Question about ASUS N6200/TD GeForce 6200 AGP 256MB DDR Video Card w/TV-Out & DVI Retail ***Free 2nd Day*** Graphic Card
How to properly install Asus N6200 AGP video card
Hi. Im currently using a PC with the following specs: Pentium 4 3.0 Ghz processor, 512 DDR RAM, 80 Gig HD, ECS Elitegroup P4M800PRO-M3 motherboard. The PC has no video card when I bought it and only runs with Integrated UniChrome Pro 3D/2D Graphics & Video Controller. According to the motherboard manual, it supports for AGP 8X/4X, AGP v3.0 with 1.5V. To enjoy games, I recently bought Asus N6200 128 MB, 64 bit AGP videocard. I installed it as well as the driver, but the graphics and icons that appear in the monitor are blurred, or what PC technicians call "garbage" (from the desktop, the start menu, control panel icons, virtually everything). I brought the video card back to the store to check if its defective but it runs perfectly well when they tested it in front of me in their PC. They advised me to adjust the "hertz" in the Monitor  in Properties-Settings-Advanced window. I tried all the adjustments (60 hertz, 70 hertz, 72 hertz, 75 hertz, 85 hertz), so with the resolution options, but the same problem persists. Please advice what to do. Thanks!
Set refresh to 60hz
Set color to highest position.
If this is an LCD, set it to the highest resolution
If this is a 15" or 17" CRT, set resolution to 1024x768.
If this is a 19" CRT, set resolution to 1280x1024.
Also, do not use the drivers on the CD. Go too nvidia.com and download the latest there.
Also, if you can get into the BIOS, try to disable the on board graphics if you see an option for it.
Posted on Nov 11, 2007
What would be the best compatible 512 MB GPU(with shader 3 or 4) working with P4I45GV 3.00 /P4 2.4 GHZ/1 Gb ram ?
http://www.asrock.com/MB/overview.asp?Model=P4i45GV%20R5.0
Any of them Shubham.
If we are to discern by a few known statements;
1) It is believed in some 'geek communities', that using the same manufacturer of motherboard chipset, and graphics chipset; to be a good thing.
For example an AMD motherboard chipset 'plays well' with an AMD ATI graphics chipset;
Nvidia motherboard chipset 'plays well' with Nvidia graphics chipset.
Intel motherboard chipset with Intel graphics..............no wait,....... there is no Intel graphics chipset, unless it is -> Integrated Graphics.
[ Intel GMA ]
(Integrated Graphics is also said as OnBoard graphics. ON the motherBOARD)
2) DOES NOT MATTER what graphics memory type is used.
Motherboard can use DDR Sdram ram memory, and graphics card can use GDDR5.
Why?
Because the graphics card has it's own Processor, and Ram Memory.
Graphics Processing Unit, or GPU; is the Processor,
http://en.wikipedia.org/wiki/GPU
Graphics memory is the ram memory.
Operates independent of the system resources.
The graphics expansion slot on the P4I45GV (P4 i 45GV), is an AGP slot.
Accelerated Graphics Port,
http://en.wikipedia.org/wiki/AGP
It will use an AGP 4X, or AGP 8X graphics card.
Use an AGP 8X.
http://www.tigerdirect.com/applications/SearchTools/search.asp?keywords=agp+graphics+card+512mb
REMEMBER;
1) ALWAYS follow Anti-Static Precautions.
2) INSTALL the software for the graphics card F-I-R-S-T,
(Drivers and 'control panel')
THEN unplug the computer from power, follow Anti-Static Precautions, and Physically plug the graphics card into the motherboard, and install.
3) L@@k at the system requirements (Minimum) for the graphics card.
Specifically the Power Supply requirements. You need a Power Supply with enough Wattage, to handle the graphics card.
[ Handles the graphics card, and -> Motherboard, Processor, Ram Memory, and peripherals; Internal and External.
{Harddrive/s, optical drive/s; Internal
Mouse, Keyboard, external harddrive, etc; External ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Nov 17, 2012 | Computers & Internet
Install or download the NBA 2k11 to my loptop
Hi xselenegonza!
Check your system specs and look if you pass the minimum requirements to run the game.
Minimum System Requirements:
CPU: Pentium 4 2.4 Ghz Single Core processor or equivalent (2.8 Ghz for Vista)
RAM: 512 MB or more (1 GB for Vista)
Disc Drive: 8x or faster DVD drive
Hard Drive: 10.5 GB or more free space
Video: DirectX 9.0c compatible (see below)
Sound: DirectX 9.0c compatible
Input: Keyboard or dual-analog gamepad
Video card with 128 MB or more memory and one of the following chipsets is required:
ATI x1300 or greater;
NVIDIA 6600 or greater;
DirectX 9.0c compatible card with Shader Model 3.0 support.
