Question about Intermatic 24hr Outdoor Timer
Clicking noise from my Intermatic raintight outdoor timer
The model is ML815TKR , it pops the fuse sometimes, but now it makes a clicking noise inside, and i don't know how to open it to see what is clicking
  • 112 Answers
SOURCE: my rain tight intermatic outdoor timer no longer switches contact
the way the message reads the timer was working and then quit. most likely the contacts or clock motor has wore out. but by u sayiing u can't get power manually i would say the contacts or relay that switches the load is bad.
i would try to buy a timer that was the same and put the guts in the old box if its alot of trouble to change out.
one other thing u can check, is the timer getting its operating power from the circuit or is the something else controlling the timer. if there is something else controlling the timer, i would check that to see if i had power there.
Posted on Jan 13, 2009
VtToolMan
  • 704 Answers
SOURCE: intermatic outdoor can't reprogram. display reads NoOp
Les, First thing to do is to change the battery and see if the timer will allow you to reprogram it. Sometimes these timers will fail, as some models have a known history of failing fairly often.
NoOp, means non operating within the Intermatic line of electronic timers, so in order to see if the unit has failed or is just malfunctioning, due to a weak battery, remove the existing battery and install a fresh, new one.
You can remove the existing battery by flipping down the front switch panel and removing the battery tray with either your fingernail or a small flat bladed screwdriver. As your timer is showing the NoOp, you don't have to worry about losing your programmed on/off cycles, so you can take your time. Normally, if you're changing the battery, you get about 30 seconds to do this with some models of Intermatic timers, or you'll lose the settings. The newer models store the program regardless of how long it takes to change the battery.
Once you've replaced the battery, press the Reset button on the timer and allow it to refresh. If the NoOp is gone, just reprogram the timer with your on/off cycles and days and you're back in action. If the timer doesn't clear, you'll likely need to replace it, as it could be damaged and will not be able to be programmed again.
Usually, changing the battery and resetting the timer works about 60% of the time for me, as I've installed thousands of the various Intermatic timers in customer's homes over the years.
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
MOTORWIZJ
  • 1384 Answers
SOURCE: outdoor timer and started to make a humming noise
IT COULD BE THE TERMINALS ARE LOOSE TIGHTEN ALL OF THE SCREWS THAT HOLD WIRES ON TIMER BOARD.. ANOTHER THING I WOULD CHECK IS THE AMPS YOUR MOTOR IS DRAWING , MATCH THE AMPS TO THE NAME PLATE ON YOUR MOTOR SHOULD BE RIGHT AT IT OR UNDER ... THE NAME PLATE AMPS.. SO SAY A 1HP 1.0 SF MOTOR HAS A 7.6 AMP RATING AT 23O VOLTS THAT SAME MOTOR WILL SET TO 115V CAN DRAW 15.3 AMPS .. VOLT AND AMP METERS ARE CHEAP AND A VALUABLE TOOL AROUND THE HOUSE,CAR... NOW IF' I WAS ANY HELP TO YA ALL . HIT THE RATING OR HELPED BUTTON ........... THANKS AND BE CAREFUL EVERYDAY ... JAY
Posted on Jun 10, 2010
SOURCE: Set up Intermatic outdoor timer 7day/7event
I have misplaced and forgot how to set a Model HB65R timer, can you help, thanks, Murray
Posted on Dec 24, 2010
I need trippers for an Intermatic Raintight Outdoor Timer model HB11R
1) Intermatic trippers: Buy Amazon or Intermatic store
Copy following link to identify tripper
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
2) Copy following link to identify Intermatic analog timers with replaceable trippers
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
3) Add comment and describe timer in detail, and color of tripper
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Dec 10, 2012 | Intermatic & Indoor/Outdoor Rain Tight...
HOW TO SET INTERMATIC T104R
Open following link for instructions how to set T104 timer:
http://waterheatertimer.org/pdf/How-to-operate-and-set-T104-timer.pdf
The T104 is 240volt timer, and the R suffix means timer is inside raintight indoor/outdoor enclosure.
Jun 14, 2012 | Intermatic T104 24h 208-277v Mechanical...
How do I set my raintight intermatic timer
1) You posted under Intermatic T-100 series timer.
To set current time, lift and rotate dial until current time lines up with silver pointer.
For timer to operate, add on-off trippers to edge of dial at times you want Load to operate.
2) For information about wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
3) Timer not working: If timer dial is not rotating or is not keeping time, order clock motor.
If dial operates, but trippers don't click lever, then order extra trippers.
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
4) For more questions or questions about other timers, add a comment and describe timer or include model number.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 20, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Need manual to set timer
You posted under T-100 series outdoor timer
If you have different timer, add a comment with timer model number located inside cover.
T-104, T-103, T-101 timer manuals show on following page:
If your timer has R suffix, like T-101R, that means box is Raintight for outdoor use.
T-101R and T-101 mechanisms are identical except for box. T-101 box is indoor use.
Click model number and drop-down menu reveals link to manual
http://www.intermatic.com/products/timers/mechanical%20time%20switches/24%20hour%20dial.aspx
If you need simple wiring diagrams, and explanation for each T-104, T-103, T-101 timer:
Here's how to set Intermatic T100 series timers:
Lift and rotate yellow dial until current time lines up with silver pointer.
Silver pointer is stationary at 6 o'clock position.
Put ON-OFF trippers on dial at times you want ON OFF functions.
Minimum on-off is 1 hour because of tripper width.
If timer is not working, add a comment and we'll troubleshoot.
These timers have replacement trippers and clock motors at Grainger
How timer works:
Clock motor, located on back of mechanism, rotates yellow dial.
Trippers on dial push lever that turns power ON and OFF.
Off tripper pushes lever one direction.
ON tripper pushes lever opposite direction.
When lever is pushed, manual override lever clicks back and forth with audible click sound.
Nov 29, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Need manual for HB77R
Intermatic HB77r outdoor raintight plug-in timer is for incandescent use up to 500watts.
Uses AA alkaline batteries. Batteries are for backup and don't affect timer operation in cold temps up to minus 40 degrees C, same as minus 40 degrees F.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb77r.aspx
Nov 15, 2010 | Intermatic Programmable 7 Day Digital...
I have a 15 yr old tork 1101 pool timer. I misplaced the tripper pins the replacements P-47 dont fit. What do I do
1) Tork P47 tripper is correct tripper for 1101 timer.
Trippers are brass-colored and black-colored.
If they do not fit timer dial you might need new timer.
http://www.frontierlighting.com/find.jsp?a=1&ID=,Photo.Cells...Time.Controls,Replacement.Trippers
2) Buy new 120Volt indoor/non-weathertight Tork T1011
To identify timer for sure:
http://waterheatertimer.org/Tork-timers-and-manuals.html
3) Google search Tork 1101 shows timer cost $83
4) Intermatic cross reference shows replacement is T-101 indoor/non-weathertight
Amaxon sells T101 for 43$:
http://www.amazon.com/Intermatic-T101-Hour-Dial-Timer/dp/B00002N5FN
5) Raintight/outdoor: Aplus and Lowes sell raintight outdoor T-101R for $71
http://www.lowes.com/pd_29405-251-T101RD89_0_
http://www.aplussupply.com/intermatic/timer.htm
6) Cross over wiring.
Tork terminal X is T101 terminal A
Tork terminal 1&L are T101 terminal 1
Tork terminal 2 is T101 terminal 2
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jul 11, 2010 | TORK Digital Interval Timer Ssa100r-24
Intermatic 24hr Outdoor Timer Logo
305 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
