Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
It doesn't show up on the computer and the light on the flashdrive doesn't turn on
  • Jonathan Larson May 11, 2010
    does it work in a different computer? or do other flash drives work in the USB port?
  • tomas sidlauskas
    tomas sidlauskas May 11, 2010
    dou you try different usb ports?
  • 53 Answers
Sorry but you have a busted pen drive....
Posted on Jun 23, 2009
2 Suggested Answers
babes_ganda0
  • 381 Answers
SOURCE: it doesn't show up on the computer and the light on the flashdrive doesn't turn on
update the drivers of USB
Posted on May 23, 2009
Cruzer flashdrive light doesn't light up
Use this USB drive on another working computer to check if your OS has any problem or not. If the drive is detected and you can access the infos stored in this drive, repair your OS, and if not, go to your nearest service center to avail a full replacement or repair.
Hope this helps, Mrityunjay.
Jun 26, 2012 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
My computer which runs Windows 7 can not detect my Jetflash 500 16gb flashdrive
It should be able to automatically detect and install it. Try using it on another computer that has either Windows XP, Vista , or Windows 7 on it. If it doesn't automatically detect and install it on that one then the flashdrive is dead.
May 14, 2012 | Transcend TS16GJF500 16GB JetFlash 500 USB...
I have a 8gb flashdrive for a xobox 360 and i cannot access it no matter waht i try and for some reason it doesn't even light up what do i do?
Are you trying to use it as a memory card? TO do this you need to format it. If the light's not coming on it could be that the USB port is broken.
Apr 23, 2012 | Video Game Consoles & Games
After copying 3.4 Gbyte or about 600 jpeg's to my Imation flashdrive 2.0 (4Gbyte) using my Apple Mac OS 10.5.8, I formally ejected the drive and inserted it into our Vista Windows machine. The Vista...
Plug the flash drive into the windows PC first and open "Computer". Find the drive and format it to Fat32 or NTFS. Now plug it into the mac and copy the pictures too it. Now your Windows computer should see the files. Mac will default to making the flash drive use HFS+ filesystem. Windows doesn't recognize this format at all. Mac will see fat32 and ntfs just fine though.
Aug 28, 2011 | Computers & Internet
How do I download pictures from my computer onto a usb-16gbtr, there are no instructions with the flash drive
Just plug the Flashdrive into the USB port of any Computer and the Operating system ie: Windows should just pick it up with Auto play after a few seconds. Open the FLashdrive under My Computer?Computer(depends on the version on windows you are using) Open the Mass Storage device or the drive that shows the Flashdrives details and then just copy your pictures from the folder which you saved them and then Paste them into the Flash drive.
If you want a more detailed description, just let me know what Windows or Operating sytem is on your Computer or the device you want to download from and also the make and model of the Flashdrive.
Hope this helps
"Even your Computer needs a rest"
www.thecomputerspa.co.nz
Jan 31, 2011 | Computers & Internet
Heating up, light not coming on
cruzer micro 4GB, loaded with data. works perfectly in all systems except my xp. Problem didn't originate until after ghosting system to correct different problem. Now, error message states flashdrive not recognized. must then get behind pc, and gently work with it until i can hear the shift in the duo core processors and the orange light on the flashdrive comes on. Please help.
Mar 10, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
SanDisk 8GB lights up but wont register
This one is just a hunch. The drive might be bad but this is worth a try. Its possible the drive letter somehow changed on the flashdrive. Plug in the drive, RIGHT click on "My Computer" and select "Manage" from the drop down menu. Now select "Disk Management" from the list. If you see your flash drive on the list, right click on it and select "Change drive letter and paths", then click on "change", now assign it a new letter like "F" for example. Click ok, ok, ok. If it showed up the the list and it's still not registering, unplug it and plug it back in. Hope that helps.
Feb 15, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Problem
Hello!
Hopefully I can try to walk you through a process that I would use.  First check to see if the flashdrive is damaged.  Usually the cases don't break, but the USB connector itself takes a lot of hits/damage/wear.  You should be able to see 4 metallic contacts on the USB connector and they should be in good shape.  Blow out any dirt/garbage in the connector as well.
Next is to see when you plug it in if the LED on it lights up at all.  If there is no light whatsoever, it is one of two things, either the flashdrive is totally broken or you have a failled USB port.  Either one is possible.  If possible, take the flashdrive and test it on another system, or at least another USB port.  That will give you some important information.
Assuming that the LED lights, then it is a question of getting Windows to recognize the drive.  If there is nothing important on the drive, fdisk the drive in DOS, then format it, and then Windows should recognize it, allowing it to be used.
If you have no LED lighting on the flashdrive, after testing on another system as well, get another flashdrive (or return this one if under warranty), since there are no real parts to service/fix.
Hope this helps out!
Ken
Jan 06, 2009 | Computers & Internet
Toshiba 4mb jump drive
try to jump from one usb slot to another until your computer recognizes your flashdrive.
Mar 25, 2008 | Computers & Internet
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
192 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
k24674
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
