Question about LG LSC26905TT Side by Side Refrigerator
Slow making ice. It is taking forever to fill the ice bin. What can I adjust to make it produce ice faster?
  • LG Master
  • 8,220 Answers
Clean the coils under the ice box so that the flow of air cools the condenser mo propah my amigo.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
  • 4 Answers
The most common problem is the water filter needing to be replaced. Does the water through the door appear to come out slow also? When was the last time the filter was changed? One other cause is a kink in water supply line.
Slow ice production
that could be one solution. I would look at how long the freeze cycle is lasting. The machine could be cycling off and on via bin stat. Average cycles from start of freeze cycle to start of freeze cycle is usually around 25 minutes or so. If it is taking longer than that, you may have to dig deeper. let me know. Don't overlook a leaking water valve.
Aug 23, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My husband replaced our water filter for our ice maker; so at first we were getting black ice cubes and now we are getting regular ice cubes but the process is so slow it will take forever to fill tray.
I would suggest cleaning the coils below the refrig ( behind the kick plate in front ) or , if clean , turn up the freezer temp slightly to make the ice maker slightly colder .
Jun 27, 2010 | Refrigerators
Ice maker is extremely slow. it will take days to
change the cooling contro indicator to freezer max ..... that will increase the speed of cooling in ur freezer ....
Jan 03, 2010 | Kenmore 52632 / 52634 / 52639 Side by Side...
I have a side by side Fridge. Model TPX24PRBBWW
turn the controls to factory settings and give it a couple of days, if it is too cold the ice can not release!!
Nov 15, 2009 | Refrigerators
My icemaker in my large French door Samsung refrigerator takes forever to make more ice. Is there some way to increase ice production? It takes 2 to 3 days to fill up the ice bucket. There is nothing in...
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Sep 08, 2009 | Samsung RF265AA Bottom Freezer French Door...
GE Eterna series Ess23xgsbb That the ice maker makes and but the despinser keepe freezing over. We have taken it out and defrosted it and with in 48 hours it frozen over again
I assume you're talking about the ice dispenser and the ice bin being frozen over.
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube and causing the water to spill into the ice bin. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker is very slow to release ice
It sounds like it is malfunctioning and needs replaced,< the icamaker has a built in heating element to warm up for releasing ice easier, it has probably quit working>.the noise is from it trying to break ice loose from tray without element warming and it is hard to do this.
Apr 25, 2009 | Refrigerators
Not producing much ice
It should produce about 8 cubes every 2 hours , there is a small door to get to the ice bin make sure it stays closed , If you still have issues you may be expeirencing the begining of a cooling problem.
Dec 30, 2008 | Whirlpool Refrigerators
I have a Whirlpool Refrigerator Model ED25RFXFW01 that is very slow to make ice. It also gets stuck very often during the dumping cycle. Is it clogged up or what?
is the ice too big? if they are, the ice size adjustment needs to be adjusted. if the water to freeze is big then it takes a lot of time to freeze it and ice produce is slow. also you can check the pressure of the water to the ref, it could be very high pressure. i hope i was able to help.
Jul 05, 2008 | Whirlpool Refrigerators
Hoshizaki Ice Maker
check condenser condition can be dirty, cleaning the coils with coil cleaner for ice machines(i suggest you take all the ice out of bin first) i'd go with that first. check if it works for you.
Mar 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
LG LSC26905TT Side by Side Refrigerator Logo
482 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
