Question about Edimax BR-6104K Router (br6104k)
I cant configure Edimax BR-6104K router with PLDT auto-connect DSL
I have a problem in configuring my EDIMAX router with a new PLDT dsl plan because my DSL doesnt have a Username and Password. Ive tried manually typing the ip, subnet, gateway and dns server in the FIXED IP configuration of the router it works for me but when i turned off the modem and router for 2 hrs and turned it on again and wait for it to for 5mins to communicate with each other then itry to go to and there's no internet again.  the call center agent told me that my DSL is an auto-connect plan so it doesnt have a username and password. can someone help me in setting the router? thank you
  • wyeith May 22, 2008
    pls help me on this matter. I had the same problem with this. tnx
Try set the Edimax router to accept a Dynamic IP from the ISP - cause I guess they provide it to you changed everytime you disconnect.
Posted on Mar 27, 2008
I have solved the same darn problem before I had the chance to crack my head in the process.
Here's my simple How To: -->
Thanks mucho!
Posted on Nov 10, 2009
If u have a pldt dsl connection which is always on there's no problem connecting to internet..because your router has all the capability to provide automatic ip addressing to all pc's connected to its lan port..even if you'll not configure your router if your router is set to default setting of DHCP enable sure you can access the internet...this is what you gonna do..configure your pc by running NETWORK SETUP WIZARD in the control panel and from there just follow the instruction on how to set your network..from the select connection method..choose this computer connects to the internet through a residential getway..if you are using a router then press next give the computer description and a computer name then press next..give a workgroup sure that all your pc in the network should have the same workgroup name...let's say MSHOME or whatever name you want...then press next again then on the file and printer sharing choose turn on or turn off depending on what you would want it to be..i suggest choose turn off first anyway you will not use to share printer the first time...just turn it on later if you want...then press next again then next again t ready to apply network settings..then wait for ure pc to install necesarry files then choose JUST FINISH THE WIZARD..then press next again then you're FINISH. that's all..reboot...then go to network connection and right click local area connection and press properties choose internet protocol TCP/IP then press properties choose OBTAIN AN IP AUTOMATICALLY then press ok and then press CLOSE that's all...then open yur browser and log on to yahoo and i'm sure you can get it. thanks
Posted on Aug 02, 2008
    Problem Solver:
  • 20 Answers
100% free, but 100% qualfied experts to help you.
Posted on Oct 31, 2007
How to configure edimax router BR-6104K
How to configure edimax router BR-6104K Problem with the Edimax BR-6104K Router
Jan 19, 2011 | Edimax BR-6104K Router (br6104k)
I cant acces to
If I'm not mistaken, you can't get to the user name password page unless you have already accessed the edimax setup page after typing 192.628.2.1, thus the solutions provided by some of our friends might not be of help.
Jan 09, 2009 | Edimax BR-6104K Router (br6104k)
My edimax prob.
Use the setup wizard under Internet Explorer - (go to: Tools, Internet Options, Connections, Setup) Choose the right connection after the setup... close the IE browser and reload it... If it doesn't work... you have to set the IP and DNS to Auto.... keep me posted if your still have problems.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router and repeat the same steps.
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username (email address format) and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix
Jul 10, 2008 | Edimax BR-6104K Router (br6104k)
How to config my edimax 6104k router???
1You can run the setup CD or manually configure it using the user interface of the router.
2.Since that is a router all devices that will be wired to it should automatically get an IP address from it.
3.Since they will be connected to the router you just need to enable file sharing on each computer.
May 07, 2008 | Edimax BR-6104K Router (br6104k)
Edimax br-6104k
well, it just works now! :-) i can access the config page. idon't have a logical explanation.:-P
Apr 21, 2008 | Edimax BR-6104K Router (br6104k)
How connect the edimax BR-6104K router using the PPPoE connection
Let's see if this things work..
First open the internet explorer browser. On the Address bar, type
The site will ask you for username and password. The default username is admin and password is 1234.
The edimax page will appear, click the quick setup wizard.
just follow the instructions. The site will ask of your broadband type; click the PPPoE x DSL and fill up the required information.
Type your Username, Password, and Service Name and other info.
That's It!
Hope this one helps you...
Dec 28, 2007 | Edimax BR-6104K Router (br6104k)
Edimax BR-6104K Router Problem:
what type of modem do you have ie is it dsl using a username and password or a cable modem.
they are 2 different setups
cany you post an update here
Nov 05, 2007 | Edimax BR-6104K Router (br6104k)
PPPoE over Edimax BR-6104K without a modem
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Edimax BR-6104K Router (br6104k) Logo
1,873 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
