Question about iLO 3200 32 in. LCD Television
Ilo Digital channel scan not working
I have an ILO 27" (not positive on the size of the TV) Digital/HD TV.  It was working great for us until I was doing a channel scan for new digital channels. It's worked before, but now it just scans up to channel 27 and then freezes us.  It goes no further.  I know there is a channel 16 and a channel 22 in our area, but it did not pick those up.  Now...when I can the Analog channels, it works no problem.  Digital channels however is a different story.  Now what?
  • 1 more comment
  • CHRISTALL3 Nov 01, 2008
    I PURCHASED A 22" DIGITAL TV. IT WORKED FINE FOR 2 MONTHS PICKING UP ALL MY BASIC CABLE AND LOCAL CHANNELS. NOW I CAN ONLY PICK UP 15 CHANNELS AND I HAVE USED AUTOSCAN BUT CANNOT GET ANY ADDITIONAL CHANNELS. COMCAST SAYS IT'S THE MANUFACTOR THE MANUFACTOR SAYS IT'S COMCAST.
  • Anonymous Dec 11, 2008
    I have the same problem with the ilo digital channel scan. Not certain what to do. I am open to any suggestions. Has anyone called the manufacturer?
  • Anonymous Jan 02, 2009
    Ilo 32" LCD will not scan for digital channels.
Benimur
  • 6966 Answers
SOURCE: ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Posted on Jul 31, 2007
  • 12 Answers
SOURCE: ilo lct27ha36
same thing happened to my ilo. There are four capacitors that are bad on the power board. You can usually tell its bad because at the top it bulges out. Here is what you need to do. Unplug the tv, open up your ilo find the power board ( the power cord plugs into it). Then find the capacitors that are bad (they are the around things usually in blue color) and remove them by soldering the other side. On mine there where three 1000uf 16v and one 470uf 35v. Those are the ones that need replacing. I replaced them with a higher voltage rating 1000uf 35v and 470uf 50v. All you need to do is solder them back on but make sure you solder them back the right way (plus goes to plus on the board or you will be in trouble). I found the capacitors at radio shack for about 1.50 a peice. If you dont know how to solder look it up on youtube. If that does not work there might be couple more bad capacitors that need replaceing just need to find them and you can tell by a small bulging top.
Posted on Apr 14, 2009
  • 3 Answers
SOURCE: 32in ILO LCD Hd TV
There is a capacitor that is out. It is a 470uf 25v. When you open the back and look at the power board there are three group together. It should be right there. You will be able to tell if the capactor top is bubbled replace it. It should be completely flat.
Posted on Jun 17, 2009
jwlevan
  • 77 Answers
SOURCE: ilo HD TV won't turn on
try another power cable (usually these tvs use the same power cords as a number of other electronics, such as desktop computers, etc) - if that doesn't work, try another power outlet - Also, try powering the tv on with the power cord out - this clears the static electricity off the system board, and helps w/ power issues sometimes - if still no power, then you can contact Wal Mart's customer service (since iLo is their in-house brand) @ 1-800-925-6278 to see if it's still under warranty or if they can put you in touch w/ an onsite technician.
Good luck - hope this helps!
Posted on Sep 13, 2009
SOURCE: ilo tv quit - will not turn on
The Problem is with the Capasiters in the power supply bord a total of 9 caps have to be replaced the power supply bord is the one on the right side of the tv in the back where the power cable enters the caps values are 35 volt 1000uf x2 35 volt 470uf x3 16 volt 1000uf x3 and 16 volt 470uf x1 after replaceing thses caps the tv will work like new... i hope this helps.
Posted on Sep 19, 2009
Digital channel 25 has no sound.
First make sure SAP or nothing similar is turned on.
After you triple check that just Contact ILO if it continues for more than 1month. This is a software error.
What state are you in?
What channel is this?NBC, ABC
Have you check this at different times of day?
What TV does your son have?
Jun 24, 2009 | iLO 2600 Television
Cannot get new digital signal to my ilo tv
I've done a little research and I don.t see where you have a ATSC tuner that receives the over the air digital signal. You have a basic Analog tuner. The only way you can receive digital is by a HD cable box by having cable or going to Satellite.
Jun 14, 2009 | iLO 3200 32 in. LCD Television
How do i manually add a digital channel to my tv? model: ILO-26HD
do u have the user manual for the TV? if you do the solution will be in there, if not (I suspect you don't) please give the make an model so I can try to look this up, but off the top of head there is no way to "assign channels" to a paticular remote setting.
Jul 28, 2009 | Televison & Video
Ilo DVD player/recorder
> jfthr - Tv convertor boxes transfer digital signals into ANALOG. So when it goes to the dvd recorder it IS ANALOG. I have my antenna hooked to my convertor box, the converter hooked up to the ILO (A/V connections) then, the output on the ILO to the input of my analog tv. (Video selection on my tv). It works great to watch tv and/or record. I switch to the "DVD SOURCE" to watch dvds. Maybe you have the conv box hooked to the tv then the outs on the tv to the dvd. That would explain why you can get a picture but not watch dvd? The ILO has to go between the box and the tv in order to watch dvd.
Aug 07, 2008 | iLO DVD Recorder DVDR05
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
ILO 26 HD
Hi! Yes, I am very familiar with the problem. I bought one of these - it was locked on channel 43, and I intended to repair it. However, I found the problem was not so simple and it took me 6 months of research to sort out the problem. I am now considering offering a rebuild service on the controller boards for these sets. You would have to be able to remove the controller and send it to me, or have a local TV shop remove it and send it for repair. Let me know if this is of interest.
Sep 22, 2007 | iLO 2600 Television
Ilo 27 inch hdmi/dvi hd tv monitor
Jul 31, 2007 | iLO V27DMBX Television
Ilo 27inch hdmi hd tv monitor
You would need to connect a VGA + Audio to HDMI Converter. The downsize it the converter goes for about $150 us
ILO universal remote code
I had the same problem trying to program my satellite remote to work with the ILO tv. I found that the emerson codes DO work. Yes local cable remotes will work as long as you have the code and the brand is getting more popular. The code that worked with both cable companys, Charter and DirecTv was 10171 I believe. You can find it under the Emerson codes. Hope this was helpful.
May 23, 2007 | iLO 3200 32 in. LCD Television
iLO 3200 32 in. LCD Television Logo
469 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jim Goldsmith
Jim Goldsmith
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