Important Note: Game requires Internet connection for activation
Recommended System Requirements:
CPU: 3 GHz Dual Core processor or equivalent
RAM: 2 GB
Video: Shader Model 3.0 support with 512 Ram (Nvidia(R) Geforce(R) 7900 GT or better)
Sound: 100% DirectX 9.0c compatible sound card
Input: Dual-analog gamepad
DirectX 9.0c or DirectX 10
For more info (Click here)
Sep 19, 2011 | Computers & Internet
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
Hi can Sony Vaio PCV-RS602 mother board support a sata hhd
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
  • Type: Personal computer
  • Form Factor: Tower
  • Processor: 1 x Intel Pentium 4 3.2 GHz
  • Processor Main Features: Hyper-Threading Technology
  • Cache Memory: 1 MB L2 Cache
  • Cache Per Processor: 1 MB
  • RAM: 512 MB (installed) / 2 GB (max) - DDR SDRAM
  • Storage Controller: Serial ATA ( Serial ATA-150 ) ; IDE ( ATA-100 )
  • Floppy Drive: 3.5" 1.44 MB floppy
  • Hard Drive: 1 x 160 GB - standard - ATA-100
  • Optical Storage: DVD±RW
  • Optical Storage (2nd): DVD-ROM
  • Card Reader: Yes
  • Monitor: None.
  • Graphics Controller: AGP 8x - ATI Radeon 9600 XT
  • Video Memory: 128 MB
  • TV Tuner Type: Analogue TV
  • Audio Output: Sound card - 5.1 channel surround
  • Communications: Fax / modem - 56 Kbps
  • Networking: Network adapter - Ethernet, Fast Ethernet
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 06, 2011 | Sony VAIO RS602 (PCV-RS602) PC Desktop
    HP Pavilion 751n Pentium r 4 1.8 GHz Ram: 1G DDR
    you can use Prescott 2.4 it will suport .
    purchase from bellow the link.
    http://shop.ebay.com/i.html?_nkw=2.4+prescott+&_cqr=true&_ipg=&_nkwusc=2.4+preescort&_rdc=1
    Hope this helps.
    There is an rate option "Was this helpful?" Yes or No.
    If you are helped you can rate ,that is your choice.
    Jan 17, 2011 | ASUS P4S333-M (P4S333-M SA/LAN)...
    Hello again.I have an old home pc and I want to upgrade the cpu processor without changing motherboard.Wich is my best options?I want to know if I can to upgrade to PENTIUM 4 3.00 GHz.Also I want to put...
    If new processor supports your old motherboard then you will upgrade system with your old motherboard.
    If its not supported to new mother board then you have to buy new motherboard to upgrade your system.
    Thanks.
    Happy to help you.
    Apr 30, 2010 | Intel CPU
    Big city rigs
    first check if your computer answers the following requirements:
    Windows® XP/Vista
    Minimum Requirements:
    • Pentium® 1.7 GHz or similar processor
    • 512 MB RAM
    • DirectX® Compatible Video Card
    • 128 MB Video RAM
    • DirectX® 9.0c
    • 2 GB Hard Drive Space
    • Mouse
    Recommended Requirements:
    • Pentium® IV 2 GHz or similar processor
    • 512 MB RAM
    • 3D Video Card with at least 256 MB Video RAM
    • DirectX® 9.0c
    • Mouse
    if you do, please tell me exactly what happens when you try to install the game
    Jan 25, 2010 | ValuSoft 18 Wheels of Steel: American Long...
    Have a HP Compaq d530 SFF with the following specs: Windows XP 2.66 Ghz Processor 1.5 GB RAM 80 GB HD I also bought a NVIDIA GeForce 6200 512MB DDR AGP DVI/VGA Low Profile Video Card w/TV-Out to be the...
    No it is Good enough, You should just make sure that it shouldn't heat-up and is properly placed, as in low-top casings it is difficult to give them enough room, if the Fan for the Card is working properly, then no need to worry.
    I hope you will have a clear picture now.
    Regards, WAQAR.
    Dec 22, 2009 | HP Compaq d530 SFF PC Desktop
    Still lagging in WoW!
    Answered originally by TimIsHectic:
    Assuming you mean a bad framerate and not actual 'lag', the problem would appear to exist in your processor, as it is old and outdated. and only just fits the minimum requirements to RUN THE GAME, not run the game well.
    Answer: You should upgrade your CPU to a Pentium Dual-core at least.
    WoW System Requirements
    Processor:
    Minimum: Intel Pentium 4 1.3 GHz or AMD Athlon XP 1500+
    Recommended: Dual-core processor, such as the Intel Pentium D or AMD Athlon 64 X2
    Memory: Minimum: 512 MB RAM (1GB for Vista users)
    Recommended: 1 GB RAM (2 GB for Vista users) Video: Minimum: 3D graphics processor with Hardware Transform and Lighting with 32 MB VRAM Such as an ATI Radeon 7200 or NVIDIA GeForce 2 class card or better
    Recommended: 3D graphics processor with Vertex and Pixel Shader capability with 128 MB VRAM Such as an ATI Radeon X1600 or NVIDIA GeForce 7600 GT class card or better
    May 03, 2009 | Blizzard Entertainment World of Warcraft...
    My hardware upgrade
    all your using is outdated only you can use is your 40gb hdd for a new mainboard. your can go with intel core2duo cpu with ddr2 800fsb 2gb ram.
    Mar 18, 2008 | Computers & Internet
    Open Questions:
    See all ASUS N6200/TD GeForce 6200 AGP 256MB DDR Video Questions
    Computers & Internet Logo
    649 people viewed this question
    Top ASUS Computers & Internet Experts
    Alun Cox
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
