Question about Ovens
I have a Frigidaire stove, model fgf316asa, and the oven does not heat. The ignitor still glows but does not ignite the gas. I cannot hear the gas coming from the line. What's wrong?
    President:
  • 1,136 Answers
Hi, You should change the ignitor. Even tho it glows, the ignitor is to weak to open the gas valve. UNPLUG the oven. Remove the floor panel in the oven and you sill be able to see the ignitor. This is very common with gas stoves.
I hope this helps you. Please let me know if I can assist you further.
Vic
Posted on Jun 14, 2009
  • Rickey Howard Nov 25, 2011
    Have the same problem with the same model oven Think I'm gonna trust you and order the ignitor but please explain how it could be "weak" if it glows bright orange/yellow, like a brand-new cigarette lighter in a car? And exactly where is the bi-metal strip that this "ignitor" pushes upon to physically open the gas valve (because it does not appear that the valve is electrically activated)?
Frigidaire gas oven not heating. The broiler and burners work but the lower burner will not ignite. I replaced the igniter however that did not fix the problem. In fact, the new igniter does not glow. I...
Check for volts to the new ignitor. The ignitor draws current which opens the gas valve. If it is not glowing it is not drawing power. Test the ignitor,disconnected, with an ohm meter, it should be under 200 ohms.
Dec 28, 2013 | Ovens
My oven will not work. the ignitor glows but no gas comes out. the stove works fine
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 28, 2011 | Frigidaire Ovens
On my GAS stove and broiler work fine but my OVEN does not light. I do not hear the pilot light or spell any gas. Where or how can I check
heatman101
Apr 29, 2011 | Frigidaire Ovens
I Have a Frigidaire Model FGF379WECR Gas Stove The oven will not start, no gas to the burner. the starter works because it glow's. What Part do i need to repair ?
Hi, Jus because it glows that does not mean it is not bad...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 11, 2010 | Ovens
Frigidaire oven will not ignite
heatman101
Jul 23, 2010 | Frigidaire Ovens
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Whirlpool stove model #st387peyn1 oven won't heat. Broiler does work.Ignitor glows and after a while you hear a poof like it lite, but it did not.
When the igniter is getting weak, it will glow but not get hot enough to fully open the gas valve. If the gas valve opens partially a small amount of gas comes through the burner and you may smell it and eventually it may ignite with a "poof" like you describe. I suspect you just need to replace that igniter.
Jan 08, 2010 | Ovens
Hello when i put my temp for my gas stove on say 350, the pilot is glowing but it doesnt seem to flame/heat up, and i get a somewhat odor of gas, could the therometer need replacing or maybe the ignition...
Your glowbar ignitor part must be replaced, Unplug the range and turn off the gas. Remove yje oven racks, The oven base pan. Then remove the flame spreader. You will see the glowbar ignitor attached to the side of the bake burner. Remove it and replace it with a new ignitor. Replace all the range parts.Turn on the power and turn on the gas supply.
Copy and paste this site for the location of the ignitor you can also purchase the part from them.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=111359&diagram_id=362260#d362260
Jan 01, 2010 | Frigidaire FGB24T3A Gas Single Oven
Oven model FGF316ASA OVEN WILL NOT IGNITE
change the igniter its just weak
cost around $65 for universal fit
takes 15min to change
Nov 17, 2008 | Frigidare FGB24S5DC Gas Single Oven
Gas stove works, but oven does not
you most likely have a bad oven ignitor...if you see an orange glow under the oven panel that is your ignitor trying to come on....but if it is weak it will not open the gas valve.....acess the ignitor and replace it
Jul 30, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
341 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
