Question about Hotpoint Aquarius WMA42 Front Load Washer
Drian clog we have drain clog problem.
  • Hotpoint Master
  • 8,220 Answers
I use a wet dry shop vac to fix them drains.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
My whirlpool dishwasher quiet partner I does not drain, need help
MAY HAVE A CLOG IN DRIAN. OR DRAIN PUMP MAY NOT BE WORKING.
Sep 19, 2011 | Whirlpool Dishwashers
Dont drain
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Daniel
Aug 31, 2011 | Kenmore 24032\24036 Top Load Washer
WONT DRAIN PROPERLY
Hi
Daniel
Aug 08, 2011 | Tecnik TKL9260 Front Load Washer
My diswasher has alot of water in it after we run the dishers thru. May be a clog? How can i check if there is a clog?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 19, 2011 | Hotpoint Dishwashers
Won,t drian the water.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Feb 21, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
My portable GE dishwasher is clogged and wont drain
Hi
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
Kitchenaid dishwasher KUDI01TJWHO will not drain. Where do I check for a clog?
Hi
Feb 09, 2011 | KitchenAid KUDR01TJ Dishwasher
My maytag dishwasher won't drain. It is not clogged. It just won't drain
Hi
Jan 31, 2011 | Maytag 24 in. DWU9202 Built-in Dishwasher
It won't pump out the water.
Hi
Oct 25, 2010 | Frigidaire Dishwashers
Drain is plugged, leaking water
Hi
Oct 20, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Hotpoint Aquarius WMA42 Front Load Washer Logo
55 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
