Question about HP Compaq Presario SR1810NX PC Desktop
My compaq sr181nx diplay monitor is now blurry
My compaq sr181nx diplay monitor is now blurry with wavy lines could this possibly be a faulty video card?
thank you in advance for your reply.
This could be a faulty monitor. Trying plugging in a different monitor to the computer.. If you continue to have the same problem with the second monitor, then it is your video card or on board video that is going out. If the video is fine after you tried the second monitor, then you need to get a different monitor for your system.
Posted on Jun 14, 2009
Computer starts but no diplay shuts down immediate,
Is the power LED on the monitor ON, if not check the power cable connection at the monitor and at the mains.
Check the video cable connection at the PC.
Try a different working monitor on your PC and see if the monitor works on a different PC (the monitor maybe faulty).
Nov 17, 2012 | E-Machines T Computers & Internet
Signal outof range
  • Make sure the pins on the video cable are not bent or damaged.
  • Make sure there are no extension cables or switch boxes attached to the monitor.
  • Verify that you have the proper drivers installed for the video card.
  • Verify the problem at all possible resolutions and refresh rates.
  • Make sure the refresh rate does not exceed maximum value for any resolution.
  • Test the monitor on a different computer.
  • Contrast is recommended to be set at a higher range while the brightness should be set at middle range. This helps to increase the text clarity while reducing the bright background.
  • If your monitor is equipped with moire control, adjusting this may improve the clarity of the text. Moire is a wavy distortion pattern caused by interference between the dot pitch of the CRT and the picture signal. The pattern may vary depending on the screen amplitude, contrast, brightness, and other characteristics of the input signal.
  • Monitor's performance may be affected by the Earth's magnetic field. Try rotating the monitor to different directions to improve misconvergence.
  • Most video cards offer a software utility that changes the frequencies and sync polarities for all resolutions. If the setup does not match with the monitor's characteristics, an incorrect signal may be displayed on the screen. Sometimes, the image may also appear blurry.
  • Aug 08, 2010 | Compaq TFT8020 18.1" Flat Panel LCD...
    My monitor is blurry / wavy. I tried connecting another PC to the monitor and it is still like that. I also replaced the cable but that didn't do anything either.
    It sounds like a power supply problem either with the power pack or inside the LCD display.
    Ring the Acer support line for your country and thy will advise on how to get it repaired locally.
    see www.acer.com
    It is not an easy job!
    Mar 07, 2010 | Acer AL1716 17" LCD Monitor
    Is this a MS-7184 problem? My son's computer has a wavy screen, so I replaced the CRT monitor with a new flat screen. Still wavy. Next, I replaced the onboard video card with a PCI card and nothing shows...
    you need to install drivers with the new video card but first you must uninstall the old one-definately a driver issue(assuming all cables are good,etc)
    Sep 15, 2009 | HP Compaq Presario SR1620NX...
    Compaq Presario sr1720nx has wavy video. You can see everything okay it's just that the video is wavy and kinda taxing on your eyes. It does this with every monitor I hook it up to. I've also tried a...
    Is it wavy all the time or just when windows is booted up? Try booting up in low res mode or safe mode and see if the problem continues. What is the monitor refresh rate set at? Try lowering the refersh rate. The on board video/video card may be going bad. Lowering the refresh rate may reduce the wavy picture. If it has a video card you could try installing a different card. If it has onboard video try installing a video card. Make sure you drivers are up to date.
    Sep 08, 2009 | Compaq Computers & Internet
    Hp pavilion motherboard problem
    Try to open the display and put out and in again the diplay cable.Maybe its a faulty contact of the display cable.It has happend to me.
    Apr 13, 2009 | HP Pavilion dv9000z Notebook
    Vertical Wavy lines moving upward in my monitor
    i think you have a faulty Fly Back Transformer { FBT / EHT }.
    Mar 09, 2008 | Gateway FPD2275W LCD Monitor
    Blurry and wavy monitor
    if the unit is onboard video card, try to install a new video card.
    Mar 06, 2008 | E-Machines eMachines Desktop PC
    Wavy lines, goes black during video games.
    It sounds to me like the monitor's refresh rate is too low to support your current settings, and the demands of the game. Have you tried adjusting the refresh rate? If I'm right, you should be able to fix the wavy lines that way. I'm not sure how much control over the refresh rate the game takes, but if you can fix the wavy lines and the game still doesn't work, I think you're not likely to get the game to work on this monitor.
    Aug 28, 2007 | Proview PL926WBi 19" LCD Monitor
    Computers & Internet Logo
    180 people viewed this question
    Top HP Computers & Internet Experts
    pontelemon
    pontelemon
    Alun Cox
    Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
