Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water in bottom of frigerator
30 yr old Kenmore cold spot standing water under vegetable and meat bins
  • nita_welborn Jun 14, 2009
    Thanks, Here is the model no: 106 7688381
    thanks, vic it was a little difficult being that i didn't have a hex screwdriver...there was ice all around the drain cup there was junk in it plus frozen around it...i have cleaned it up and re installed..i will let you know if it worked.
    Thanks again
    President:
  • 1,136 Answers
Hi, The drain is plugged coming from the freezer section. Please get me a model# and I can assist you with this problem. Thanks Vic
Posted on Jun 14, 2009
  • 1 more comment
  • Victor
    Victor Jun 14, 2009
    Hi, I am sorry but, the site I use to look up models is down untill morning. I will look this up for you then.
  • Victor
    Victor Jun 14, 2009
    If your control panel in the fresh food section is top rear in the middle, the drain should be located behind the controls. If there is a light bulb on both sides of the controls, remove the lenses and the two 1/4" screws holding the control cover. Remove the control knobs and the cover will release. There will be a drain cup. Pull the cup out and flush it with water. If possible, try and use a hose to blow air down through the drain as well.
    If this is not the model you have, I will give diferent instructions when I can look this up.
    Vic
  • Victor
    Victor Jun 14, 2009
    Hi, The drain cup is behind the control panle. It is a little different design then I first explained but, same area. Remove the light lens and the two screws holding control panel.
1993 kenmore fridge has water dripping and pooling below vegetable bins, we cleaned the tube in back of freezer but it did not help what should we try next
thanks
anita
Posted on Dec 31, 2009
My Kenmore side by side fridge isn't cooling hardly. Feeling the suction and discharge lines I think it's low on freon. How do I charge it?
Well I have to go, so I can't wait for your reply for more info. Basicallty what happened to me was the freezer became very good at freezing. The problem with modern freezer/fridges is that there is only one cooling system, the freezer. The freezer chills the other side to chill the refrigerator. Something was blocking that vent into the fridge side. Turns out it was ice blocking the vent into the refer side. It happens when it is humid and the kids to "shopping" in the fridge and leave the door opened for extended periods of time.
If you are blocked by stuff in your fridge, move it away from the vent. If nothing there, you'll need to get ready for a bit of time. Side-by-side freezer/fridges, typically the freezer is on the left. So, open the fridge, somewhere near the back about 2/3s of the way down, just above the vegetable bin, on the left side. Remove the cover, if something is stuck in there, gently try to remove it. If it is ice, like I had, you should remove your vegetable bin and meat bin and unplug the unit (to prevent shock as water will be everywhere. Be sure that your overflow tray (under the unit) is empty. Next is to make quite a bit of boiling water (I ended up using just over a gallon). If you are at the point where you can't get the cover off, you'll have to use a baster to melt the ice that is holding your vent cover on (that is where I started). Then you can start working on the ice. You need to keep putting water in until you get hot water in the overflow tray. Replace your food and don't slam the fridge control all the way to the coldest setting, you could end up freezing your meat and vegetables.
The repairman came and told us, he could do this for us for $200 or we could do it ourselves. He would have done the exact same thing.
Feb 05, 2014 | Kenmore Refrigerators
Sears Kenmore refrigerator 18cu frost free. Water constantly flows down the back of the fridge and collects under the vegetable bins. How do I fix it?
sounds like the drain pipe is blocked. turn it round and at the bottom there is a pipe check its not blocked. to clean out use an old curtain wire or something that can get up the pipe and flex.
Nov 03, 2013 | Kenmore Refrigerators
Water collects in the fresh meat compartment (in refrigerator section). Ice forms on the bottom (under the fresh vegetable bins) of the refrigerator.
Your drain is likely plugged and not allowing the defrost water to drain out. You will need to remove the rear freezer panel and thaw the drain. I would recommend installing a drain heater while you have it apart. They are inexpensive and easy to install. They come with installation instructions.
Kelly
Mar 23, 2011 | Refrigerators
My vegetables are freezing in the vegetable/meat bin. How can I keep them from freezing?
Check your settings for your thermostat. Turn it down in increment's one letter or one number at a time. Higher letters and numbers normally mean lower temperature. Also, the veg bins have settings also.
Feb 13, 2011 | Kenmore 57029 Side by Side Refrigerator
My whirlpool is leaking water under the vegetable/fruit bins and inside the cheese/meat bin.
defrost it, remove back panel on freezer side, and unclog small hole where water collects
Feb 13, 2010 | Refrigerators
Water in bottom of refrigerator under vegetable bins.
there should be a tray that guides water from freezer to a drain located in the fridge section normally held with one screw . take it off and unclog drain ( use a vacuum to **** out sludge) clean tray/guide and mount back on. make sure all moisture is cleaned out after drain is cleared.
Jun 20, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
404 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
