Question about Candy AQW130 Front Load Washer / Dryer
Leaking Candy Aquaviva 130
I have a small leak from a hose that leads from the top of the machine down to the pump.  This is where the concrete block has rubbed on the hose.
I need to get a new hose but don't know what it is called.  Can you help me please?
  • 64 Answers
Re: Leaking Candy Aquaviva 130
Its called 'The Main Outlet Hose' But you can probably make a fairly good repair by wrapping Gaffa Tape around the hose. Tip! after replacing / repairing the hose tape some padding around it, so it doesnt wear again
Posted on Oct 31, 2007
0 characters
3 Points
Why water is leaking from bottom of the washing machine
it easy .look in and wach the falling drops coming from the inlet water or from the drainage hose and pump.Whatever it is u can handle it.
Jun 24, 2015 | Candy Washing Machines
HI THERE I have a candy aquaviva 800 washing machine and it seems to not want to drain all of a sudden, i have taken out the hose at the back and given a good wiggle and sat with it in a bucket while
Your drain pump is dead. Have a serviceman replace the pump. How old is the unit? If it's old enough that it has the old belt-driven style, have them check to see if the belt is stretched or broken.
Apr 30, 2012 | Washing Machines
Water is coming from the machine. we have checked the hoses but did not find any cracks. Any suggestion on what it could be and how to fix it?
The hose that connects at the water pump may be your culprit in the leak. Otherwise, the tub gasket is leaking.
If you are able, position the washer on top of 4 concrete blocks (1 at each corner), that should make it easier to see underneath with a mirror to see where the water is coming from, and verify that water is leaking from the pump area.
Aug 25, 2010 | Roper RAX4232KQ Top Load Washer
Water is leaking out from under the front part of the machine (this is a top load machine). Doesn't matter whether use small or large fill. have checked hoses and drainage in back they are not leaking....
have u checked the pump that is located iin the front of the machine? Remove the entire cover of the machine look down in the very front when the cover is removed turn the machine on and you should be able to see exactly where ur leak is coming from your pump is located on the motor small white or grey plastic round like object sometimes it can leak fromthe center of the pump in any case test the machine with the cover off and you willbe able to find the leak hope this helps
Jun 24, 2010 | Washing Machines
Candy aquaviva plumbing
NO if it has two inlets then both are used buy a connector to connect both hoses together any diy shop will supply
Dec 20, 2009 | Washing Machines
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Water leak
Remove the lower panel under the washer door and inspect the interior. The panel is removed by loosening and removing the screws under the bottom front edge. With the screws removed the panel will drop down, then off. Inspect the following areas:
- Check all hoses for leaks, cracks, holes and loose connections. Check the seal where the drain hose from the bottom of the wash tub connects to the intake of the drain pump. Make sure the drain hose from the pump to the standpipe is connected snug to the pump and is not leaking.
- Check the drain pump to ensure it is not leaking. The clean out reservoir cap (if not fitted properly) can leak around the seal.
- Check the door bellow (gray rubber boot) to ensure it is not leaking. HINT: A tale-tell sign of bellow leakage is wetness showing up on the front washer counterweight. This is a concrete block mounted to the front of the wash tub. It is not supposed to be wet.
- Check the pressure switch air hose to ensure it is connected to the air dome on the side of the wash tub. This is a small rubber hose that runs from the pressure switch in the top left rear of the washer (viewed from the back, with the washer top panel removed) to the bottom right hand side of the wash tub. However, if this hose were to come off the air dome fitting, the wash tub would continously try to fill and water would begin to pour from the bottom of the wash tub. If this does not sound like your symptoms, disregard this step.
- Check the seam where the wash tub shells meet. There is a rubber tub gasket that seals the two tub halves together. If the seal is bad, water will begin to collect and drip along this seam.
- Check the tub for cracks. This is NOT common, but it can happen.
The following link explains the step-by-step process of checking and cleaning the drain pump:
I mention this link, because it gives you some guidance on how to access the pump and how avoid the possible mess involved with water pouring out of the pump.
If you discover the door bellow as the the cause for your leak, please refer to this link:
I hope this leads you in the right direction and helps you resolve your problem. Please post back if you have any further questions.
Aug 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Candy Aquaviva 1300 washing machine
fabrick condictioner drawer stays full can you help me bernie
May 21, 2008 | Candy AQW130 Front Load Washer / Dryer
Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Sep 13, 2007 | Washing Machines
Candy AQW130 Front Load Washer / Dryer Logo
88 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
