Question about Watts Onan Portable Generator - 4000 , Model# 5500
Onan generator making grinding noise while cranking
I have a 94 Onan 4000 microquiet generator that makes an intermittent grinding noise while turing over before starting. It is very loud and reminds me of a starter grinding on a flywheel but I'm not convinced that is what it is. Is there something else it could be?
    President:
  • 3,433 Answers
If it walks like a duck and quaxks like a duck?
If it grinds like a starter ?
Your alternator would hsve to be in absolutely unaerviceable condition to match a noise a starter makes.
Posted on Jun 14, 2009
Onan 4000 won't turn over
check for bad battery, loose terminals ,dirty terminals , faulty starter relay
if it is not starting check for oil level is correct ( low oil level sensor turns off ), diesel -air in system
Jun 11, 2016 | Onan Microquiet 3600 & 4000 Generator
Check the ignition circuit, and trigger coil for correct resistance on the trigger coil, and the ignition coil. The trigger coil is a small module on the engine shaft near the flywheel.
Jan 31, 2015 | Onan Microquiet 3600 & 4000 Generator
I have an Onan 3600 microquiet lp. I made the mistake of hooking up a jumper box to the battery with the cables crossed,now it blows the 5amp fuse that supplies power for starting. hope I didn't fry...
It certainly sounds like you have damaged the control board. If you cranked it with reverse polarity, there is a good chance that you have rotor winding damage also. If not you still may have to flash the rotor windings to ensure a correct polarized field. That involves hooking a battery for a couple of seconds to the rotor brushes (with correct polarity) with rotor brush wires disconnected. Only do this if there is no output voltage after you replace the control boards. Bad mistake :)
Aug 05, 2013 | Onan Microquiet Generator Lp Vapor 3600...
Onan generator microquiet 4000
Check the pickup tube in the vehicle, the fuel pump is suspect. If you check the fuel pump pressure and it is ok, then try installing a test check valve between the fuel delivery hose to the generator. If it solves the problem the pump is losing it's prime internally, so replace the fuel pump.
May 24, 2013 | Onan Microquiet 3600 & 4000 Generator
Onan bfa 4.0 generator
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Apr 27, 2013 | Onan Microquiet RV Generator 4000 Gasoline...
Onan Microquiet 4000 starter will spin but not turn engine
bendix is actual the spring that pushes the gear back out of the ring gears engagement your issue is more likely a rusted /corrodied incline engagemnt gear a little lube will probably bring ti right back (do not us WD_40) this is not a lubricant it is an anti lubricant any light oil will do Good Luck
Oct 12, 2009 | Electrical Supplies
Onan MicroQuiet 4000 Generator
Remove the air cleaner and inside near the throat of the carb is two bolts holding the carb to the intake remove these. Unhook the fuel line and twist the carb to allow the linkages to remove.
Sep 14, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,020 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
