Question about Acer Aspire 4315 Notebook
Battery problem hello sir, the problem is i've setup xp but since then the laptop's working when it's connected to charger but it's not turning on when not connected to charger.also there's no icon of battery in the toolbar.
  • Acer Master
  • 32,281 Answers
You could have a faulty charging circuit or a faulty battery. Recharagable batteries have a finite amount of charge and discharge cycles and their capacity also diminishes over time especially if the battery is more than 2 years old. Test the battery in another laptop, if you get the same results then the battery needs replacing.
Posted on Jun 14, 2009
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Dear sir i'm unable to install xp on my compaq presari cq57. setup don't detect hard disk.. i'm facing blue screen error please help me..
hello,
  • Turn off the laptop.
  • Unplug from power if connected
  • Disconnect the hard disk power supply and re-connect after a while.
  • Now start the PC and run set up.
thanks!
Sep 24, 2011 | Computers & Internet
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Hi sir i have lenovo 3000 y410, i face problem is that my laptop did not charged during power on condition ,but it's only charge in power off condition. So, pls solve my problem.
Hello Maitrikshah1,
I propose two solutions:-
1) Try to use any other charger and see what happens
2) Try to use the second battery and see what happens
3) Unplug the battery and connect the charger and see what happens.
Please update with your findings!
WIth regards
Pankaj
Sep 22, 2010 | Lenovo 3000 Y410 Notebook
Battery Not Identified.
hello
I suggest you a few steps to solve your problem.
  • remove the charger and press the power button till all residue power is radiated.
  • then connect the charger and charge the battery fully and try booting the system.
  • if this don't work check the output of your charger and see if it is working fine.
  • if it is working fine then remove the battery and connect the charger and try starting the system.
  • if it works then there are two things possible.
  1. battery gone.
  2. IC responsible for charging is gone.
i hope you can figure out the problem through this.
Thank you
Aug 07, 2009 | Dell Inspiron 1525 Laptop
Laptop is not working
remove the battery fact the connect the charger direct, then turn on you laptop if the same problem.. check the baord where comes out the sond,, check the ram ro boar
Jun 26, 2009 | Computers & Internet
Acer Aspire 3000 notebook works, but cpu does not recognize battery connection
Hello sir  please tell me doest your charger contain two parts like 1- Plug to charger box
2- Charger box to computer
tell when u fiddle the switch did you get any reponse...if yes then their is looose connectivity ....hope it is helpful or you notify me first did you get any reponse then we can move further
regards golu_fixiya
May 05, 2009 | Acer Aspire 3000 Notebook
Acer Aspire 4315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
