Question about Intel D101GGC Motherboard
Motherboard welcome screen is not visible... OS loading problem and after several effort setup screen is not coming and  message flashed that Disk Boot failure insert disk. When tries several times Intel welcome screen not coming and current is also tripping right now and from few days system is getting restarted .
You have been caught by bios virus try to update your bios and then try to load windows it will work
Posted on Nov 01, 2007
How to boot with usb flash drive. detailed please, I'm trying to many diff ways nothing working, bios is the only thing on comp.
It is possible to boot from a USB drive....but only if the USB drive has been formatted as bootable, in the same way that OS CDs and DVDs are bootable media. You have to have an operating system either on the hard drive or on the flash drive in order to boot the computer. The BIOS is simply a "Basic Input-Output System" that interfaces the computer hardware to the OS, whatever media it is on. That is why you have to select the boot device and the boot device priority in the BIOS during setup, so it can direct itself to the bootable OS. Once you have installed an OS, then all will work fine. Until then, you will continue to have issues. Normally, with Window-based systems (you don't say what OS you are trying to use), you would insert the bootable Windows setup disk in the CD/DVD drive, ensure the BIOS was set to boot to CD/DVD first, and start the computer. The windows setup file would load itself and start the OS install process. It may even be necessary to partition and format the hard drive during this evolution, but the setup program would lead you through that as well. I have seen Windows setup files loaded to USB sticks, but they require a special process to generate so the BIOS sees the USB as bootable.
Jun 26, 2015 | ASUS Computers & Internet
I got a grey screen flashing a folder and other symbols on my IMAC OS X 10.5
Hi joe_shadowla, this means the Operating System has trouble finding the startup disk and the OS needs to be reinstalled. You need to have your OS X Install Disk equivalent to 10.5 or higher:
1) Insert the disk and wait for it to load to the Welcome screen
2) On the menu bar go to tools and click on Disk Utility
3) Click on your Hard Drive on the right and click on the Erase tab
4) Make sure it say (Mac OS X Extended-Journaled
5) Erase the Disk and Exit
6) Proceed with the installation and follow the onscreen instructions.
Mar 05, 2013 | Apple Mac OS X 10.0.3 Operating System &...
When I turned on my PC this morning, I saw as the bios info screen loaded then the screen went black. Then when a new screen loaded, it flashed the screen, then went black again. Any idea what the problem...
Probably a problem with the OS itself. I would recommend putting in your OS cd (the one that came with the computer. And restart, select the option to repair OS (or says something to that effect). This may fix the problem. If it does not try another monitor, see if it is monitor specific (I dont think so, it sounds like it is an OS problem)
Mar 05, 2011 | LG W2252TQ Monitor
Dfi-64 tc problems. i just to install xp (before was windows millenium )now each time when xp load appears a message saying that bus ide drivers does not installed but when i run the drivers disc...
when a person goes install windows xp they encounter the problem of not being able to find any hard disk drives installed as if they weren't connected. The hard drive is detected with no problem in the BIOS and also on start up POST, able to boot up Linux Live CDs but the hard drive is just not being detected in Windows setup. Here is the exact error message.
Setup did not find any hard disk drives installed in your computer.
Make sure any hard disk drives are powered on and properly connected to your computer, and that any disk-related hardware configuration is correct. This may involve running a manufacturer-supplied diagnostic or setup program.
Setup cannot continue. To quit Setup, press F3.This problem is quite a common one and is simply due to the fact that when Windows XP was created, the SATA chipset itself and SATA hard drives weren't available to the masses, so support for it wasn't included in the XP setup process. As most computers within the last decade or so have some form of SATA controller, if you try to install Windows onto a SATA drive, XP won't recognize it because the drivers aren't present on the installation disc, so they need to be loaded manually for the drive to be picked up.
Thankfully there are a few ways to get around this problem and enable Windows XP to be installed onto a SATA hard drive so you can enjoy the extra performance and other functions like hotplug/AHCI etc. Setting the BIOS Correctly
The first and mos obvious method is to change the SATA Mode to IDE in the system BIOS. Most BIOS's for several years have included a fallback mode to enable a SATA drive to behave like an IDE drive, and therefore makes it visible to XP during setup. The problem with this setting is it comes under several different names and can be found in different sections within the BIOS. It depends entirely on the computer or motherboard's make, model and manufacturer to know which setting you have and where it is. If you have a manual, it's certainly worth reading.
