Question about Onkyo TX-SV525 Receiver
There is no sound going to the rear speakers. Is there a certain mode I need to have the receiver on. If it is not a mode switch, is it a relatively simple fix?
  • 39 Answers
Assuming you do have all 5.1 speakers connected and a digital signal (DVD/CD etc)
Make sure that you have the surround speakers connected into the right spot on the rear of the amp: they can be confusing with their markings.
Front speakers should be in speaker A front.
You must have the sound setting or sound programme on Dolby Digital or similar, Not just stereo. There should be a dial or button on the front panel for this.
Bear in mind that the rears are the only for effect and do not alway produce sound.
Maybe send me more info:
Posted on Jun 14, 2009
Rear speakers are dead, never got them to work. Changed front to back and rears work so speakers and wireing are good. Is it possible that because I did not hook up a center speaker this is the problem?
if its a 5.1 channels it means 2 front speakers,2 rear speakers or either the center speaker or the subwoofer.try to hook up either center speaker or subwoofer.
Jun 05, 2010 | JVC RX-888V Receiver
I have a VR 615 receiver. All 6 surround sound
It all depends on the processing the receiver is doing when recreating the sound. Change the surround mode to Dolby Digital or THX if it's on there. When it is receiving a Left/Right signal only, it does some processing but pretty much spits it out of all the speakers, fronts being the loudest. That's why you always hear them. When it is getting a Digital signal, the receiver does a much better job of processing the audio to the correct speaker, but unless there is a lot of background noise, there might not be any signal going to the speaker.
Also, check to make sure that the "size" of the speaker on the rear channels is set correctly. There is a setting on most receivers to tell the receiver how big the speaker is on that channel. This sets the power level on the output to accomodate the size of the speaker.
Oct 25, 2009 | Kenwood Audio Players & Recorders
Buzzing on certain speakers (but not all)
do you have the problem in stereo mode (no suround) Try to disconnect rear speakers and see if you still have the buzzing if you do then disconnect center and check,using only the mains,process of elimination, check your polarity + - on speakers and check the wire.I would double check ALL connections even RCAs
Feb 01, 2009 | Yamaha HTR-5840 Receiver
Volume distortion only on tv setting
RCA HAD A CERTAIN MODEL SERIES THAT HAD A REALLY BAD DESIGN,,IT SEEMS THAT SOLDER CONNECTIONS STARTED BREAKING LOOSE AND DEPENDING WHERE THEY CAME LOOSE,,YOU WOULD HAVE PROBLEMS IN THAT CERTAIN CIRCUIT..TO DETERMINE IF YOU HAS THAT SERIES,,WE WOULD NEED THE CHASSIS # ON THE BACK...
IF THE CONNECTIONS CAME LOOSE IN THE VERTICAL CIRCUIT--THE PICTURE WOULD CLOSE UP ,,IF IN THE TUNER SECTION--YOU WOULD LOOSE CHANNELS ,,IF IT WAS IN THE AUDIO SECTION--YOU WOULD GET CRACKLYN SOUND OR NO SOUND
ONE THING YOU CAN TRY--PUT IT BACK IN THE TV MODE,,GENTLY TAP ON THE CABLE CONNECTOR IN THE BACK OF THE SET AND SEE IF IT CLEARS UP,,IF SO YOU HAVE THE CONNECTION ISSUE--WILL NEED A TECH..GOOD LUCK ..TUNICA
Oct 30, 2008 | RCA P52926 52" Rear Projection Television
No surround sound
if the unit has no digital dvd 5,1 input it will not play 5.1 output, unless the unit is switched into a virtual surround mode(theatre/etc) mode try with a new dvd film with a digital glassfiber cabel if it shows 5.1 on the display of the receiver. if it shows 5.1 digital surround than the end stage of your surround is blown and needs to be replaced
pauliesbouth
Aug 25, 2008 | Yamaha HTR-5650 Receiver
Surround sound distortion
Receivers like this will incorrectly decode rear channel audio and pass it on to the rear channels as distorted audio. Make sure the source being used really has rear channel information encoded into it. It could have other issues but check this first.
Dec 16, 2007 | Sony STR-DE625
No sound in surround modes
I just connected the front main speakers and sound well, but when i connect the speakers (2 fr, 2 rear, 1 ctr) there`s no sound in any surround mode from any source.
Aug 15, 2007 | Onkyo TX-SV525 Receiver
332 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
