Question about Car Audio & Video
Hi i have a pioneer cd player that i am trying to install it
Hi i have a pioneer cd player that i am trying to install but i cant figer out wat wires go were can u help me at all
    President:
  • 1,114 Answers
You didn't list the model #. However, if you go to www.pioneerelectronics.com click on support then car audio, find your model # and you can download the manual for the unit which will give you the diagram you need. Hope this helps
Posted on Jun 14, 2009
  • 93 Answers
Pioneer follows the universal after-market color code, so if your CD player was made in the last ten years or so, the wires should go like this:
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
We cant find the power cable in our rover 420 sdi to re-wire a new stereo..the blocks have been cut off the stereo we brought so no clue as to wats wat and no wire diagram on top of stereo
If its a aftermarket stereo, the red wire is ignition, yellow wire is constant 12 volts, & black wire is ground. The speaker wires should be purple + & purple w/ black stripe - / white + & white w/ black stripe - / green + & w/ black stripe - / gray + w/ black stripe - /....then blue is for power antenna. Thats most aftermarket radios, some have orange for a dimmer but it depends on the brand.
Mar 28, 2010 | Pioneer DEH-P6600 CD Player
Installation wiring diagram??
No need to guess what wires go where. Buy a wiring harness for your specific year, make and model.
You make connections from your pioneer harness which are all marked, to the Harness you will purchase for your car. They cost about $20 and can be purchased at most autopart stores, or major electronic retailers.
Once you make the connections from the pioneer harness to the harness specific for your car, simply unplug your factory radio and plug in your newly wired one.
Jan 25, 2010 | Pioneer DEH-2300 CD Player
Installin used headunit in 97blazer dnt know wat wires go where?
you need wiring harness for your truck to the radio go to your local bestbuy or car audio shop then follow color coded instructions for the wiring
Aug 13, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Trying to install a new pioneer radio to a 1999 jeep
try walmart they have the wiring harness that you need to install your radio for about 6 dollars
Aug 10, 2009 | Pioneer DEH-1100 CD Player
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
I cant get power is my harness missing wires?
Yes, your red wire is for ignition, yellow wire is for battery and black is ground. The red ignition wire is for the radio to turn off and on with the ignition. The yellow is always hot, for memory.
Dec 29, 2008 | Pioneer DEH-P2900MP CD Receiver...
Pioneer car stereo instalation
if they are all positive speaker wires then each speaker will get a positive and the other speaker wire goes to the ground of the ground wire
Oct 12, 2008 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Car stereo
Goto www.installdr.com They have all wire diagrams for all cars. Next time, don't cut the car harness. Go get a snap in wire harness.
Jun 15, 2008 | Pioneer DEH-P2000 CD Player
Cuttinng out
Does it cut out when you are listening to the tuner as well as the cd player? If so, you have a bad connection somewhere. Sometimes the solder joints inside the radio can be cracked and will cut out when you hit bumps. May be a wire that is a little loose. Check all the wiring.
If it only cuts out when you are listening to the CD player, you may need the lens cleaned or the laser replaced. Sometimes the cd player cuts out because the unit has too much wiggle room and it bounces a little when you hit a bump causing the cd to skip or cut out. and there is always the dirty CD. Try cleaning the CD's with windex and a soft cloth like a bath towel. It works great for me and is cheap. Fingerprints can and will cause a cd player to skip.
Jun 07, 2008 | Pioneer DEH-P6800MP CD Player
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
