Question about Canon Rebel XT / EOS 350D Digital Camera
Pop up flash not working
When I press the pop up flash button, it doesn't pop up, also, will not pop up when taking a low light photo
  • 130 Answers
You probably need to change the setting wheel on the top of your camera to either auto or Program (P) to do what you are wanting.
Posted on Jun 14, 2009
D60 flash won't pop up
Please set the MODE to P (Programmed Auto) In this mode YOU control the flash, not the camera. Inside where it is not bright. Set your ISO to 800 and take a photo indoors with low light. Then pop up the flash and do it again. P lets you take a photo with the flash down or UP it is the only mode I suggest most people should use. :)
Jan 15, 2017 | Nikon D60 Digital Camera
HOW TO TURN ON FLASH
Flash should pop up automatically when you operate camera in easy mode (green square on dial selector) in low light conditions. If using in manual modes press the button on the left side of the lens mount. To fire the flash without taking a picture press the button used to zoom out when viewing pictures.
If your flash does not work at all then there is probably a fault with the charging circuit or firing circuit.
May 11, 2012 | Canon EOS Digital Rebel XS / 1000D IS...
Sony Cyber-Shot DSC-F828 Digital Camera won't flash
Make sure Flash Shoe option is Off in setup menu then check flash light.
Does camera give any blinking error code when flash fails to fire?
Does flash pop up when you press shutter button to take picture in low light?
Let me know to find out possible cause of problem.
Oct 13, 2010 | Sony Cyber-Shot DSC-F828 Digital Camera
I can't get the flash to come on. what do i do?
Switch the photo mode selector knob on top around to P. Then press the little black button on the body behind the AF/MF button on the lens. Flash will pop up and work then (don't forget to switch the camera on before doing this stuff). All of the above takes the camera out of auto mode (the square green box on the selector), so you can tell the flash you want it. It will work in the other manual modes as well of course. Good Luck
Steve
Sep 25, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Why won't the flash on my e500 pop up when the correct button is pressed or when I try to take a picture that requires a flash?
When you take pictures in AUTO, Portrait, Macro or Night scene mode, the built-in flash will automatically pop up in low-light or backlit conditions. If you want to control the flash pop-up, set this function to OFF.
1 Menu [AUTO POP UP]
2 Use control dial to select [ON] or [OFF].
3 Press the Ok
button.
If you are in any other mode the flash will not auto pop up.
Apr 16, 2009 | Olympus EVOLT E-500 Digital Camera
Flash not working
pop up the flash and you can select flash mode by pressing the arrow like button press right to select the flash mode....
Jun 16, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Nikon D40 - The built in flash will not ppo-up in auto mode. The only time it works is the manual modes. Are there any settings I don't know about. I'm calling it defective and will return it the store.
With the command dial set to "auto", try to take a shot in low light. The flash should pop up automatically. You can't manually pop it up with the flash button in the auto mode. If it won't pop automatically in low light, then it certainly sounds defective.
Apr 16, 2008 | Cameras
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Built in flash
Have you given it a gentle press down with the button depressed? This will release it sometimes, Other than that it is a repair shop job or send it back if you are able.
May 20, 2007 | Canon EOS 30D Digital Camera with 18-55mm...
Canon Rebel XT / EOS 350D Digital Camera Logo
95 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
