Question about IBM ThinkPad T40 2373 Notebook
When I start my computer windows won't start up properly, under normal settings or in safe mode. Can you help me? Thank you!
    President:
  • 1,383 Answers
Enter in safe mode.
go to start menu then run type in run "chkdsk /r"
then press enter "y"
then restart computer then it scan for viruses.
Posted on Jun 14, 2009
Whenever I power up my laptop, a bluescreen appears with IRQL_NOT_LESS_OR_EQUAL. What should I do to solve this?
Try loading the computer in "Safe Mode" and see if the problem still occurs. If it doesn't, then you have something on the computer that is causing the problems and needs to be cleaned off.
To enter "Safe Mode":
1. Go to "PC Settings".
2. Click "Update & recovery".
3. Next click "Recovery", and then under "Advanced startup", click "Restart Now".
4. Once the "Choose an Option" screen opens, click "Troubleshoot".
5. Now click "Advanced Options", and then "Start-up Settings".
6. Then click "Restart".
7. The computer will restart, and load the "Startup Settings" screen.
8. Here you will make your "Safe Mode" option choice. Your choices are:
a. Press the "F4" or "F5" or "F6" key to Enable "Safe Mode".
(The computer will then start in "Safe Mode" with a minimal set of drivers and services.)
9. Now sign in to the computer with your account name and password. (If you have one set.) 10. When you are finished troubleshooting, you can exit "Safe Mode" restarting your computer.
Good Luck.....
Jan 07, 2018 | Dell Computers & Internet
I have an HP notebook. I was on Skype with a friend when suddenly it froze showing green colors on the screen. Nothing would un freeze it so I opted to turn it off through the power button. ...
Step 1:
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 11, 2013 | Computers & Internet
When Power On, the computer appears to be starting, get DELL logo, then black screen, then "We apologize for the inconvenience. Windows did not start successfully. A recent hardware change or...
Hi
You didn't told us, what is the most recent updates you've done, i.e.: installing driver or software, or something like this.
Choose 'Last Known Good Configuration', if not worked, choose 'safe mode'
Please tell us your results
Good Luck
May 13, 2011 | Dell Vostro 1500 Notebook
I had accidently turned of the power as my PC was loading up , so then when i turned it back up it has come up in a black screen saying:- We apologize for the inconvenience , but windows did not start...
Now that PC works in Safe mode i suggest you to run the Disk Check.
Step1: Double click on My computer and then right click on C drive.
Step2: Choose properties and then click on tools option.
Step3: Click on the Check Now tab listed under Error Checking.
Step4: Select both the options under "Check Disk Option" then click on start.
Step5: It will prompt you to restart your computer.
Step6: The Disk Check gets initiated as soon as you your computer starts rebooting.
Step7: Allow it to finish.
Hope this helps.
Jan 15, 2011 | ASUS Eee PC 1000HE Netbook
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
Your computer stopped responding, restarted unexpectedly, or was automatically shut down to protect your files and folders. Choose last known configuration to reverse to the most recent setting that...
Choose safe mode and see if you can get into it. If you can then go into system restore and choose the last date that you remember the computer working properly.
At this point the computer will restore the computer back to the earliest date that it was working properly.
Once you do this the computer will reboot and it should go back into windows normally and work just fine. If for some reason it doesn't then windows is corrupted and you'll need to wipe out the hard drive and restore the computer back to factory defaults.
Aug 21, 2009 | Sony VAIO PCV-V210P PC Desktop
Look for windows recovery CD for AcerAspire 5610
It is good when you can start Safe mode it can help.
What realy happen when you start in 'Normal' mode ?
Do the following:
Start the computer in Safe mode.
Open My computer, than Right-click on Disk C and click on properties.
Click on Tools Tab and then click on 'Check Now', and then Start (leave two options above unchecked)
When it finishes, it should show that Disc check is complete, close it.
Right-click on My Computer, click on properties, and then Advanced Tab.
Click Settings in Startap and Recovery field.
Uncheck Automatically restart and then OK.
Now restart and see if it will bring Windows in 'Normal' mode.
Are there Errors, Blue Screen . . . . ?
If so, try one more thing.
Go to Windows start options (the one you go to select Safe mode) and go to
Last good known configuration
and pres Enter and once again, Enter.
Did you get to 'Normal' Windows ?
Mar 27, 2009 | Acer Aspire 5610-4648 Notebook
Sony vaio not loading windows
reinstall the OS ! Just overrite it over the previouse xp so u won;t lose data ...
..most probably u are missing some files ... .. or u have virusez issues. Ofecourse there is the posibility of hardware mallfunction, but considering microsofts reputation ... probably thats not the issue ...
Dec 10, 2008 | Sony VAIO PCV-V210P PC Desktop
Computer will not start past safe mode screen
In safe mode, hit start button -run, and type "msconfig" in the box , hit enter.
the system configuration utility opens.
select startup tab at the top
when the startup screen opens, UNcheck all the boxes, press APPLY, then OK
the computer will prompt you to restart, when it restarts it will give you a message saying you have use the system configuration utility to change the way windows starts, this is normal. Check the box that say dont show this again and click OK.
doing this will keep the programs set to start when windows starts from starting untill you start them manually. If one of them is causing the freeze, this will make the system accessible.
Keep in mind, you may want to turn some of them back on after you get the computer going and when you do , turn them on one at a time and restart the computer after each change. this way you can identify which program is causing the problem.
Hope this helps. please repost if you have more questions
Oct 08, 2008 | Sony VAIO PCV-V210P PC Desktop
Safe mode business
safe mode automatically comes up when you didn't shut down properly. Just select boot as normal or last known good configuration then you are good to go.
uninstall any new hardware or software you have recently installed to cause the problem in the first place. If you haven't installed anything then windows should just start normally.
good luck
smeags.
Jan 22, 2008 | Computers & Internet
IBM ThinkPad T40 2373 Notebook Logo
67 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
