Question about Toshiba Satellite Pro A200-EZ2204X Notebook
Satellite ac connecting port damage how do i fix this problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 95 Answers
Http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A105/remove-motherboard-1.htm
dissasembly instructions,you need to take out motherboard and take a look do you able to fix or need to exchange ac port
Posted on Jun 14, 2009
Will the PoE Function of S2700/S3700/S5700 PoE Switches Be Affected When a 110 V Power Source Is Used?
When using Huawei power supply units, Huawei fixed switches supports 110 V AC input power. The power consumption of most powered devices (PDs) is 4 W to 5 W; therefore, 250 W and 500 W power supply units can provide sufficient PoE power for PDs.
NOTE:
All fixed PoE switches except the S2700-9TP-PWR-EI, S2750-20TP-PWR-EI-AC, S2750-28TP-PWR-EI-AC, S2751-28TP-PWR-EI-AC, S5700-10P-PWR-LI-AC, S5700-28P-PWR-LI-AC, S5700-28TP-PWR-LI-AC, S5700S-28P-PWR-LI-AC, S5701-28TP-PWR-LI-AC, S5700-52P-PWR-LI-AC, S5700-28X-PWR-LI-AC, and S5700-52X-PWR-LI-AC support double PoE power supply units.
Jan 10, 2017 | Computers & Internet
Toshiba satellite c655 won't power up
Take off the top keyboard and power lid. Check for damage to the power flex cable. Plug in AC adapter. The port where connected power flex cable should have two or three pins. With small screwdriver try two-pin jumper shortly. Does not turn on again? All you need to replace the motherboard
Oct 04, 2013 | Computers & Internet
Toshiba satellite A200-27Z power cord led flasing failure to post will try any suggestions
Have you tried another Cord with the EXACT same power specs? Remove the battery. Has the cord/charger/transformer been damaged? Has the AC jack been damaged? Due to pulling on the cord while plugged in? At the AC jack "wiggle" the plug a bit to see if the plug and AC jack are making a good connection or Loose. Sounds like a loose AC connection.
Jan 10, 2013 | Computers & Internet
Does not turn on
Most power issues with the Wii can be fixed by resetting the AC adapter. You can easily reset the AC adapter by following these steps:
1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
3. I also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
4. While you're waiting, check the AC Adapter for the following:
Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
5. Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
6. After you've waited 2 minutes, plug the AC adapter into the Wii system and into an outlet, If the power light comes on and stays on, then it appears resetting the AC Adapter worked.
Jun 03, 2012 | Nintendo Wii Console
What could be the problem if the power does not come on?
  1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip). acunplug.png
  3. We also recommend you unplug anything connected to the USB ports and the Nintendo GameCube Controller ports (such as LAN Adapters, keyboards, Nintendo GameCube controllers, etc.).
    • Make sure that the word "Wii" and the model number "RVL-002 (USA)" molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    • Check the AC Adapter for physical damage. Physical damage, such as frayed wiring or a cracked housing can cause the system to shut down. If your AC Adapter shows signs of physical damage and needs to be replaced, you can purchase one from Nintendo's online store.
Jan 23, 2011 | Nintendo Wii Console
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
My Toshiba L10 will not switch on the power supply is ok and plugged in and there is a blue light on to say power cord is connected but still will not power up, any ideas?
Do you have a known good ac adapter to try it with? Or is that ac adapter you were saying lights on powering on a different computer?Try to test both to check the functionality of the ac adapter and the port. If ac adapter will work with a different pc, then possibly the port is damaged. You may need to replace the motherboard. If still it wont turn on, then you may just need to replace the ac adapter.
May 26, 2010 | Toshiba Satellite L10 Notebook
I have a toshiba satellite A-135 laptop that will not recognize anything plugged into the usb ports
Check to see if one of the USB ports is damaged. Sometimes they can be damaged and have connections touching the outside metal of the port which actually grounds the connection and will cause the other ports to not work either. If it is connected then use a flat tip screw driver (*with the machine off and battery out*) to make it not touch the outside of the usb port and try "other" USB ports that aren't damaged and see if it works. If it doesn't then you are looking at needing a new motherboard. Locate your closest ASP and take in for service, you can find them at support.toshiba.com.
Nov 15, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite USB port is damaged
If  the usb port is at the front side of the c.p.u then it can be replaced ,but if the usb port of the motherboard is damaged then you have to take it to any repairing centre and fix it for you......because it has to be replaced with any damaged motherboard usb port....Please don't do it yourself..
Sep 15, 2008 | Computers & Internet
Toshiba Satellite Pro A200-EZ2204X Notebook Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
