Question about Linksys Wireless-G WRT54G Router
Linksys wrt54g router won't broadcast my wireless internet!!!
I have tried everything possible.  My wireless network will not show up!!! Like it doesn't even exist! Sooo frustrating!  Please help... my modem is made by WireSpeed and it connects with a DSL hook up.  I went through the whole router setup process, however nothing seems to work.
    Champion:
  • 381 Answers
Find the back of router a small hole/pin then reset the booton then a 15seconds go go back normal the router.good luck
Posted on Jun 14, 2009
Find ssid number for linksys model wrt54g
SID broadcast allows computers to quickly locate a new network and connect to it. In wireless home networks computers often use only the home network, which makes SSID broadcast unnecessary. Disabling SSID broadcast adds a bit of security to your wireless network, because computers won't be able to see your network's SSID.
Log into the router.
  1. Open your webbrowser and type http://192.168.1.1 in the address bar. This is the default IP address of the browser.
  2. Type your login info in the login screen. Default: 'admin' (without quotes) in both fields.
  3. Go to Wireless > Basic Wireless Settings 'wireless
  4. Set SSID broadcast to 'disable'.
  5. Click Save Settings.
On the next page you will set a router password to prevent unwanted visitors from accessing your router setup.
Sep 23, 2011 | Linksys Wireless-G WRT54G Router
How to set my router have a internet connection,because my router is local only
Are You just Trying to Broadcast just for your house? If so follow the Giant booklet linksys gives you and just encrypt your network!
May 05, 2011 | Linksys Wireless-G WRT54G Router
When connecting to internet on laptop, the connections which I have set us to automatically connect do not show up in the list of wireless connections available. I have a linksys wireless connection...
If your connecting WIRELESSLY--the a network cable would be unplugged because your wireless not wired---
and if your not seeing the router on the laptop check the router settings to broadcast the signal
Jan 13, 2011 | Linksys Wireless-G WRT54G Router
I have a Cannon MX860 printer that is set up for wireless. My linksys wrt54g router is also configured for wireless - I can access the internet wirelessly from my mac but the router will not acknowledge...
You need to scan and view available wireless network in printer select your home network (linksys).
Once the printer is ready to go, plug it in and power it on. There should be an interactive set up screen on the printer that you can use to indicate the appropriate wireless settings. You'll want to use the same security settings on the printer that you have set on your wireless router. I recommend using the WEP settings so you are not broadcasting any of your documents or online activity the neighborhood.
Jun 02, 2010 | Linksys Wireless-G WRT54G Router
The DNS error on my PS3 from LINKSYS
your wireless network should be configured to NOT broadcast the SID and a WEP key. Then after entering the address of the router manually in the network setup on the PS3, you will able to obtain an ip address from the router
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Can"t get wirerless to pick up from router
  1. can your laptop connect to other wireless networks? if not, the laptop's wireless may be the issue.
  2. if yes, it's possible that the router has the wireless functions turned off, or is set to not broadcast it's SSID (network name). Check these settings, or just press and hold the reset button until the power led goes out. After resetting the router to factory settings, it should broadcast the name "Linksys'. If still no good, it's likely that you have a defective router.
  3. As a last resort, plug an ethernet cable directly from your pc to the router and see if you get an ip address and can get to the web. If this works, log into the routers web interface by typing in 192.168.1.1 in the address field ofyour web browser and look at the wireless settings.
  4. If nothing still, contact linksys......let me know if I can provide any other suggestions.
Aug 08, 2009 | Linksys Wireless-G WRT54G Router
Dhcp error using linksys wireless g wrt54g router to comcast
Try to call linksys and they will guide you through trobleshooting steps
Jun 15, 2009 | Linksys Wireless-G WRT54G Router
Using Linksys WRT54G as router connected to ActionTec with FIOS
You must keep everything on the same subnet. Only allow the router to be DHCP and keep everything on 192.168.1.x subnet. You are going to have alot of problems talking across subnets
Jan 15, 2009 | Linksys Wireless-G WRT54G Router
SMC EZ Connect 2862W-G does not see Linksys network
It shows that your wireless router and wireless adapters are both working. One thing to try is changing your wireless channel. Since you are already using 11, try maybe 1 or 9. Check if your SMC adapter will pick up the wireless signal.
By the way, how far is your computer (using the SMC adapter) to your wireless router?
Oct 21, 2008 | SMC EZ Connect g SMC2862W-G 802.11g/b...
Linksys Wireless-G WRT54G Router Logo
1,316 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
