Question about Amana DLE330RAW Electric Dryer
Amana alg331raw. glow plug ignites gas fires and goes out ignator starts again then gas never ignites again.
  • Amana Master
  • 8,220 Answers
That is intermittant coils. Please read my essay on this:
Gas dryer works once then quits then wurks some moah. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 14, 2009
Gas dryer will not heat up the igniter lights but it will not let the flame to be put out or start
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 16, 2010 | Amana ALG331RAW Gas Dryer
Model ALG643RBW Dryer heats sometime, APPEARS Flame Doesn't Always Ignite.
heatman101
Nov 22, 2010 | Amana ALG331RAW Gas Dryer
My dryer does not heat, but the igniter glows for a few seconds and then burns out.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Amana ALG331RAW Gas Dryer
My dryer is not igniting. I replaced the igniter, still wont heat
The ignition coils located on the gas valve or the flame sensor located on the burner assembly is the problem. Both inexpensive repairs.
May 14, 2010 | Amana ALG331RAW Gas Dryer
Dryer is not heating...it tries to light, glows red but does not ignite
Replace the ignitor. one of the solenoids is not letting the gas flow.
Nov 08, 2009 | Amana ALG331RAW Gas Dryer
Gas dryer Amana Model LGA30AW, rattling noise, no heat.
I was experiencing a similar problem. I just repaired mine yesterday, with the help of this web site. Remove the front bottom panel. The are two screws located on the bottom of the panel. They are there, just slightly hidden. Turn on dryer to heat. Look inside where the panel was. Wait a minute or two and you will see the igniter glow. After a minute or so you might hear a click and the gas valve will open to start flame. After a while flame will go out until it cycles again. If your igniter glows and you hear the rattling noise and then the igniter glow goes out and you have no flame, it might be your solenoid coils are bad. These are the two black round things located on top of the gas valve. Make sure your gas dryer is unplugged. There is a wire clip attached to each solenoid. Unplug them. I needed to pry them off carefully with a flat screwdriver. There is a metal bracket holding those two solenoids in. There are two screws that you will need to remove the bracket. Use a flashlight to see them. Slide them up and off the gas valve. One is a 2 prong and one is a 3 prong. I bought a new set for 26.75. Put the new ones back the same way as you took them off. The is little nips on the top of the solenoid that line back up with the holes of the top bracket when reassembling them. Plug your machine back in and turn on and watch to see if the ignitor glows again and watch for the flame. Put panel back on and enjoy dry hot clothes again. GOOD LUCK
Aug 09, 2009 | Amana ALG331RAW Gas Dryer
Dryer does not heat. Exhaust is not plugged. Gas supply is present at the input connector. Dryer worked perfectly and suddenly quit drying. Personally, I think The igniter failed.
If the ignitor is working properly, it will glow orange. If the gas supply is present, then I would agree with you that the ignitor is the most likely the problem. Hope this helped and best wishes.
Aug 02, 2009 | Amana ALG331RAW Gas Dryer
Dryer heating problem
It sounds like an air flow issue. There is a flame sensor on the side of the flame housing. If the venting is not sucking the flame down the tube it will cycle very quickly and never reach the right temp.
Jul 04, 2008 | Amana ALG331RAW Gas Dryer
Amana DLE330RAW Electric Dryer Logo
112 people viewed this question
Top Amana Dryers Experts
Tim Whalen
Sal De
Marvin
Marvin
Are you an Amana Dryer Expert? Answer questions, earn points and help others
