Question about Garden
My craftsman chainsaw starts but will not stay running? What can I do?
  • 1,041 Answers
First, check the fuel lines for cracks/breaks.
If they are o.k.,then you will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Usea Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit abd replace all appropriate parts.)
If you need further assistance, just let me know.
Jim
Posted on Jun 14, 2009
  • Jim Parker
    Jim Parker Jun 15, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Poulan chainsaw starts but won't stay running
Try choking it a little longer and it will warm up and should run
Jul 25, 2016 | Poulan Garden
Cant stay running
What to do if your chainsaw won't stay running?
arborist101.com/what-to-do-if-your-chainsaw-wont-stay-running/
Idle ports may be plugged or blocked - This is the small ports in the carburetor where the fuel passes through when in idle. ... Vent in the Fuel Cap is plugged - If the vents in the fuel caps are clogged the fuel becomes vacuum locked. ... Starting with the High Speed screw, turn it ...
Craftsman 16" Chainsaw Fix - Won't Run - Fixed! - YouTube
? 1:32
https://www.youtube.com/watch?v=aIUVQziXBPY
Jul 7, 2011 - Uploaded by BriggsRepair
Is this Craftsman 16" chainsaw broken? Hardly. Watch this carburetor fix and how it runs brand new!
Chainsaw won't stay running - DoItYourself.com Community Forums
www.doityourself.com/.../360759-chainsaw-wont-stay-running.html
Sep 20, 2008 - Chainsaw won't stay running. Craftsman 16" chainsaw, fuel/oil ratio 40:1. Saw is 10 years old, used once or twice a season. Last used in spring ... chainsaw wont stay running
Aug 1, 2015
Craftsman chainsaw won't stay running
Oct 30, 2010
Chain saw won't stay running
Oct 2, 2006
Poulan Chainsaw - starts but won't run
Apr 28, 2006
More results from www.doityourself.com
Why won't my chainsaw stay running? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 31, 2016 | Garden
36 cc craftsman 16 inch saw replaced fuel lines fires up but wont stay running it excellerates for about 15 seconds
Check to see if exhaust is stopped up Clean or replace it then it should run good,If not replace fuel cap.Take fuel cap off and start.if runs and accelerates then replace fuel cap. If not the exhaust is stopped up with carbon clean it or replace.
Nov 01, 2014 | Garden
Craftsman chainsaw runs then stalls when starting to cut
allways use full throttel when you insert the chainsaw
Jul 04, 2014 | Husqvarna Garden
Chainsaw issue
What is the model number of the saw?
It may as simple as a tank vent that is clogged. I have seen this on Poulan saws, and many of the new Craftsman saws are rebranded Poulans.
If the saw has a tiny hole in the center of the fuel cap, try this test. Engage the chain brake, turn the saw on its side so the cap is facing upward, loosen the cap slightly, and start it while a strong helper holds it on a workbench. If it runs normally (don't heat up the clutch drum while the brake is engaged!), the tank vent needs to be cleaned or cap replaced. If it still won't run correctly, it is time to diagnose the carburetor and other areas of the engine.
Let me know if you have any luck getting it going.
Mar 30, 2014 | Craftsman Garden
CRAFTSMAN 20" MULCHING MOWER MODEL
You have to take the bowl nut off he bottom of the bowl and clean it with a small wire or torch cleaners. Try not to allow the bowl to drop off the carb, the float drops down and the needle might come off the float.
Mar 11, 2011 | Craftsman Garden
Redlite blinks and green lite stays on hours while charging my craftsman battery
most likely you have a bad battery pack.craftsman recommends you bring battery and charger to craftsman repair location. what is the model # of battery and charger? i'll try to get you more info.
Dec 31, 2010 | Craftsman Garden
Chainsaw starts and runs fine for a few minutes
Try fresh fuel making sure oil and gas mixture is correct. Carb might need cleaning and adjustment.
Jul 26, 2009 | Garden
Craftsman 16'' chainsaw, start with very high rpm, how to adjust ?
The H is for when your cutting,it keeps the saw from stalling. The L, is for the saw when at Idle. When the L ,is adjusted right, the saw should stay running ,and the chain should not move ,that is with the break in the off position. The H screw,should be adjusted if the saw bogs down when rev ed up. A good starting point for theses screws would be a turn and one half out.
Jan 19, 2009 | Garden
Garden Logo
118 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
