Our washing machine agitator isn't spinning properly.
Could the directional cogs (dog ears) be stripped out? If so, those look easy to replace.
  • Washing Mach... Master
  • 8,220 Answers
The face of the individual little puppys wear smooth and won't grab the inner walls of the upper agitator. Read the fermented grand master's excellent page on this here subject right ova HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
My washing machine wont spin
The dogs inside the agitator are probably stripped. Take the cap off the top of the agitator and you will see four what we call dog ears. Real easy to change. Cost about $30.
Dec 21, 2017 | Washing Machines
Agitator won't spin. Only swivels back and forth when I apply direct pressure down on the center of agitator.
This a very common concern and an easy and cheap fix the agitator cogs are worn out you can order the parts online part number wpl285751 or just 285751 about $4.00 (agaitor directional cogs) or dog ears. or a complete repair kit #285746 about $14.00 I would go with the kit. With parts in hand pop of the fabric softener dispenser then you will see an agitator cap with a pair of pliers pull up and remove the cap,now you will see one bolt remove this bolt and you will be able to remove the top part of the agitator replace you worn parts and reinstall and you will be agitating like new,,,Sounds like a lot I know but its really a 10 minute job Good Luck
Sep 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agutator doesn't go around properly-the cogs at top are stripped-how do I replace?
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Also see the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=58c8c3ef065dd7bf04758c8088fe09a7
Dec 18, 2009 | Kenmore Washing Machines
Machine does not agitate, will spin and rinse including.
Hi,does the top part of the agitator move freely when you move it by hand?Or does it catch,if it does not catch the the cogs other wise known as dog ears are worn out.Do not believe the little cogs that catch inside the top part of the agitator can be replaced.You may have to replace the whole agitator unit on some models they are around 40.00.
Apr 11, 2009 | Maytag PAV2300 Top Load Washer
Washer won't spin
pull the fab soft dispenser out and pry off the cap that sits on top of agitator looking down inside there you'll see 4 pieces called agitator directional cogs(dog ears) they are worn and need replaced
Apr 06, 2009 | Kenmore 22422 Top Load Washer
We have a modle # LLR7144DQ0 - the agitator is not working properly. It is not pulling the clothes down into the water.
The agitator 'dog ears' have worn out. Very easy to replace.
  • Remove fabric softener or protective cap on top of agitator
  • Remove center bolt securing agitator.
  • Lift out agitator and replace dog ears.
Jun 23, 2008 | Whirlpool Washing Machines
WEAK AGIATOR
Does the agitator shaft turn real easy or does it stop or keep from turning 360. It should have limits and not free wheel or turn around and around. Does it spin correctly? Most generally the parts you are looking for would be accessed from beneath the unit. Not sure about what dog ears are but there are plastic pieces that make the unit shift from agitate to spin on some models. If it has slight resistance to turning the agitator shaft but will turn 360 the gear in the transmission is probably stripped out. Do a little looking from the bottom and turn the shaft while looking at the bottom to see if you can tell what is out. You might find broken parts on the floor under the machine...
Feb 10, 2008 | Washing Machines
Adjetator (sp) isn't spinning properly .
The agitator dogs (little dog ear gears) are stripped. This is a very easy fix and the new dogs are very cheap. Go down to an appliance part store and ask them for agitator dogs for a direct drive whirlpool washer. Ill help too with installtion
Jan 12, 2008 | Washing Machines
Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Nov 02, 2007 | Washing Machines
Agitator won't spin back and forth like its stripped
I think what you have going here is some worn agitating ears. In the appliance world we call them dog ears. You have to remove the fabric desp, it should just pop off. Under there will be a cap that you can grab with a needle nose pliers and pull the cap off. Now you will be looking at the bolt that holds the agitator to the shaft. Remove this bolt and you can get to the dog ears and plastic bearing. There is a kit for this and the part number is 3951682. This is not a hard fix...just take your time and observe. Catriver...post back.
Jul 29, 2006 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
