Question about LG VOYAGER VX10000 Cellular Phone
Charging port on LG Voyager loose
Third phone with similar problem. Charging port becomes loose with poor connection requiring hand held charging.
  • 93 Answers
Time for a new phone or some super glue
i suggest you not play with the phone as much when its on the charger
Posted on Jun 14, 2009
  • pappydroid Jun 20, 2012
    nothing constructive here
My Samsung tablet won't charge when plugged in
Does it have a micro USB charger/charging port? This was the universal charging adapter most manufacturers other than Apple moved to around 5 years ago. In my experience, the charging port to charger connection can become loose and prevent charging....especially if you use the tablet or phone during charging. The best method I have found to troubleshoot the issue is to try a charger that successfully charges another device and plug it into the tablet or phone. If your device still does not charge, and especially if the connection is loose, it is most likely that your charging port is damaged. Another possible issue would be the battery itself but the charger or charging port is the most likely culprit for your issue.
Sep 08, 2017 | Samsung Tablets & eReaders
Why my lg phone KP 502 is no charging the battery
if you have ensured that the charger is working, and the charging port is also fine,,,
then , know that the battery is bad and it needs to be replaced with a new and original one.
1.. to ensure that the charger is working, connect to a similar phone and see if it charges, if it works,then you'll know that the charging port of the phone in bad and needs to be replaced by a phone specialist
I ASSURE YOU THAT THIS WILL HELP YOU RECTIFY THE PROBLEM
Jan 19, 2011 | LG Cell Phones
My phone will not charge even when i plug it in
Check with another charger to see if it will charge, if it is still same problem, the problem is from the charging port on your phone.
You will need to replace or change the charging port on your phone to solve the problem.
Take the phone to any local phone repairer to help you replace the charging port on your phone, the cost of replacing the charging port is very cheap. This the solution to your phone not charging.
Take care.
Aug 09, 2010 | LG VOYAGER VX10000 Cellular Phone
Will turn on but won't charge
Hi
I think yhe problem you are exreriencing with your phone has to do with the charging port of your phone.
All you need to do is to test your charger with a similar phone and if it charges then you would have to replace the charging port of your phone.And if the charger d
Jun 21, 2010 | LG VOYAGER VX10000 Cellular Phone
For LG enV VX9900 Phone, Silver (Verizon Wireless) My charge port is loose. When I plug in charger it moves and is not snug. It now is so loose that I have try and catch the right spot for contact and...
It is not your battery, as far it is charging when you get the right spot at the charging port.
I advice you change your charging port because it is glaring it cannot hold your charger firmly anymore that why you have to all through the stress of locating where it will charge at the charging port.
Just replace the charging port, you will see it will charge without you holding it.
To confirm that your battery is still very good, you can remove it and place in another phone, if it charge, it means it is good.
Please also try to use the charger to charge another similar phone to see if it will giving you such problem because it could also be that the charger is bad.
Take care.
Apr 14, 2010 | LG VOYAGER VX10000 Cellular Phone
Charging port lg chocolate
wow to soder the charger port for lg vx8500
charles
Feb 18, 2010 | LG CHOCOLATE VX8500 Cellular Phone
My voyager wont charge its brand new... only three weeks old and ive chaarged it before but now today i went to charge it and it wont work
If you have already tried using another charger, then the charging port inside your phone is probably either broken or bent. I wouldn't suggest trying anything to unbend it or fix it yourself; I would go up to the store if I were you. I had the similar problem, and I just got my refurbished (4th Voyager) in the mail today. But my most recent old phone did the same thing, and I had to get it replaced; I hope I helped some!
Jun 07, 2009 | LG VOYAGER VX10000 Cellular Phone
The charger port on my lg voyager is frayed. If i buy anew charger port, is it easy to install? i thought it was my battery, so i bought a new one on Amazon. put the battery in and it worked fine. i have...
you have done well in troubleshooting it. if you have tried another charger on it and its not charging, then you have to replace the charging port. if you are good opening phones, then replacing the charging port will not be a problem. the chrging port is usually not screwed, it is just fixed to the board by contacts. look for the replacement part and change it. other wise, take it to a phone technician with the new charging port and replace it. good luck!
May 27, 2009 | LG VOYAGER VX10000 Cellular Phone
LG VOYAGER VX10000 Cellular Phone Logo
1,996 people viewed this question
Top LG Cell Phones Experts
skiffy99
skiffy99
Level 1 Expert
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
