 35
Presser foot up, takeup lever at the top, thread on the top spool pin, take the thread to the left and over the top guide, straight down the right hand side of the tension and go round it making sure the thread goes between the discs, up the left hand side to the takeup lever, thread the takeup lever right to left, take the thread all the way down to the needle going through any guides on the way, thread the needle left to right, make sure the flat side of the needle is facing right.
Mar 22, 2010 | Sewing Machines
I need a threading diagram singer 329k sewing machine
Cotton omn the reel pin, take the thread from the right to the left and through the top cotton guide above the takeup lever, make sure the takeup lever is at the top and make sure the presser foot is up, take the thread down the right hand side, round the tension unit and back up the left hand side to the takeup lever, right to left through the takeup lever and then follow the guides all the way down to the needle and thread front to back, flat side of the needle must face back.
when you put the bobbin in, bobbin in your left hand and the thread must feed from the bottom of the bobbin, drop the bobbin, through the groove and lay the thread to the back.
Feb 12, 2010 | Singer Sewing Machines
Opening side panel of acer aspire t180
You have done half the work toward the solution by removing the thumbscrews. The other half involves sliding a spring-loaded lever above the lower thumbscrew toward the bottom of the case. While the lever is slid toward the case bottom, push on the side panel in the same direction as the screws, i.e. toward the rear of the case. The side panel should slide just slightly, allowing you to then lift it off to access the inside. Note that when replacing the side panel, follow the above steps in reverse order.
When replacing the side panel, note that if the panel is not correctly replaced, the thumbscrews will not be able to be installed as the lock lever will not be set properly.
Jan 23, 2009 | Acer Aspire™ T180 PC Desktop
Daisy wheel will not stay on wordsmith 100
CHANGING Changing The Ribbon Cassette 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette. 3) To insert a new cassette, place the back end of the cassette on the cassette holder on the carrier and gently press down on the front of the cassette unit it clicks into place. 4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon. 5) Presss the CODE + = (SETTING) key.
Changing The Print Wheel 1) Move the print carrier to the center of the platen using the SPACE or BS key. 2) You will see a lever on the right side of the carrier. Pull this lever toward you and lift out the daisy wheel. 3) Place the daisy wheel into the slot with the characters facing the platen. 4) Push the lever back into position. 5) Press the CODE + = (SETTING) key.
It appears as though you have something that is preventing the print wheel from being locked in place by the release lever. It should make a snapping or similar noise when it is locked down.
Dec 10, 2008 | Smith Corona Wordsmith 100 Typewriter
Nov 22, 2008 | Kitchen Appliances - Others
Vintage toastmaster toaster
you will need to adjust the heat switch to a hotter temp. then pull it down. its the slider arm located below the lever.
Jul 07, 2008 | Kitchen Appliances - Others
Lever won't stay down Breville CT20
hi sounds like the problem is the holding down mechanizem clean the toaster well find that spring which caches the lever down you can find it on the external lever side pretty small and simple thing when you push down the external lever the spring kick a little lever which holds the slide in place for heatup only when you will hear a "click" then you'll know its in place and then the electric cicuit will be close and engage the coils to heatup good luck
Mar 30, 2006 | Breville CT20 Retro Classic 2-Slice...
Cuisinart CPT-140 Cool Touch 4-Slice Toaster Logo
6,332 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
