Question about Kenmore 22422 Top Load Washer
Whirlpool washer won't drain or spin.
It fills and it washes but it won't drain or spin. I checked the lid switch. It's not that.
  • Victor
    Victor May 11, 2010
    Hi, Do you get any noise from motor when it goes into spin cycle? Does it agitate ok?
  • Kenmore Master
  • 8,220 Answers
Bra, thong sand coin or other inanimate object in pump. Easy fix. Check out the GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
Lid is not locking properly, washer sensor is overfilling, and the washer wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 28, 2013 | Whirlpool WTW4950XW Washer
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
My whirlpool cabrio washer #wtw555oxwo won't work. The lid lock light keeps flashing and the washer won't start
Possible that the switch is defective, there is fault in the line to the control unit from the switch of the control unit is faulty.
check these one by one.
Sep 03, 2012 | Whirlpool WTW5550XW Energy Star Qualified...
Whirlpool LSQ9544KQO won't spin
if it fills with water and then nothing check the lid switch,if it's bad it won't do anything but fill,some will agitate but then no drain or spin,the easiest way to check it is open the lid a few inches and close it,do this a few times,if you don't hear a clicking sound the switch is bad,or open the lid and stick a screw driver into the hole on the right side where the strike from the lid goes into,if it doesn't click when you push it down and let it up it's bad,part number 3949237 and it's around 50 dollars.watch this video,it's a different lid switch but changes out the same way.
http://www.youtube.com/watch?v=MFsvLiuTniU
you can also stick a jumper wire into the two outside wires to check it,flip up the top console,you'll see the lid switch connector on the right side plugging into the top of the frame,unplug it,stick the jumper into the connector that unplugged from the frame and it will have three holes in it,the middle is ground so stick the jumper into the two outside holes,set the timer to drain and pull out the timer,if it starts to drain and spin then you know the lid switch is bad.hope this helps.
Jun 04, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
The washer fills up with water and doesn't do anything else. the water is still in the washer.
check the lid switch,set the timer on spin,open the lid and stick a screw driver into the slot where the lid strike normally would close down into,push up and down it should make a clicking sound and the washer should start to spin and drain out the water,if it doesn't click ,spin and drain the lid switch is bad.
Apr 01, 2011 | Whirlpool LSB6200KQ Top Load Washer
My whirlpool top load washer won't drain and spin
This is likely to be a problem with the lid switch.the lid switch is activated by the lid stricker when you lower the lid.these machines will normally fill & wash without needing the lid closed but when it gets to spinning & draining the lid must be closed,so the machine is acting as though the lid is open.the lid has probably been dropped or slammed shut & this can break the lid switch from where it mounts with 2 phillips head screws.
May 31, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
Oct 27, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer fills up with water but does not spin or drain
it may have a bad lid switch you can bypass it to check
Apr 17, 2009 | Whirlpool Washing Machines
Kenmore 22422 Top Load Washer Logo
172 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
