Question about Intel D101GGC Motherboard
Motherboard welcome screen is not visible on booting and pmain problem is after installation an OS it is not accessible
OS loading problem and after several effort setup screen is not cooming and flash message to Disk Boot failure .
  • 385 Answers
There is a problem with your hard drive. Either it is faulty and cannot be accessed or it is not in your BIOS boot sequence.
When it is starting, go into the bios settings and verify that the first boot device is set to your hard drive. If it is and still does the problem, then your hard drive is faulty and needs replaced.
Posted on Nov 01, 2007
Comp will not boot after installing a SATA DVD-RW
Perhaps your bios is set to boot from the 1st device it 'sees'.
When you add the dvd drive, maybe the device order gets shuffled up, making the dvd drive 1st. So, you need to check this by looking at the boot settings on the bios screen and change the boot order if necessary.
Sep 24, 2012 | MSI Ms-7529 V1.6 Motherboard Intel Lga775
No screen display
First of all see POST screen is visible or not if yes then second see OS booting screen is visible, with this you can judge the problem is with Motherboard/Memory or OS.
Aug 24, 2012 | EliteGroup P4VMM2 Motherboard
MSI P965 Pt Continually re-boots on start-up
You don't say exactly at what point in the boot sequence the system crashed and restarts. Many things could be at work here. You say you are using the HDD from the previous system. Did you swap this drive straight out and are still using the OS load from the previous system? Windows loads drivers at startup based upon the hardware installed. If you are using and old WIndows load with a new mainboard, this could be the entire cause of your crashes. YOu may be able to get to SAGE mode and remove the old drivers and try to restart the system, but from experience I will tell you that to get the best results when installing a new mainboard, you should reload the OS from the original OS disk, and then load the new mainboard drivers.
Dec 31, 2011 | MSI P965 Platinum Motherboard
Guys, can you help me with my laptop problem. windows is unable to load, i tried to reformat the HDD install new OS but still windows will not load. though I bring my laptop to service center but they told...
Hate to say it.. but yes your service center is correct. The motherboard or the back plane on the motherboard is not able to handle the windows load, just sits there stating it is installing .... but there is no progress on the screen.
I note, you stated that you have formatted the HDD, if you did not, the data on the disk could be prone to corruption.
To verify and/or prove a point ... I'll try another Operating System (OS) ... The freeware linux versions. Fedora Core or Ubuntu. You can download a "live CD" which starts the OS and if it starts, then it may not necessarily be a motherboard issue. From the liveCD you can then install onto your computer and install free versions of word, excel, etc .. I'd suggest OpenOffice.
Either this should assist in verifying you have a hardware related issue or not for loading any operating systems.
hope this helped ....
Oct 08, 2010 | Computers & Internet
How to dual boot xp and vista?
First of all partition a drive up. Make sure its a large capacity drive, something well over 100GB.
Boot the computer with CD/DVD set as the first boot device and pop the XPmag-glass_10x10.gif CD in the drive and allow setup to begin. When you come to the screen where you select the drive partition you should see the drive listed with all the space listed as unpartitioned. If the drive was in use previously, you'll need to delete all the existing partitions. To do this you'll have to hit the 'D' key followed by the 'L' key. The screen instructions will be visible to guide the process.
Once all the existing partitions are deleted the display will show the total unpartitioned disk space.
Hit the 'C' key to create a partition. Personally i partion mine to 80GB (81920MB)
On the newly created partition, (not the raw one) install XP on that. Carry on with the installation until its final restart, it will be a light blue screen.
Quickly pop the Vista disk into the drive and start the Vista install. When it askes where you want Vista choose the unallocated partition. If you let XP load up first then you will not have the dual boot option on start up.
If you have done this correctly then each time the computer restarts during Vista install you see a boot message on screen saying "older version of window(XP) and Vista.
Lets Vista fully install right up until it loads the welcome screen. Then you can restart the computer, choose older version of windows to complete and load the XP operating system.
You then have to switch between them both to install drivers, software etc.
If you want to use both operating systems at a time then you need a virtual operating system installed but they are not that good as memory is kept at a minimum.
Good luck and please post back if you need anymore advice.
Jul 15, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
I installed an HP P450 motherboard, pulled from HP D530 SSF Desktop, in a mini-tower case to build a home server, but when I power it up I get an ''HP Invent'' blue screen. The screen has options at the...
That is the BIOS boot screen, it doesn't go beyond that because it can't load the OS. You can disable it if you don't want it but it won't fix your problem - you can't just attach a hard drive with an OS and it will work, it never does and Network Service Boot means that you already have a network server with the appropriate OS for your motherboard. You will have to install the OS on that motherboard on your local disk or, if you still wanna use the Network Service Boot, have an appropriate server on your network that when the PC boots, it sends an extended DHCP request, and your server responds by sending a bootable image to the PC via the network and the PC then boots from this image.
Apr 09, 2010 | HP Compaq d530 SFF PC Desktop
My screen is stuck on the WELCOME screen, when I click my name to log in, my desktop is visible with no icons, then immediately logs off and returns to the WELCOME screen...
I think some of booting files missing..... due to virus affected . so insert the Xp os cd and repair it... after that scan ur computer with good antivirus .......
Feb 21, 2010 | Dell Dimension E521 PC Desktop
About "Error Loading Operating System"
Mitch to re-install your OS you must have the OS CD/DVD. If you have then follow these steps:
1). Insert your CD/DVD in drive and boot and see on the screen
....there will be message ..Press any key to boot from CD... then press any key
.... Your system will boot from CD and setup will start.
2). Just follow the on screen instructions.
if any problem occurs... Ask me
Mar 25, 2008 | ASUS P4S800-MX Motherboard
Intel D101GGC Motherboard Logo
47 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
