Question about Craftsman 10" Table Saw
Rear Bearing on RM871
Read Bearing on RM871 shot. Lightly used homeowner only.
The rear bearing is a 6200ZZ (sheilded); hope you didn't let it run too hot. I can't get this on off the shaft with heat and a bearing puller. Good luck!
Posted on Jan 07, 2010
Sears only shows the purchase of a new armature or new motor. They do not show this bearing seperately. This route will end up being just short of purchasing a new saw. Correctly measured, the bearing can be purchased through a bearing supplier. I have a good automotive parts supplier that was able to obtain the bearings I needed. I caught the problem quickly and was able to salvage the rear housing. The housing is available from Sears for approximaely $30 if yours needs replacement.
Posted on Dec 08, 2009
Find a local tool repair shop and they should have the right bearing on hand for repair - This is what I have done and they had both the rear and front bearing - It cost me 40$ to have them both changed
Posted on Nov 27, 2009
  • 87 Answers
Since it's a Craftsman you can get a replacement part easily. Your owners manual should have a diagram with part numbers. Call up Sears, order up a new one.
Posted on Jun 14, 2009
Saw starts but jerks to a stop right away
Sounds like the bearings are wearing out. Is the blade wobbly? Does it squeal like a pig? If so, the bearings are shot. You will be able to replace the bearing on a high dollar saw. If its and off brand or homeowner type, buy a new one.
Mar 05, 2014 | Saws
2001 Chrysler 300m
Hi
The wheel bearing may carry the magnetic ring that the abs sensor uses to pick up a reading.
Replace bearing if its faulty and retest all as before.
Roger
Apr 24, 2017 | Chrysler Cars & Trucks
How do you replace the bearings on a GE Spacemaker DSXH47EG1WW dryer. In addition to a bearing set, is anything else recommended for the repair?
I looked up your model and it is VERY similar to that of a Frigidaire model. Same rear bearing as a Frigidaire type. The front of the drum rides on felt. The controls are all quick connected with molex blocks so that is not an issue. I ran across a homemade video of the bearing being replaced by a homeowner who is by no means a tech just a guy who can git her done!
I have a manual and the other videos He does 3 and repair photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 06, 2011 | GE DSXH47EGWW Electric Dryer
I need a table saw motor model rm871 where can i go to get it?
Sears.com would be the only place that I know of, I also think that the motor number has changed,
Oct 02, 2009 | Saws
Excessive noise when tumble drying
Most likely the front drum supports (either rollers or slides) are worn out, forcing the drum to slide over an uneven surface. If the drum is supported in the rear on rollers, these could also be the problem. Rear axle/bearing mounted mechanisms can also cause this problem.
Less likely is a worn belt or worn idler pulley bearing. All these components can be replaced by a reasonably skilled homeowner, although the dryer will have to be disassembled to do so.
Hope this helps. Good luck.
Sep 12, 2009 | Dryers
Need motor for craftsman table saw model rm871
Go to midlandhardware.com.For about $4.00 more than just price ofthe motor,you get the complete saw 15amp.motor with a laser guide!The table saw has a 3yr. warranty,3 extension wings,and a sturdy stand.Shipping to your door $24.00,$198.58 total.
Jul 03, 2009 | Craftsman Saws
New or used motor for a Craftsman 10" table saw
Sears no longer sells repair parts for this motor, only the whole motor as a replacement part, and it is $140.00, but you can buy replacement bearings from drillspot.com the bearing needed is an Enduro 6200 zz c3
Apr 26, 2009 | Craftsman 10" Table Saw
I have a Craftsman table saw with a burned out motor. The motor model number is RM871. Where can I find one for less that the $130.00 that Sears wants for the motor. That's the price of the saw.
SOUNDS LIKE THE PROBLEM I HAD, BUT WAS JUST A SEIZED-UP BEARING. I WENT TO LOCAL ELECTRIC MOTOR REPAIR ($15.74) PARTS AND LABOR, THEY REPLACED THE BEARING, THERE ARE 2 BEARINGS ON IT, COST IS THE SAME FOR EACH. THE BEARING IS PRESSED ON, SO REPLACEABLE. HOPE THIS HELPED
Mar 27, 2009 | Craftsman 10" Table Saw
Crank shaft movement
did you check the pulley on the crank shaft ??
is it warped ?? ( bent )
because i do not think that the truck will run with the crankshaft moving.....back and forth.
so in any case you have a lot of work to do.
here is how to remove the crank shaft.
REMOVAL
  1. Remove the oil pan.
  2. Remove the oil pump from the rear main bearing cap.
  3. Remove the vibration damper.
  4. Remove the timing chain cover.
  5. Identify bearing caps before removal. Remove bearing caps and bearings one at a time.
  6. Lift the crankshaft out of the block.
  7. Remove and discard the crankshaft rear oil seals.
  8. Remove and discard the front crankshaft oil seal.
INSTALLATION
  1. Lightly oil the new upper seal lips with engine oil.
  2. Install the new upper rear bearing oil seal with the white paint facing towards the rear of the engine.
  3. Position the crankshaft into the cylinder block.
  4. Lightly oil the new lower seal lips with engine oil.
  5. Install the new lower rear bearing oil seal into the bearing cap with the white paint facing towards the rear of the engine.
    1. Apply 5 mm (0.20 inch) drop of Loctite 518, or equivalent, on each side of the rear main bearing cap. DO NOT over apply sealant or allow the sealant to contact the rubber seal. Assemble bearing cap to cylinder block immediately after sealant application.
    2. lb align the bearing cap, use cap slot, alignment dowel and cap bolts. DO NOT remove excess material after assembly. DO NOT strike rear cap more than 2 times for proper engagement.
    3. Clean and oil all cap bolts. Install all main bearing caps. Install all cap bolts and alternately tighten to 115 Nm (85 ft. lbs.) torque.
    4. Install oil pump.
    5. Install the timing chain cover.
    6. Install the vibration damper.
      1. Apply Mopar Silicone Rubber Adhesive Sealant, or equivalent, at bearing cap to block joint to provide cap to block and oil pan sealing. Apply enough sealant until a small amount is squeezed out. Withdraw nozzle and wipe excess sealant off the oil pan seal groove.
      2. Install new front crankshaft oil seal.
      3. Immediately install the oil Dan.
if you have an email address i can send some images
Jun 07, 2008 | 1998 Dodge Dakota
Craftsman 10" Table Saw Logo
2,248 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Tim Venetis
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
