Question about GE DVLR223 Dryers
Installed new motor in my old ge dryer ddg6580gdlwh and it trips the breaker. the thermostat fell apart while working on it however i reasembled the thermostat and when i pluged it in and try to turn it on it triped the breaker. any ideas?
  • Victor
    Victor May 11, 2010
    Hi. It sounds like the thermostat needs replaced. Make sure the wires or located on the motor in proper sequence. Check the connections on the door switch to be sure they didn't slip off.
    If it is a direst short, there is a bad wire somewhere.
  • GE Master
  • 8,220 Answers
I bet you did not get the center bearing in exactly right and the drum rubbed against the element. Seen it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
Put a new heating element in new upper and locer thermostats and new thermal fuse dryer still won't heat what could be the problem
Check the house circuit breaker panel. The breaker for the dryer is two separate breakers with their handles joined with a wire so if one trips the other one will too. This doesn't always happen as it was designed to do . If one breaker trips but not both, you will have the controls , lights and motors working, but not the heating elements . Replace the breaker because simply resetting it will not be a lasting fix.
Nov 20, 2015 | Dryers
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
Dryer keeps tripping the circuit breaker
hello mam please change the mains breaker after tripping for several times the breaker will be defected and check the power socket outlet by removing the socket there should not be any loose connections and skinned wires.
Oct 02, 2009 | GE Profile Harmony DPGT750EC Electric...
Ge dryer just stop working is there a circuit breaker in the dryer
basic problems]
First check these:-
1) Over load cut off (try running it empty)
2) circute failur and fuse blown
Sep 20, 2009 | GE DBSR453EBWW Electric Dryer
GE DVLR223 dryer wont start....breaker is not tripped
check all the connections on the back of the dryer, if a few screws are loose, that could be the problem.....now the other thing....it might need a new motor. Unplug it before checking it out!!
Clean out your vent hose and the outside of the Vent to prevent fires.
Jul 31, 2009 | GE DVLR223 Dryers
Dry trips breaker
breaker is tripping from faulty insulation allowing current to ground
breakers work on milliamp current so it requires a mega meter to check the insulation
call a qualified electrician to check the unit
Sep 18, 2017 | KitchenAid KEYS750LQ Electric Dryer
G.E. electric dryer terminal block and wires are burnt. I took the dryer apart to clean the inside of dust and lint. I put it back together and plugged it in. The breaker tripped,and I looked at the...
you did not say how old? but I find that all it takes is one wire to get old, and starts to heat up because electric cant flow through it, then it gets worse and worse fast, then heats up the whole block, till the whole thing gets melted...bad thing is its happens slow enough that the standard 30 amp breaker won't trip during this slow melt down!
Mar 13, 2009 | Kenmore 64902 Electric Dryer
HE4 Kenmore Dryer tripping Circuit Breaker
If you put a light load in the dryer will not trip the circuit at all. That means heavy load made the motor work harder and over heat, it going to trip the circuit , pretty soon, the motor will be warn out.
Jul 01, 2008 | Kenmore Elite HE4 Electric Dryer
GE DVLR223 Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
