Question about Safety 1st Acella LX - Navy Stroller
Unable to remove canopy of stroller
I have this stroller though its not blue...I have a problem removing the canopy to wash it...
At first glance it appears be engineered to be easily removed just as all the other fabric pieces are. The canopy is attached three ways: threaded through a slim bar near the stroller handle held on by 2 little screws, a zipper that unzips to allow the canopy to slide off the frame and then its threaded through a hoop attached to the frame of the stroller. The screws and zipper are easy to detach however I cannot unthread the canopy from the hoop that holds the canopy in place when it is extended. The hoop seems to be riveted on both sides to the frame of the stroller. There has to be some kind of solution without popping a rivet. Please help.
  • 12 Answers
SOURCE: Squeaky Wheels
To remove the wheels there are a plastic cap over the nut and if you can take that off that unfasten the nut and it should come off clean. The wheels might be squeaking because you might have them on to tight.
Posted on Dec 30, 2007
SOURCE: Replacement footrest
What brand is it? Look up that company online or contact them by phone. Most companies should have replacement parts available if the stroller isn't too old. Good luck!
Posted on Aug 21, 2008
SOURCE: Instructions on putting stroller fabric back on stroller..
you can download the manual here: http://www.safety1st.com/instructions/.
Basically, the easiest way is to put the back in, then start at the bottom and work your way up.
Posted on Oct 10, 2008
SOURCE: Maclaren Triumph Stroller Canopy replacement - scarlet
You can order replacement parts at maclaren.com
Posted on Apr 21, 2009
SOURCE: Maclaren double stroller canopy
I need a double canopy for a black twin traveller maclaren
Posted on Sep 02, 2009
I have a safety1st stroller that i need to wash, but i can't take it all the way appart especially the canopy part
Goodmorning,
You could try very patiently with a screwdriver to remove the stroller cover (the chair part) as well, but you have to be very patient with the strap/belt. Then once it is completely removed, you could wash it at a very low temperature in the washing machine and dry it in the open air.
Good work!
Celeste
May 31, 2011 | Safety 1st 01929PAC Travel System Stroller
Want to wash baby jogger twin strawler. cannot remove the canopies
canopies are secured with snaps correct? your probably not being aggressive enough unsnapping them, good luck
Nov 26, 2010 | Phil & Teds E3 Twin Seat Jogger
Removed the canopy on model6490fkb and don't know how to replace it
did you remove the front or back canopy? The back one will go in, but you just have to shove it in really hard. Not sure about the front?
Aug 24, 2010 | Graco DuoGlider 7924 Twin Seat Stroller
Can the canopy be removed from a Peg Perego P3
Yes, it can be removed. Where the canopy attaches to the stroller you will see a clip like devise. Push the buttons down and slide the hood up the frame at teh same time. it should slide right off.
Mar 20, 2009 | Peg Perego Pliko P3 MT Classico Umbrella...
Frog canopy removal
Pull gently on the plastic arches that support the canopy (on either sides - where they connect to the stroller) and slide the canopy off.
Nov 05, 2008 | Bugaboo Frog Stroller
Cosco Eddie Bauer Stroller Canopy
the lower frame bar locks the canopy onto the frame. Remove this and remove the brackets from the frame. drill out the rivit on one side (take note of the location of the snap and washers) and then remove the frame from the bracket and canopy. you then use a 1 inch 5/32 rivit to reassemble.
Jun 22, 2008 | Cosco Eddie Bauer Lightweight - Blanchard...
Eddie Bauer Travel System - Removable Hood??
Took me awhile to figure this one out...
There are two bars attaching this hood to the stroller. The rop bar is obvious and removed by taking out 2 phillips head screwdrivers.
The bottom bar seems much more tricky as it seems "permanent".
Upon closer inspection, the lower metal "hood bar" goes into the side of a round clip. This round clip has a button snap in the middle of it. This round clip can be removed by pulling on it (not intuitive at all). It is not bolted on. It turns out it only encircles the metal bar it is attached to 3/4 of the way like a c-clip and will stretch to come off. You cannot remove the bar from inside the hood, but you can toss it all in the washer! Good luck!
May 24, 2008 | Eddie Bauer Lightweight Travel System...
TAKING OFF THE CANOPY
There are two tiny screws on each side of bar the the canopy is wrapped around. Unscrew them and you will able to slide it right off!
Oct 26, 2007 | Eddie Bauer Lightweight Travel System...
Safety 1st Acella LX - Navy Stroller Logo
310 people viewed this question
Top Safety 1st Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Safety 1st Baby Gear Expert? Answer questions, earn points and help others
