Question about GE WDSR2080D Top Load Washer
My GE WDSR2080D washer won't spin or drain. - GE WDSR2080D Top Load Washer
  • GE Master
  • 8,220 Answers
The crappy designed mexicanical lid switch device has faile, jump it out. Remove the front panel and then you can get the top off to access this problematic lid switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
SOURCE: Washer does not spin
I have a GE WSSH300G0WW washer and it is doing the same thing except I can not go to any other cycle to get it to spin. The water is just sitting in the machine right now.
Posted on Dec 23, 2007
SOURCE: will agitate, but will not spin
hover gemini. mod.A6516-010 will agitate but will not spin.thanks .henry
Posted on Feb 17, 2008
the dr
  • 447 Answers
SOURCE: GE WVSR1060A1WW washer will wash but will not drain/spin
Lid Switch either magnetic or mechanical
Posted on Nov 03, 2009
  • 9 Answers
SOURCE: GE WSSH300G Front Load Washer drains, but
Door latch for that model I chrge labor and materials minmum charge is 180 ... its easy to replace ..2 minutes done...
Posted on May 27, 2011
heatman101
  • 43501 Answers
SOURCE: GE Washer will wash but won't drain?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Jul 24, 2011
GE Washer will not agitate but it will spin
Put old coupler back on transmission shaft. Can you now turn coupler? You should not be able to. If you can, grooves in coupler are stripped out. Replace coupler. Part # WH49X10042
Sep 13, 2017 | GE WDSR2080D Top Load Washer
My GE washer #WDSR2080DEWW washer won't spin
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
Washer wont spin cycle, all other cycles ok.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Feb 18, 2011 | GE WDSR2080D Top Load Washer
My wdsr2080d will not drain
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | GE WDSR2080D Top Load Washer
GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Jul 15, 2009 | GE WDSR2080D Top Load Washer
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Washer filles with water can hear timmer then drains never spins
you have transmission problems. When your washer is empty and off you should be able to turnthe agitator by hand if you can't then the transmission is bad.
Apr 03, 2009 | GE WDSR2080D Top Load Washer
Washer
relay switch between timing circuit and spin cycle is faulty
Apr 03, 2008 | GE WDSR2080D Top Load Washer
Will agitate, but will not spin
Jan 01, 2008 | GE WDSR2080D Top Load Washer
GE WDSR2080D Top Load Washer Logo
451 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Marvin
Marvin
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
