Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Fisher and Paykel Active Smart® -E402B
Active Smart, beeping about every twelve hours, indicates fault in top refridgerator compartment, evaporator in freezer icing up heavily, have manually defrosted, both fans operated when bench tested. What components should I replace?
  • jaydave160 Jun 14, 2009
    Are there any other different opinions on the solution to this problem. Do you replace both sensors in the fridge and in the freezer?
    Very helpful. will check out as you recommend.
    DJ
  • 1,170 Answers
Good day
You freezer sounds like the self defrosting function has failed. If the evaporater coil freezes up, it gets really cold, but the air in the top of the freezer gets warm, so you could have stuff towards the top of the compartment melting, while the bottom is super cold. The heating element, thermal limit switch, or the timer could be bad. I am not particularly familiar with this model, but most have a little timer motor mounted behind the toe kick somewhere that contrlos the defrost intervals. The timer sends power through the thermal limit switch, located on the inlet tube of the evaporater (coils that get cold in the freezer) and keeps the heater from over heating. This part is probably the most common failure. From the switch, power goes to the heater element, which is mounted directly to the evaporater. If the heater looks kind of like a bake element style (similar to what you'd find in the bottom of your oven) then its probably not bad. If its a glass tube style, then they fail more commonly. Hope this helps, good luck! P.S. this could all have been caused by a door left slightly ajar overnight too...if you think that may have happened, then just turn it off and leave the door open for a day or 2...it'll defrost and be fine!
Hope I helped with the repair of your problem.
An Accept from you is how I get paid.
And a positive feed back tells me how I did with the repair.
Regards,
Arjun.
Posted on Jun 14, 2009
  • 378 Answers
It seems that your thermostat failed to control the temp. or it was set to the max cold. check or try reset the temp. if still unsolved try change the thermostat.
How do i take the bins out of the freezer? fisher and paykell product no 20717 model E372B.
Text, manuals and videos.
[PDF]Installation instructions and User guide - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../838360b-nz-au-gb-ie-eu-ae-hk-sg-refrigerator-active...
Never freeze liquids in glass containers. Liquid expands during freezing, which may cause the container to explode. ?. ?. Never freeze carbonated drinks. They may explode. ?. ?. Do not consume food if it is too cold. Food removed from the freezer compartment may be cold enough to cause damage when brought into ...
[PDF]Refrigerator & Freezer - Fisher & Paykel Appliances
https://www.fisherpaykel.com/.../821187-nz-au-gb-ie-pac-refrigerator-freezer-guide.p... Food removed from the freezer compartment may be cold ... E372B. E381T. E402B. E411T. E415H. E406B. E413T. E440T. E442B. E521T. E522B. A inside height. 853 1255 1635 1255 1635 1475 1735 1465 1635 1735 1635 ..... The humidity lid seals the bins to provide a humid microclimate to extend storage times of fruits.
Page 41 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Permanently fixed bins and trays (Freezer drawer models only). The freezer bins and trays in this model are permanently fixed. They cannot be removed from the. freezer compartment. To clean simply wipe with a soft, damp cloth. On vacation/holiday.. Turn the ice maker to OFF on the internal control panel (refer to page ...
Page 25 of Fisher & Paykel Refrigerator E372B User Guide ...
kitchen.manualsonline.com > ... > Fisher & Paykel Refrigerator Remove all frozen food and wrap it in several layers of paper. Place food in the refrigerator. compartment or a cool environment e.g. insulated picnic bin. Switch the power off at the wall. The temperature control can remain at its normal setting. Remove the freezer baskets or shelves for ease of cleaning. Whilst defrosting ...
Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A ...
https://manualsdump.com/en/manuals/fisher-and-paykel-e442b...e372b/.../41 Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins ...
Refrigerators - Removing & Replacing The Drawer on Vimeo
? 2:35
https://vimeo.com > Fisher & Paykel Technical > Videos
Jun 29, 2012 - Uploaded by Fisher & Paykel Technical
This video shows the proper method for removing and replacing the drawer on Fisher & Paykel ...
Ice Storage Bin - Fisher & Paykel ActiveSmart E372B Installation ...
https://www.manualslib.com > ... > Installation instructions and user manual
Fisher & Paykel ActiveSmart E372B Manual Online: Ice Storage Bin. All models When going on vacation/holiday we recommend cleaning your ice bin and discarding...
[PDF]Fisher & Paykel RF522ADX5 519L French Door ... - Winning Appliances
https://www.winningappliances.com.au/.../Fisher---Paykel-RF522ADX5-519L-French... Note: non-Ice & Water models do not have an external water dispenser. Refrigerator French door and freezer drawer. Refrigerator door and freezer door .... 9. Installation instructions. Product dimensions (mm). E372B. RF372B. E402B. RF402B. E442B. RF442B. E522B. RF522B. A overall height of flat door product. 1620.
fisher & paykel e522b manual
https://sway.com/JxXqIwtViE8mDVwl Products 1 - 20 of 23 - Shop with confidence on eBay! Fisher & Paykel E372B, E402B, E406B, E442B, E522B, RF522A, RF522W, RF540A, RF610A To remove trays or fixed bins, To replace trays or fixed bins:, Permanently fixed bins and trays (Freezer drawer models only), On vacation/holiday . To remove trays or fixed bins, ...
fisher and paykell E372B remove freezer bins Google Search
Feb 18, 2018 | Fisher Refrigerators
Fisher and Paykel Active Smart fresh food compartment indicator is blinking continuously.
flashing lights and beeps indicate a component failure. Count the beeps and provide details here.
Jul 16, 2016 | Fisher and Paykel Refrigerators
I have a fisher & paykel active smart fridge the fridge part freezes everything and wont stop beeping when door open
Your fridge is telling you there is a fault, i'd say one of the 2 fans are not working. If everything is freezing in the bottom of the food compartment then the upper fan is faulty. You have to remove the shelves & remove the rear panel, the fan is in the shute at the bottom, remove, repair the broken wire or replace. Make sure unit is unpluged.
Aug 10, 2014 | Fisher and Paykel Active Smart E522B...
E402b beeps once every 5 minutes
It's alerting you to a fault, maybe a fan or a heater element etc. Call F&P customer care.
Nov 29, 2013 | Fisher and Paykel Active Smart® E522BR...
E402B model alarm comes on every 6 to 8 hours. fridge not cooling we have to reset it why?
ck the fans under neath and clean the coils as this the most common for your problem. . also ck the fan in freezer . it runs when the compressor is working . and if it not not enough cold .. ****
Jan 04, 2010 | Fisher and Paykel Active Smart® E522BR...
Uneven cooling in fridge and annooying alarm every 10 hours!
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 28, 2009 | Fisher and Paykel Active Smart® E522BR...
Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
Jun 13, 2008 | Fisher E522BLX Stainless Steel
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
417 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
