Question about Zenith Data Systems Zenith (OP-260-74501) Plug-In Module 24x CD-ROM Drive
CD Rom tray stuck
Compaq Presario CD rom tray will not open, it is empty, computer not on line, has no small hole in front, program does not recognize the CD rom. Help will be appreciated. R. C. Trimble, Colonel USA Retired
  • 130 Answers
Does the case a a faceplate infront of the cd rom drive(i.e. if there is a door that flops down when it opens)? if so you probably need to take off the computers faceplate and then you can get to the little hole.
Posted on Jun 14, 2009
The cd tray on my computer will not open
HI
use thin and long paper pin to open it,
insert pin in cd tray"s hole which u see in front of CD tray and push it,you will get the Cd tray out..
May 28, 2011 | Computers & Internet
How can i remove a stuck cd in my computer?
There is a tiny hole just below the CD tray. Straighten a paper clip and insert it into this hole and push it in gently and the tray will pop out. then you can pull the tray out fully to access your CD.
Nov 12, 2010 | Compaq Presario 2100 and 2500 ,NX 9000...
Hi my cd rom will not read a disc or pop out when I press the button and the light will not come on
to open the cd rom u will need a small pin, there is a small hole on the front panel of the cd rom drive, insert the pin into this hole and the cd-rom drive should pop out...oh and i think you will need to replace the cd-rom drive because its had its best days!
Jul 09, 2010 | Compaq Presario Notebook
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
My CD ROM/DVD on my computer drive wont open? Why not?
Try either right clicking on the CD drive icon in My Computer and see if it opens, of not put a straightened paperclip into the small hole on the CD drive face and push into open it. Does the light flash or does it make any noise. I would make sure that it isn't jammed by trying the first two. If all is good, then go into Device Control Panel->System->Device manager->DVD\CD-Rom Drives and see if your drive is showing. If it is then right click and click Uninstall and then restart your system. It should find new hardware and reinstall the drivers for your driver if it is working properly.
Jan 25, 2009 | HP Compaq Presario SR2011WM PC Desktop
My cd rom is stuck, when i click eject button it won't open.
There should be a small hole in the front, use a paper clip and push into the hole to eject tray mannualy. The cause of the tray not ejecting is that the belt from the motor that ejects the tray is worn, need to change it.cheers.
Dec 01, 2008 | Gateway (5502156) CD-ROM Drive
DVD/CD ROM does not open
There should be a small hole on the front panel of the DVD-ROM. Take a paper clip and insert it into the hole and push to open the tray. If the DVD-ROM tray continues to malfunction, you'll need to replace it. DVD-ROMS run anywhere from $25.00 to $75.00.
Oct 01, 2008 | E-Machines emachines (emachinees) CD-ROM...
Disc tray will not open
a small orifice is given there in cd-rom near a push or open button or LED in front side of the rom.take a niddle and enter it in that hole, rom will be opened
Jan 20, 2008 | Computers & Internet
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
316 people viewed this question
Top Zenith Data Systems Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Zenith Data Systems Computer and Internet Expert? Answer questions, earn points and help others
