Does the battery still charge?? The reason I ask is that some tool mfr's are starting to play with the chargers. Insert the battery and remove within 5 seconds and reinsert and then does the noise go aaway or change? Makita has started doing this and also some others. If the battery charges I wouldn't worry too much but try the above method and see.
I bought a Milwaukee Drill 2601-22 a couple of days ago, I got 2 issues. 1.- When I open the chuck...
(More)
I bought a Milwaukee Drill 2601-22 a couple of days ago, I got 2 issues. 1.- When I open the chuck all the way and then I start closing it without a bit, the ratcheting mechanism kicks in right away, then I have to close again for it to release the ratcheting then I can close it freely , is that normal? 2.- Switching from speed 1 to 2 sometimes the switch moves half way and sometimes moves all the way, I have to move it back to 1 then 2, push the trigger and try again then it engages to the speed, it does that from 1 -2 or 2 -1, both ways, is that normal operation? This is the second drill I got, the first had the same symptoms so I exchange it but the second one has the same so I'm starting to wonder if that's normal or not? Any suggestions?
Ordered new gear train for my PS20. Does it have to "bolt on" to the motor or is it held...
(More)
Ordered new gear train for my PS20. Does it have to "bolt on" to the motor or is it held in place by the tabs?
