Question about 5900 SST 2-Way Security System / Remote Start System with Responder S
Viper 7701 i just put a new batter in my viper 7701 remote, now it plays the song like it going to die but nothing will come up on the screen and it wont work starting or opening the car what do i do,
  • 212 Answers
SOURCE: battery died in the remote and now car remote wont unlock security
try another battery. maybe that one is bad also. contact the security system manufacturer or a viper dealer. They will help You.
Posted on May 24, 2009
  • 50 Answers
SOURCE: Viper SST 7701. I replaced
Try to relearn the tach by cranking the car and holding the valet switch(small black push button) until the LED lights solid.The try it again
Posted on Aug 14, 2009
  • 5 Answers
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Posted on Oct 09, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
I have a viper 5900 car alarm with the 7701 vpx remote and the lock and unlock are reversed. How do I fix this
according to Viper tech support (I emailed them your question):
Thank you for contacting Directed support!
You may need to reprogram the remote to your phone. Please use the following instructions to reprogram the remote:
To program the remote to your system please do the following:
1) open the driver door
2) turn the key to the "on" or "run" position
3) locate the valet switch (small black button under driver side of dash) and press once, release, then press again and hold
4) after the siren chirps one time press the lock button on the remote
5) the alarm will give you a unique confirmation tone
6) turn the key off (the same unique tone will be heard again)
Warm regards,
Nigel McGee I Customer Service Rep.
Viper Support
Apr 28, 2016 | Viper Vehicle Parts & Accessories
I have a viper 7701 remote that just stopped working. Battery is new. Do I have to re program something
If it is the OE (original equipment) key fob, meaning if it is the alarm remote control that came with the original purchase of the car it should not need reprogramming. If it is an aftermarket alarm then it may need reprogramming, more information is required to answer the question.
This is a common issue and the most common problem is that the solder joints holding the battery in the proper location. If any of these are broken the remote will not function. It can be fixed with a little solder or if your uncomfortable with doing it yourself, take it to a computer repair store (they can fix it ONLY if you have a broken solder point).
Take the key fob to the closest auto parts store (aka. autozone, o'reilly's, advance) and near the counters they have a key fob testing equipment (FREE). If the remote is working a light will blink when you push the key fob button while close to the testing equipment. If the testing light shows that the fob is working but does NOT unlock your doors, it needs reprogrammed. If the testing light doesn't blink at all, repair or replacement of the key fob is indicated.
Hope this helps and good luck!
Dec 31, 2014 | 7701V Remote for Viper Responder SST Car...
I just purchased a 2007 Mazda3 S Sport Sedan and it came with a Viper 7701 intalled. I need to know where I can download the manual to help with turning off the alarm during thunderstorms and just general...
http://www.directeddealers.com/manuals/og/viper/G5301V_05-06post.pdf
the 7701V is actually the remote. The Viper remote start alarm system that it corresponds with is the Viper 5900.
Mar 21, 2011 | 7701V Responder SST Remote
Battery died in the remote and now car remote wont unlock security
May 24, 2009 | Directed Electronics 479V Remote Gen 2...
Wont unlock or lock on my 06 tacoma
If you have replaced the battery in the remote, go to the fuse box and check the fuses.
Jul 29, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper SST 7701. I replaced the vehicle battery and now the 2007 Saturn Outlook will not start. How do I program the Viper system to allow it to start?
Nov 26, 2008 | 5900 SST 2-Way Security System / Remote...
Viper 791 XV Automatic Start Not Working
Try putting the key in the key cylinder but do not turn it at all. Then try and remote start the car. If it works then your bypass module is bad and needs to get replaced.
Nov 17, 2008 | Viper Security and Remote Start System...
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
5900 SST 2-Way Security System / Remote Start System with Responder S Logo
199 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
