Question about Canon PIXMA iP1600 Printer
Orange light flashing
I've just changed my printer cartridge, following the instructions given on these pages.  It fitted in OK but now after flashing the green light once, it flashes orange 5 times.  What have I done wrong?  I've tried turning it off and one again but it makes no difference.
  • Tihesa Dec 20, 2007
    I changed my ink cartridge, and when I try to print, I get a message saying that the printer is out of paper and to load paper and resume printer
  • Anonymous Dec 20, 2007
    My printer flashes and will not turn off and we cannot print...is there a solution?
    Genius:
  • 1,601 Answers
  • Thomas Christopher
    Thomas Christopher Oct 31, 2007
    Resetting the Printer
    By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur.
    Follow these steps to reset the printer:
    1. Turn the printer off with the Power button (if available).
    2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
    3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
    4. Turn the printer back on.
    Note: If resetting the printer does not work, please attempt any other solutions that appeared in your search results.If this is a hardware error on the printer, the printer may need to be repaired.
    Also,
    Supported ink cartridges / Printable sheets limits
    When replacing ink cartridges (when ink cartridges are not recognized, ink runs out, etc.), use the following ink cartridges. See the table below for ink cartridge output specifications.
    Supported ink cartridges:
    Black: Insert into the left side of the ink cartridge holder.
    Color: Insert into the right side of the ink cartridge holder.
    Color
    Cartridge
    Capacity
    Printer Model
    iP1600
    iP2200
    Black
    PG-40
    Standard
    Prepackaged
    Prepackaged
    PG-50
    High capacity
    Not usuable
    Sold separately
    Color
    CL-41
    Standard
    Prepackaged
    Prepackaged
    CL-51
    High capacity
    Not usuable
    Sold separately
    Number of printable sheets
    Note: Printable sheets limits may vary depending on circumstances of printer usage.
    Printing pattern
    Media
    Cartridge
    Printable sheets per Cartridge
    1,500 characters per page, normal text
    A4 or Letter / Plain paper
    Black ( PG-40 )
    Aprox. 520 sheets
    Black ( PG-50 )
    Aprox. 810 sheets
    ISO JIS-SCID No.5
    Black ( PG-40 )
    Aprox. 760 sheets
    Black ( PG-50 )
    Aprox. 1,170 sheets
    Color ( CL-41 )
    Aprox. 190 sheets
    Color ( CL-51 )
    Aprox. 320 sheets
    Digital camera 24 images
    4 x 6 / Photo Paper Plus Glossy
    Color ( CL-41 )
    Aprox. 100 sheets
    Color ( CL-51 )
    Aprox. 180 sheets
Hi, My ip4500 printer has an orange light that is flashing five times. I have just changed the ink cartridges. I went online but cannot understand the instructions. Where is the reset button? Lance
for resetting follow these steps
Disconnect the power cable and connect it while holding down the power button
With the power button still down, press twice the "Cancel/Stop" red button, release the power button
The printes turns into a kind of factory mode...(wait for about 10 seconds, utils it says "Idle")
Press the ">" (next to the "OK" button) once."Shipping Mode 3′
Press the "OK" button.
Press "OK" again for "Without cleaning"
A test page will print..
Open the cover, like you are about to change the cartridges, disconnect the power cable again.
Take out both cartridges and dlose the cover.
Connect the power cable once again, Turn the printer on.
Now just put the cartridges back.
good luck, and do rate the solution if helped
Nov 29, 2010 | Canon Pixma iP4500 InkJet Printer
A test page keeps on printing everytime the printer is switch on
The printer is printing alignment page. This will be printed if the printer was reset or if you have changed the ink cartridges. We need to complete the alignment process.
1. Place the printed page on the scanner correctly.
2. Press scan button on the printer.
3. The ON light will start blinking, wait until the ON/OFF light stops blinking.
4. Now the alignment is completed and it should not print anymore untill next cartridge change
Thank you
Rizwan.
Feb 17, 2010 | HP PSC 1410 All-In-One InkJet Printer
Left hand light flashing orange and printer wont
Check the following:
Make sure you have removed the seal on each cartridge.
Turn of Printer, open all shutters, front and back and close them firmly, firmly.
Make sure there is no paper jam.
Usually these are the immediate causes of this kind of scenario.
Then try to print again.
Dec 03, 2009 | Canon LASER SHOT LBP-5000 Printer
Canon i250, black text won't print, but ok with nozzle check
Canon i250. Instructions on this website solved the problem of flashing green and orange lights, but now the black won't print. Changed ink cartridges, but still no print. Did a diagnostic nozzle check, and the black DID print. What do I do now?
Oct 21, 2009 | Canon i250 InkJet Printer
Changing a cartridge low in ink (less than 5%)
Please download the user's manual here: http://files.support.epson.com/pdf/r300__/r300__u1.pdf. The instruction is on page 90. You should be able to open the cartridge cover if you follow the instruction.
Sep 02, 2009 | Epson Stylus Photo R300 InkJet Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Hpdeskjet 940c printer
make sure thats the right one and to test page and cean the heads if there still not ok change the cartridge again
Jan 03, 2008 | HP DeskJet 940c InkJet Printer
After changing cartridge, printer won't print a full page, gets stuck and all lights are flashing
Some problem in Catridges, take the white petrol and clean the head of the catridge and try again.
Sep 28, 2007 | Brother HL-2040 Laser Printer
Changing ink cartridges
You can download the manual from the link below: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=26322&prodoid=37368458&category=Products Get the Product Information Guide on this page, it has good diagrams of how to change the cartridges. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 29, 2007 | Epson Stylus Photo R300 InkJet Printer
Canon PIXMA iP1600 Printer Logo
535 people viewed this question
old marine
old marine
