Question about Kenmore 700 6973 Dryer
How to hookup side exhaust vent on a Kenmore dryer?
    Problem Solver:
  • 9 Answers
Go to a hardware store and ask for a dryer hook-up kit. You can run the vent to an outside source through a wall or if needed you can exit the exhaust through a roof although I would not do this unless it was the last resort. Instructions for the dryer hook-up are included with the materials.
It consist of connecting a vent hose usually 4 inches to the dryer outlet and running the hose usually a flex hose to another outlet that vents the dryer air outside. The outside connection should have a door that closes when the dryer is not in use to keep rodents and pest out.
Posted on Jun 14, 2009
How to clean blower on kenmore dryer model #592891070
Make sure lint isnt traped in route between lint compartment and vent line hookup
Sep 06, 2014 | Dryers
Kenmore #11066742500 dryer
Could be several things. If it is a new hookup the neutral and one of the hot wires has been reversed. If it just started doing this the most probable is a shorted heating element. It will still test good on continuity test but part of it is touching the frame. The third thing is a bad thermostat, it would be cycling at too low a temperature. The temperature coming out of the exhaust should be between 150 and 175 at high heat.
Jan 21, 2012 | Dryers
I have a kenmore dryer 80 series. it takes two cyclyes to dry clothes and they come out smelling musty
Check the vent hose! Have you ever cleaned out the hoses? This can reduce your drying capabilities drastically! Not to mention create a FIRE HAZARD. If you haven't done this since having the dryer installed, you should do it asap. Also check the hookup for the hose & make sure it's not blocked & is the proper material (e.g. not vinyl or plastic)The most common reason is that the exhaust vent is clogged. Longer vent ducts to the outside are more prone to this problem, so if your duct is only 3 feet long, that probably isn't it unless it is completely blocked. If the duct is 6 feet long, or longer, clean it first to see if that will help. A cleaning kit is easy to find and not expensive.
Oct 26, 2011 | Dryers
How do i change the high limit thermostat on a kenmore dryer # 72822
Unplug the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the back of the dryer. Loosen the retaining screw on the clamp connecting the vent to the dryer's exhaust port and slide the vent off of the port.
Remove the hex nuts holding the dryer's rear panel in place and slide the rear panel off to the side of the dryer. Locate the high-limit thermostat on the heating element housing on the right side of the dryer. The oval-shaped thermostat can be found a few inches from the bottom of the heating element housing.
Unplug the two thermostat wires by sliding them off of the thermostat's contact posts. Slide the old thermostat out of the socket on the heating element housing.
Mar 12, 2011 | Kenmore 72822Gas Dryer
Need to change vent from rear to left side
why don't you just go to home depot and buy a longer flex hose?mike
Feb 19, 2010 | Kenmore 64942 Electric Dryer
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Cant locate vent exhaust
the vent come out at back or sometimes bottom side you cant miss it
Jun 21, 2009 | Kenmore 63942 Dryer
I have a kenmore electric dryer.When I push to start ,the timer ticks but do not start.The door switch is working.When I open the door the ticking stop.What can this be?
Replace the thermal fuse located on the rear of the dryer.
Remove the rear panel the thermal fuse is white about 1 and 1/2 inches long by 1/2 inch wide.It is on the exhaust vent on the left side near were your connecting vent attaches.
Apr 12, 2009 | Kenmore Dryers
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor  and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor  and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here  + new25.gifExpanded repair helps for a common "Even Heat" dryer
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
Kenmore 700 6973 Dryer Logo
372 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
