Question about SVA-USA HD4208 42 in. HD-Ready Plasma Television
I plug in the regualar cable from the converted cable box onto the back of tv and picture wont come out, but if I use a component cable i see the picture fine. What could be the problem and How can I fix it?
Sanyo 50in HDTV turns on fine, no picture or sound
How is your xbox connected to the tv? If its connected with hdmi cable. Unhook it from xbox and plug it into the back of the cable box. If nothing happens then try switching the tv input with the tv remote. Should have several different inputs. Hdmi,video,component,etc...
Feb 25, 2013 | Sanyo Televison & Video
I have a sony EX4|40 with built in Freeview. However, the port on the tv is a UHF (?) port (Im not technically minded, my port names may be wrong so I hope you know what I mean), The cable which runs from...
xtreamz_69,
It sounds like you connected the coax cable to your TV. What channel is the TV set on when you have the Freeview connected? Because you are using a coax cable, the TV should be set to either channel 3 or 4 (normally channel 3). Check to make sure your TV is on one of those channels. Also verify your receiver is on. Your TV has the several other type ports (HDMI, component, composite) as alternatives to pick up your picture. If you have any other questions, please post to this site.
Ray Calo
DISH Network
Jan 19, 2011 | DISH Network IR Remote Control
How do I connect my digital tv converter box to this plasma tv. My antenna in and signal out are both co-axial cable. Which input do I use on the back of the tv? Would I use a BNC adapter to coaxial...
Here is a cheap and easy way to connect this for you....
Get a VCR (often times can be found at goodwill or garage sales for very cheap) and connect the coax cable from the output of the Converter box to the Antenna/Cable in on the VCR then connect from the RCA output from the VCR to the TV. Tune the VCR to Channel 3 most likely and change channels through the converter box.....
Good Luck and please rate this solution....
Jan 05, 2010 | JVC GD-V500PZU 50 in. Plasma Television
How do I hook up my old VCR to an insignia tv?
You will need a converter to record onto a VCR. I can't remember the when the FCC require VCR to have digital, but I know yours old enough it has an analog tuner. Take your antenna connection to the in on the converter box, then you can take the out from the converter box to the in on the vcr and finally take the out to tv to the tv. To record you have to have the vcr on 3 or 4 and use the converter box to do the channel changing.
Another way would be take the in to the converter and use RCA cables to the line in on the vcr, and line out to the to the tv. This will give you stereo sound.
Aug 10, 2009 | Panasonic Televison & Video
Color bars only on KWorld PC to TV - Composite and SVideo
found this reference it may be of help
This product appears to be defective. I connected it to a working video camera that produces an excellent picture on a standard monitor. I looped the video from the camera through the monitor to the converter which is connected to a new ACER LCD display. The LCD display workes perfectly when connected to my computer. Using the converter, the results are poor. You can see the desired picture in the background but in the foreground there are horizontal bars that scroll vertically through the picture. I'm returning it for an exchange - will try again.
Jul 26, 2009 | KWorld PC to TV (0872880887527) Video...
Sony Wega TV --24F... does it need a converter?
No. all flat screens have converter chip built in.
If you are having problems getting channels, make sure you go to the settings, and broadcast settings, and make sure it is on AIR for regular tv, or CATV for cable.
May 05, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I cant get my dvd to play using my rf modulator
instead of plugging in the rf modulator before the cable box, i plugged it in after it
Jan 24, 2009 | GE 25GT240 25" TV
My tv broke that i had my converter box hooked up to so bought another one now i cant get a signal, my converter box wont stay on.
if it is hooked up through the componant, or composite cables, that is the red white yellow, or the red blue green red white, you have to take note of what input it is plugged into on the back of the tv, they are labled, then hit the input on the remote control to match the input your plugged into, even if your using the screw on cable, stioo have to put it on that input, also try turning your tv to chanel 3
Jan 08, 2009 | Televison & Video
My HDTV has no HDMI and I'm not getting a picture on the TV except for the Yamaha Backscreen
tell cable box 480 i putput not 720 p even tho big screen has hd inputs its not true hd ok unplug plug back in see if get cable box to defult u or take card in front in and out most likely tv cant handle 720 p or 1080 i if its on 1080 i bring to 720 still no pic tak ethe cable box out settings to 480 i ok try that 1st
Jan 06, 2008 | Yamaha RX-V2700 Receiver
SVA-USA HD4208 42 in. HD-Ready Plasma Television Logo
41 people viewed this question
Top SVA-USA Televison & Video Experts
Michael Galve
Michael Galve
Marvin
Marvin
Adorjani Laszlo
Are you a SVA-USA Televison and Video Expert? Answer questions, earn points and help others