The most obvious thing to look for is a setting which can change the SATA controller to IDE or PATA mode, with options such as AHCI -> IDE or SATA/RAID -> IDE etc. Basically any option you come across to reduce the SATA/RAID mode to IDE/PATA should be the correct one. Don't confuse this option with a similar one which will disable the SATA controller completely. Here's some names we found it could be under in a few motherboard manuals we looked at:
Integrated Peripherals > SATA Devices Configuration > SATA Mode > [IDE]
Integrated Peripherals > Serial ATA Function > Base
Storage Configuration > SATA Mode Selection > Emulated PATA Mode
SATA Configuration > SATA Configuration [Enhanced] > Configure SATA as > IDE
Integrated Peripherals > South OnChip PCI Device > SATA Controller > IDE Mode
Using a Floppy Disk
If you're unable to change RAID mode to IDE or disable SATA in the BIOS, then the next option would be to download SATA/RAID drivers from your motherboard manufacturer's website, extract the drivers to a floppy disk and then insert the floppy into your computer during Windows XP installation. This method obviously gets around the problem of XP not having the drivers on the install CD by you providing them manually.
Windows XP setup won't recognize USB flash drives, so you need to have an internal floppy drive available, many USB floppy drives will also work though. As you can see in the image below, it clearly states that the SATA RAID driver is for use on floppy drives. You need to make sure any drivers you download are explicitly designed for putting onto a floppy and not a generic driver, usually the file will be around 1MB or lower which is a good sign it's likely to be the correct driver.
Insert the Windows XP CD and boot it up. You should see a message that says "Press any key to boot from CD..." Simply hit any key and it'll start to boot from CD. Pay attention to the next blue colored windows setup screen. When you see a message that says "Press F6 if you need to install a third party SCSI or RAID driver..." at the bottom, immediately hit the F6 key.
After loading some files, you will come to a screen that says the following:
Setup could not determine the type of one or more mass storage devices installed in your system, or you have chosen to manually specify an adapter. Currently, Setup will load support for the following mass storage devices(s):
< none >
* To specify additional SCSI adapters, CD-ROM drives, or special disk controllers for use with Windows, including those for which you have a device support disk from a mass storage device manufacturer, press S.
* If you do not have any device support disks from a mass storage device manufacturer, or do not want to specify additional mass storage devices for use with Windows, press ENTER.Make sure the driver floppy is inserted and press S. It will present a list of drivers which it read from the disk earlier. Select the appropriate driver and continue the Windows XP installation. The setup will continue and this time it will recognize the SATA hard disk drive in your PC. This problem is quite common when trying to install Windows XP on newer computers because most if not all are using SATA hard drives. After installing Windows XP, you can easily and automatically install all required device drivers using the DriverPack Solution disc.
If you thought it wasn't possible to use a USB flash drive instead of a floppy drive to load the drivers during the F6 phase, we have a solution that could !!!
Oct 04, 2017 | DFI CA64-TC Via 694T/686B Mainboard...
It went to welcome screen and after i typed in my password, got a black screen that says insert disk and press F1 or press F2 and something about setup.
This happens whenever one closes any installation prematurely. Insert the disk then properly cancel or complete the setup and restart the computer you wont get this message.
Jun 22, 2010 | Dell Dimension 2350 PC Desktop
Trying to load xp os. setup runs but after
May be problem on RAM or HDD you can change any one or fix it.
Mar 15, 2010 | Gigabyte GA-G41M-ES2L Motherboard
PATA boot problem
Did you set the boot options to boot from the PATA drive? Did you set the port mode to legacy IDE? Did you try to let the BIOS determine the type of drive?
Jul 02, 2009 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
Do not choose the option to press R to use the Recovery Console.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Os loading
go to the bios , change the hard disk support from native to legacy
Oct 31, 2008 | Compaq Presario Notebook
Motherboard welcome screen is not visible on booting and pmain problem is after installation an OS it is not accessible
There is a problem with your hard drive. Either it is faulty and cannot be accessed or it is not in your BIOS boot sequence.
When it is starting, go into the bios settings and verify that the first boot device is set to your hard drive. If it is and still does the problem, then your hard drive is faulty and needs replaced.
Oct 30, 2007 | Intel D101GGC Motherboard
Intel D101GGC Motherboard Logo
52 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
