Question about Dryers
How do you crack open the GE Dryer Model DBXR463EBOWW to take out the drum? I only see two screws on the bottom and two for the legs. After taking these out nothing. What or how do you take out the drum? I have never opened a dryer before so I have no idea where to start. Thanks
  • Dryers Master
  • 8,220 Answers
Check out my handy GUIDE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
    President:
  • 1,136 Answers
Hi, Insert a flat blade screw driver in the gap between the top panel and the front. There are two spring clips to release the top.
Once the top is open, there are two screws located inside upper corners. Take them out and loosen the two at the bottom.
The belt will need to be released in order to remove the drum. NOTE: be sure you notice the belt and how it rests on the idler pulley.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
How do I take the cabinet off a GE gas dryer model # DHDSR46GE1WW to check inside?
The following website may be helpful:
https://www.partselect.ca/Models/DHDSR46GE1WW/Instructions/?InstructionID=21302
This was extracted from the website:
Remove the two screws at the front above the drum opening (with the dryer door open). The top panel then lifts off. I removed the screw at each side that holds the front panel to the side panels, tilted the front panel forward, which disengages the front of the drum from the front drum glide bearing. I then lifted the front panel slightly, unhooking the bottom of the panel from the dryer base, and swung the front panel aside.
Oct 10, 2017 | Dryers
How to install dryer belt for a ge model dbsr453gb3ww
  • Unplug the dryer and pull it out from the wall.
  • 2
    Remove the top of the dryer by opening the door and taking out the screws along the top of the opening, then lifting the top. Remove the front of the dryer by reaching down into the opening at the top and taking out the screws holding the front in place. Move the front piece out of the way just enough so you can get to the drum inside, without disconnecting the electrical wires running from the front piece to the unit.
  • 3
    Move to the back of the dryer and remove the screws holding on the small access panel at the bottom. Remove the panel. This will give access to the two pulleys holding the thin belt that runs around the drum. With your pencil and paper, draw a diagram showing exactly how the pulleys are strung. Then slip the belt off the pulleys so it's hanging loosely on the drum.
  • 4
    Return to the front of the dry and pull the belt off the drum from the front. Put the new belt on the drum from the front, laying the ribbed side against the surface of the drum.
  • 5
    Return to the back of the dryer and restring the belt through the two pulleys, using your diagram as a guide. Use your hands to manually turn the drum at least one full turn to make sure the belt is lined up.
    Things You'll Need
    • Screwdriver with multiple bits
    • Pencil and paper
Jan 11, 2012 | Dryers
I need the part information for a new belt for this model GE dryer(DBXR463EBOWW)
The part number on a drive belt for the model you have listed is WE12M29. It can be purchased on line at pcappliancerepair.com for about $11. I hope this helps you.
Oct 28, 2009 | GE DBXR463EBWW Electric Dryer
How do you change belt on GE dryer model DBXR463EBOWW?
You have to open the door right where the door closes if you look up you'll see two screws take those out and the top just comes off by lifting it up and then on the inside if your in the front of the dryer the screws are pointing to you so once you got the top look at the front panel but from the inside and at the top you'll see two screws one on left one on right take them out and grab the front panel and just lift it it sits on two little hooks or screws on the bottom i usually lift right and than left or left then right.
You will now have access to slide the new belt around the drum and ready to mount on the motor pulley and idler.
Pull your dryer from the wall and remove the back panel by the vent outlet.
You will see a diagram of how belt mounts over both pulleys, follow instructions and reinstall everything the way it was.
GOOD LUCK!
Aug 30, 2009 | Dryers
Replacing felt around drum - model dpsr610eg0wt
On the DPSR610EGWT if you open the dryer door and look at the top of that opening There are two small phillips screws that hold down the top of the dryer. Unscrew those, lift the top and then slide it to the left to remove the top. Next, near the top of the seams between the front and side panels is a screw. Unscrew the small screw and the front will lift off. Be careful because the drum is supported by the front and there are also wires connected on the left. Hope this helps!
Aug 23, 2009 | GE Profile Harmony DPGT750EC Electric...
How to get the 3 scew back in the dryer drum GE DRYER
If you put your knee under the drum while your arms are inside the dryer, you can line up one. You could also duct tape one screw in and stand over the dryer to line it up. Then once lined up, manouver your foot or leg under the drum.
Feb 24, 2009 | GE Dryers
I need to change a dryer belt on GE model DBxR463EBoWW electric dryer we have the belt on but it is loose
First, make sure you are using the proper belt. For your model
DBXR4630WW that would be a part number WE12M29. Next, the grooves of the belt touch the drum. Now, looking at it from the front side, the belt goes from the left side of the drum directly to the motor drive pulley, then around the tensioning pulley, and then back to the bottom right back around drum.
Jan 21, 2009 | LG DLE2512W Electric Dryer
Front felt drum seal on ge came off---hard to repair?
Open the dryer door. At the top of the door opening, there should be two screws holding the top of the dryer down. Remove those screws and the top will rotate up, giving you access to the drum.
Nov 19, 2008 | GE DBXR463GB Gas Dryer
Drier Belt Replacement on GE model DDG7580
Open the door and remove four screws which go into the dryer top. Swing top back. Take out the screw on each side holding the dryer front to the side panels near the open top. Tilt the dryer front forward and lift it off the bottom pegs, then swing it to the side. Leave door switch wires connected. Lift up slightly on drum to allow the belt to be placed around drum. (grooves of WE12X82 belt touch the drum) Belt goes down from the left side of the dryer directly to the grooved motor pulley, then around the belt tensioning pulley and back to the drum. Your model has a removable panel at the bottom side of the back which will allow easy access to the motor pulley area.
Nov 10, 2008 | GE DVL223GB Gas Dryer
Ge dryer
Jim; without the model number it is hard to give specific advise. (model number is usually on the frame just inside the door) To open top, try pushing a putty knife in the seam between the dryer front and the dryer top, a few inches in from each side.
Nov 06, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
226 people viewed this question
Top Dryers Experts
Marvin
Marvin
