Question about Kenmore HE2 Plus Front Load Washer
Error codes "f1" "f22" etc. and washer stops at different times
Washer stops at different times sometimes after first cycle, and sometimes just before rinse and spin, sometimes before spin.
  • Kenmore Master
  • 8,220 Answers
Replace water inlet valve or clean water inlet screens. Remove the water inlet hoses and take a look see. Just guessing.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Washer stops before rinse cycle
Check the water level sensor.
Nov 25, 2013 | Maytag Washing Machines
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
Jan 23, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
749 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
