Question about HP DeskJet 5652 InkJet Printer
Printer lid does not latch properly
After refilling the ink cartridge I am having a problem getting the lid to latch properly.  If it does not go right down the printer will not work but I do not understand why the lid stays up about 2 or 3 mm and does not set right down.  After fiddling with the lid and recycling the switch button something???? happened and the lid went right down and it is working again but I am frustrated with the same problem everytime I open this printer lid....?????!!!!!!!!!
  • Anonymous Mar 11, 2008
    cannot close the lid after changing catridge.
I have the same problem with my 5652. Could not find an other solution then trying to replace the lid several times after each other in different ways. As that happens only several times a month, I can live with that. Most probably it seems to be a production failure.
Posted on Nov 26, 2007
I have a dell all in one printer 944. When I turn it on it keeps sending the message, "change ink cartridge" I have changed the cartridge twice and message remains the same. Is it broken?
Are you using Dell Series 5 ink cartridges?
Please unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. Now plug everything back in. This will reset any error messages the printer has. Now open the printer with the power on and the cartridges should go to the center to be replaced. Take out both Dell Series 5 ink cartridges and make sure the tape is off the cartridges and insert both back in and make sure the seat properly and latch. Close the printer and it should print an alignment page. If you still get the error message, please read bleow.
Black cartridge = black side(left side) Color cartridge = Color side(right side)
Photo Cartridge = Black side(left side) Color cartridge = Color side(right side)
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is also possible to get a new ink cartridge with a bad sensor. Please take it to the place of purchase for a refund or a replacement one.
Rick
Jun 27, 2011 | Office Equipment & Supplies
How to install the ink
Open the front cover on the printer. The print cartridges should slide on a conveyor belt from one far end of the print chamber to near the center. There should be one black ink cartridge and one color cartridge.
Remove the cartridges from the printer. This should simply involve grabbing and pulling the cartridges out. There may be a flap holding the cartridges in place that you need to flip up first. Or you may need to press down on the cartridges to spring them out of place.
Decide on replacing the cartridges with a brand new ones or refilling the existing cartridges. Refilling the cartridges can cost less money in the long-term and reduce waste, while new cartridges will guarantee to work and have the most ink up front.
Refill the cartridges with fresh ink in order to reuse them. With black cartridges, you need to drill or melt a hole in the cartridge lid, while you will remove the lid to find the color cartridge's holes. Inject the correct color ink with a plastic syringe bottle. Reseal the lid on a color cartridge after refilling.
Dispose of the cartridges properly after you purchase new ones. Take the old cartridges with you to whichever store you get the new ones from. Not only will this help you find the correct replacements, but the store may also take the old cartridges for recycling.
Insert the new or refilled cartridges into your printer. New cartridges likely have protective tape over the print head that you'll need to remove. Run a test print on the computer to make sure that the cartridges properly work
Check to see if the printer still reads the cartridges as being empty (if you are reusing a refilled one). This will be due to a chip in the cartridges that the printer reads for the ink level. It doesn't change just because you refilled the cartridges. You must purchase an electronic device that will reset the chip for you.
Chris Thrash
B52Computers
Jan 21, 2011 | Canon Office Equipment & Supplies
How do i change the ink cartridge on a canon mp560 printer
Chris Thrash
B52Computers
Jan 21, 2011 | Canon MP560 All-In-One InkJet Printer
How to remove ink
http://support.dell.com/support/edocs/systems/PRN810/en/index.htm#online_documentation
Jan 20, 2011 | Dell 810 All-In-One InkJet Printer
We have a Dell 944 showing Error 1102 consult user guide...cannot find the user guide. We just replaced color ink cartridge with a re-processed one ordered online. Please advise...many thanks!.
Hi there
Dell Printer 944 error message 1102
Why does my Dell ink cartridge level still show up as "low ink" after refilling them?
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not
be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always
report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
This post is in no way a validation of refilling ink cartridges.
Why my printer is reporting “low ink" after using refilled/remanufactured ink cartridges?
Most ink cartridges have sensors that report the ink level. The “Low Ink” is usually the last sensor (fuse) before
running out of ink.
Since the sensors are fuses that open when the ink level drops, they cannot be reset. If you are using refill or
remanufactured ink cartridges, the best thing to do is to disable “ink alerts” on the printer’s software so you don’t keep
getting “low ink” messages.
To disable “Ink Alerts” on Dell inkjet printers:
1. Open the Dell printer software (All-In One Center, Tool Box, etc)
2. Go to Settings
3. Advanced
4. More Options
5. In the “Appearance Mode, window, check “Never display the Printing Status window” and “Display the low
ink alert only when the cartridges are almost empty.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | Office Equipment & Supplies
Printer (HP5650) has full ink cartridges.window sez almost empty
That is normal, the printer "sees" the cartridges by their serial number, so when you pop in a refilled cartridge, the printer thinks you have put in old cartridges and continue to show low ink level. When you pop in a new one, with a new serial code, the ink level will reset, showing that the cartridges are full again.
You can try this:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
Doesn't always work, but you can try.
Here are links, so you can see:
http://www.misterinkjet.com/hp56reset.htm
http://www.misterinkjet.com/hp57reset.htm
Hope that helps!
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
I changed my ink cartridge, but the top cover won't close properly, and I keep getting a "cover open" error message---i am pretty sure the cartridge is in the right way. suggestions?
Lift the printer cover. There is a slot on the right side by the ink cartridges. Push the end of your little finger into the slot. Close the lid. I know this sounds lame, but it has helped me many times. It seems the latch will stick and this usually unsticks it.
Sep 25, 2009 | HP DeskJet 5650 InkJet Printer
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
HP DeskJet 5652 InkJet Printer Logo
127 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
