Question about RCA RP5420 Clock Radio
I need to know how to use the clock radio with 2 wake ups RCA RP5420C Can not get it to work. It is brand new...... Need instructions to set, with wake ups and neps ETC.
I purchased an RCA Radio/CD player, with the manual showing the numbers RP5605 and RP5605R on it. However, I cannot set the clock, alarm, etc. because everything in the manual's instructions is NOT in
To use the worry-free backup battery, get a 9V battery. Then look for the battery compartment on the bottom of the unit. Press the tab with your thumb and then lift the cover out and away. Plug in the battery and then replace the cover.
Press Wake Time once and use the forward/reverse buttons to set the alarm time. Then press Wake Mode repeatedly to toggle between the options of wake to radio, wake to CD, or wake to alarm. (Note the radio must be tuned to your desired station and a CD needs to be in the player for these to work).
The Smart Snooze means that pressing Snooze, forward, reverse, play or stop will turn off the alarm temporarily. (Pressing Off will prevent the alarm from sounding again today.)
The English version of the manual for the RP5605 clock radio is available here: http://www.voxxsupport.com/images/User%20Manuals%20-%20FAQ%27s/RP5605.pdf .
I hope this helps.
Dec 17, 2011 | RCA Audio Players & Recorders
Set alarm clock
goto http://voxrightnow.custhelp.com/app/answers/detail/a_id/12057/~/operating-the-rca-rp4803-clock-radio
or follow instruction
  1. Press the SET button until WAKE 1 / WAKE 2 icon is blinking.
  2. Press REV or FWD to set the wake time. The time decrements or increments will follow by a faster rate when you press and hold either REV or FWD.
  3. After the WAKE time is set, press SET repeatedly until no icon is blinking.
Tips:
  • The unit equips with GRADU- WAKE feature, the alarm tone volume will increase gradually to its maximum in about 30 to 45 seconds.
  • If you set the SLEEP function with low volume level before going to bed, we advise using WAKE mode to wake you up since its volume will automatically increase.
Waking by Selected Source: You may be woken up by WAKE, RADIO or CD.
  1. Select an AM or FM station.
  2. Set wake time (see above directions).
  3. Press WAKE 1 or WAKE 2 to select waking up by WAKE, RADIO or CD. Corresponding indicator will be shown next to the selected setting.
  4. Adjust the volume by turning VOL.
You can select your CD wake track by the following procedures:
  1. Make sure you have inserted a CD.
  2. While holding WAKE UP CD TRACK, press REV or FWD to select your desired CD wake up track.
Mar 18, 2011 | RCA RP4803 Clock Radio
How do you set the alarm and clock?
Setting Clock
1. Slide the switch /WAKE1/WAKE2/
on the top of the unit to clock position.
2. Press REV or FWD to set the clock
and hold the buttons. The ":" between
hour and minute time flashes when you
are setting the time. AM or PM icon will
also beside the time.
3. Slide the switch /WAKE1/WAKE2/
on the top of the unit to position
when finished.
Setting Wake Time
This unit allows two wake times to be set.
on the top of the unit to WAKE 1 or
WAKE 2 position.
respective wake time. The time
you are setting the time.
when finished.
http://audiovox2.info/docs/common/RP5430/RP5430_OM.pdf
Mar 15, 2011 | RCA RP5430 Clock Radio
I need an instruction manual for my RCA Clock Radio Model RP3750A. Can't turn off the alarm - want radio to come on with the radio and not the alarm.
There are three buttons under the heading "Dual Wake", WK1, Cancel, WK2. The WK buttons refer to the two wake time settings you can have. Press Cancel and then WKx. That will turn off the alarm. If you press WKx more than once, it will cycle through small symbols on the bottom of the screen with the number x in front of them. First symbol means it will have a sound alarm for alarm x, second symbol means it will have a radio alarm and the third symbol means it will play the CD to alarm. You set the time for alarm with the slide switch at the back of the unit, selecting WK1 for alarm 1 and WK2 for alarm 2. You can have both alarms active at once, or either one singly.
Nov 15, 2009 | RCA Audio Players & Recorders
How do you set the time and alarm on the RP5600A
Setting Clock
1. Press SET repeatedly until a clock icon
shows on the display.
when you press and hold the buttons.
AM or PM icon will also show beside
the time.
3. Press SET when finished.
Setting Wake Time
1. Press SET repeatedly on the top of the
unit until you see WAKE 1 or WAKE 2
flashes on the display.
2. Press REV or FWD to set the respective
3. Press SET repeatedly until you see no
WAKE 1, WAKE 2 or icon the
display.
Selecting Wake Source
You may be woken up by radio, CD or alarm.
1. If your desired wake source is radio or
CD:
• Wake by radio - select an AM or FM
station (see directions on “Radio”).
• Wake by CD - insert a CD in the CD
compartment. If you want to be
woken up by a specific track on the
CD, press and hold wake up - cd
track
on the top of the unit and at the
same time press REV or FWD to select
a desired track.
2. Set a wake time (see above direction).
3. Press WK-1 or WK-2 repeatedly at the
front of the unit to select a waking
mode. Corresponding icon lights on
the front of the unit.
- Wake 1 by alarm
- Wake 1 by radio
- Wake 1 by CD
In case of Wake 2, “2” shows at the
centre of the icons.
Sep 30, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Cannot turn off the alarm on my RCA clock radio rp5430
Look at the display. Look for a number 1 or a number 2 to determine which alarm is on. If you see a number 1, push the 1 button on the top right side of the alarm clock until the number light goes off (1 or 2 times, depending on whether it is set to beep or radio alarm). When the number is not lit up, the alarm is off.
Jun 09, 2009 | RCA RP5430 Clock Radio
Can't set alarm
Push the center botton on the back until you see WAKE I and then by holding it dwon push the bottons on either the right ir left of that button to set the alarm.... same process for WAKE 2...just have to push the center botton again
Jan 05, 2009 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Need operating instructions for RCA clock radio Mod. 5430
The instruction manual will not help you, because it doesn't address this problem head on.  You're having this problem because the time changed, and the clock has an automatic setting.    As long as the batteries are in the clock and it's plugged up, it automatically computes the time. I just discovered the solution.  Unplug the clock, take out the batteries and WAIT about an hour.  Plug it back up, and the time will flash, allowing you to change the time.  You do this with the button on the top back which says wake up 1 and wake up 2.  Push that button all the way to the right to the setting that looks like a little clock, then press the forward button on the top of the clock to set the correct time.  Then put your batteries in and you're good to go!  (til the time changes again:)  Good luck!
Oct 27, 2008 | RCA RP5430 Clock Radio
Setting the alarm on my clock radio
use the selector switch on the top, switch it to wake 1 or wake 2. set the time that you want that alarm to go off. then push the switch all the way back to the left to deactivate it. then to activate the alarm, use the buttons on top labeled wake 1 or wake 2 to turn the desired alarm on. pushing that button repeatedly will cycle the alarm to either beep, radio, or it will turn that alarm off.
Oct 21, 2008 | RCA RP5440 Clock Radio
RCA RP5420 Clock Radio Logo
338 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
