Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana refrigerator not running but light and water dispenser work
Hello, I was out of town for a week, and when I returned, my Amana SPD26VW refrigerator/freezer was not running. All contents in refrigerator and freezer were room temp. Light works, as does water dispenser. No sounds (like fan, compressor, or other moving parts) coming from it anywhere. Appreciate any help. Thanks.
  • wronko Jun 14, 2009
    Thank you both for your quick replies. Last night, I did some online searching for a solution also, and suspected the defrost timer. I manually turned it -- no response. Got to the point where it clicked, then went slightly past that point, and it clicked again. I assume that the 2 clicks were the defrost cycle on, then off. Past the second click, still no action. So I put the notch in the dial to the "9 o'clock" position to see if it would move over time. Went to bed. Got up this a.m., and the fan was running. Looked at the switch and it was just barely past the 9 o'clock location. A couple minutes later, the compressor came on. Cold air now blowing inside the freezer and refrigerator sections.
    So, after that long winded description -- does it sound like the defrost timer is bad (working intermittently) or is it still possibly something else, like the thermostat, as suggested above? If it is the defrost timer, can I just disconnect it and run the refrigerator until I get a replacement timer?
    I appreciate your help.
    President:
  • 1,136 Answers
Hi, Remove the front kick plate at the bottom and locate the defrost timer box. You will see a hole and there will be a round switch you can turn. Turn in clock wise and see if the refrigerator starts.
If it starts, the timer needs changed. If it does not starts. locate the cold control (thermostat)
Check continuity on the switch. If it is the on position and the circuit is open, you need to replace it.
I hope this helps. Please let me know if I can assist you further.
Thanks
Vic
Posted on Jun 14, 2009
  • Amana Master
  • 8,220 Answers
Probably went into defrost mode and the timer got hung up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Amana AR2664bw dispenser lights
Are you talking about the inside lights are the dispenser lights?
Nov 01, 2008 | Amana Refrigerators
Amana Side by Side Refrigerator
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 24, 2010 | Amana 22.6 cu. ft. Side-By-Side...
My Amana SPD26VW no longer cools. The fan is running but the compressor is not. I turned the defrost timer switch all the way around and the fan turned off for a few degrees of rotation and was on the rest...
i would take off the back and feel the compressor, if its hot then it is struggleng to come on if not
make sure the unit is unpluged then disconnect the overload and relay they often fail and cuses the sysmtoms you speak of
Oct 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Not cooling
If it's clicking on and off like you say, replace the compressor start relay device and overload protector. These are located directly on the side of the compressor, usually contained within a dark plastic cover.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Amana SPD26VW runs, lights on, does not freeze
I called Amana and found the "sealed systems" are still under warranty. It cost me $85 for a service call and the fridge is working. The problem was a plugged "capillary line."
Jun 23, 2009 | Amana 22.6 cu. ft. Side-By-Side...
AR2664 dispenser lights
remove the cover you will find a duel mirco switch one side is for the water the other is for the light. switch is bad on light side.
Nov 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice/water dispenser not lit or working
I think this is probably just a coincidence that you changed the water filter and a couple of weeks later the dispenser doesnt work. If it failed the same or next day then possibly related but unlikely. The water filter purely affects the water supply line. Does the dispenser (water) make a noise (clicking) when activated. If it does then I would check the incoming water supply. If it makes no noise then you possibly have an electrical fault not providing power down to the water solenoid valve. The way to check the ice dispenser is to see if you first have any ice production if you do then again it could be an electrical control fault. You could check the underneath of the cabinet low level for the wiring connection from the door to see if it is dislodged or damaged however if it is a control issue then I would suggest contacting a good fridge tech. Hope this helps.
Sep 05, 2007 | Amana ACD2232HR Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
567 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
